#31 | |
Tube is your buddy!
.188” wall box sliders are structurally speaking close to the lower section of the Metal-tech sliders. The lower section is CNC laser cut from a flat plate of .188” and then CNC formed to the shape shown below. All four of the bends are facing the direction of outside impact. (vrs. Standard box where there is only two) The .250” laser cut internal vertical gussets are then put in like ribs in a wing. The ribs are over kill and are what send it off the chart in strength. ![]() We then go and put the two stage rub rail on the outside to help protect the upper body of the truck. Also don’t forget the one piece .500” laser cut and formed and reinforced plate that is the front mount and cat guard on the right side, these crush rocks. __________________ Metal Tech supports the efforts of http://anysoldier.com go to this site to learn how to send a care package to a US Solider in the hot zone. 93' FZJ80 (aka: NEWPIG) - 97' FZJ80 - 79' FJ40 - 78' FJ40 |
#32 | |
#33 |
Okay, here are more pics of the slider...
As you can see, I didn't touch the main part of the slider at all, just the rub rail... This is how much it moved... I'm, personally, very impressed. That was a lot of force!!! Here is a different trip up Can-Opener when I was testing the sliders. I was sliding sideways into the rocks here: |
#34 | |
Hopeless Cruiser Addict
![]() I've hit that sucker so hard on rocks only to get out to look at the damage and see...well not much of anything . A little scrape if that on the guard while the rock was looking much worse for the wear. I'm still struggling with not cringing everytime I hit my sliders, but that is just because they're so damn purdy I don't want to scratch 'em up, because they definitely are stout ![]() __________________ '97 LX450 aka "The Whale" with a winch called Damien '97 FZJ80 40th AE, Antique Sage, #267 '74 FJ40, 2F, SM420, 4" Lift, ARB locked front and rear, 33" MTRs '76 FJ40, 2F, 4-speed, 4" Lift, 33" BFG ATs (SOLD)
#35 |
Pursuance of Vacuity
Good points about the sliders. That tubing took a serious hit and only deformed a few inches...that's pretty good in my book.
__________________ 1993 FJZ80 205k, Stockish, for sale! http://forum.ih8mud.com/vehicles-tra...246-000-a.html 1999 Tacoma 4x4 V6 TRD, 115k |
#36 |
Wow the pics of the slider doesn't look bad after all. Not bad for the force it took.
__________________ <>< 1996 FZJ80 Armor Plated, Internal 6 Point Roll Cage, Marks Cruiser Crawler Box ------------------------------------------------------------------------------ For Genuine Toyota Parts Call Cruiser Dan at 1-800-432-6668 ext. 8 |
#37 |
Metal Tech
Damn Chad... it was going to happen some time. Time for the sawzall!
As for the rub rail bending I am not surprised on that obstacle. I tried it back when it was covered in snow and ice. It is a full throttle assault just to get past the first rock (couldn't even get past the first rock). I am pretty sure knowing Chad he had the rev limiter bouncing trying to get up that last part. Having a 6,000 lb truck land on those rocks, pretty much was the kiss of death. It is far different when you are slowly crawling over rocks as Mark and I did at Katemcy. We thoroughly hammered our sliders on his 80 series have some serious deep scoring in the tubing. In the case of Chad this was sheer momentum. If you look at rock crawling buggies you will find that the DOM tubing is bent to hell and back from slamming into the rocks. And those suckers weigh in the area of 2,500 lbs. Everything has a breaking point. BTW Chad you should of tired going down it for some extra pucker factor ![]() __________________ Propane Powered 2f. |
#39 |
Ride On...
In any case, your slider bent far less then your sheetmetal would have.
__________________ www.NFCruiserheads.org FJ45 Crawler and a 1983 Hilux... has had no peers for 50 years... |
#40 |
No kidding! It's all taken care of now, I dropped them off at MetalTech and they retubed them for free! Thanks Mark and LT!
#41 | |
Whitey
![]() ![]() for another great mud vendor.__________________ ~~~~~~~~~~~~~~~~ 93 FJZ80 Slee 4"/OMEJ, 35's, 4.88's, ARB's, Metal Tech sliders, On Board Air, caster plates, DC drive shaft, Pin7, CDL, adjustable rear uppers, ARB front bumper, homemade rear, Slee Skid Plate, extended brakelines, backup camera 96 FZJ80 285's OME 's ride
#42 |
No kidding. And (I think it shows on the first page) they saw this thread and told me to bring them in. I didn't ask for them to do that. MetalTech = the awesome. ![]() |
#43 |
How much air pressure did you have in? Your tires look like they are not aired down.
__________________ Third generation Californian! If you don't like it here, leave. And take your fat wife and screeming kids with you. |
#44 | |
Could you not just pop over the big rock and try the line straight up? I feel you man. I just rolled my 40 on Saturday... __________________ 1974 FJ40 FI vortec 350, H42/Orion 4:1, 4" lift, 35s, lock-rited f/r, Saginaw ps, etc, etc. 1994 FZJ80 with lockers. |
#45 |
Toyo MT's for sale
![]() Amazing how much protection the step tube on sliders can provide, that saved your sheetmetal. Back to that front axle - how are you going to make that thing strong enough for that kind of momentum wheeling? Seems a lot easier to make an 80 feel smaller on big, grippy granite than in that boulder strewn slop. You need 40" Swampers for that kind of stuff ![]() __________________ 1995 FZJ80 - F.O.R. 3.5" lift - 35" trxus MT - 5.29's - Custom SROR Tube Bumpers - De-plasticized - Dented - Dieted |
#46 | |
I probably could have if I didn't have those POS Toyo Open Country M/Ts! |
#47 |
Time for some 38.5 x 14.50 SS SXs.
#48 |
Would be nice... *sigh*
#49 | |
Metal Tech
#50 |
IH8MUD Tour Guide
LOL, why do you all keep talking about saving his sheet metal? Have you not seen his truck?
I love it. I love to see someone taking the station wagon through the hard stuff! __________________ 95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . . Remember it's a gateway drug, so it will actually lead to "crystal meh". |
#51 |
Why thank you! And it's true, there isn't much to save anymore!
#52 |
i dare anyone to post a pic of a bolt on slider supporting the entire side of an 80 via a highlift. home built or production. if the slider is the pass side and the highlift is toward the front you get bonus points.
__________________ 97lx450 4" slee/j's, sliders, bumpers, 3" exhaust, custom turbo, HG pm/Valve job/seals, sweet custom skid plate, Sleeoffroad parts, Buys oe parts from Cruiser Dan used to have 37" swampers.. 1 tons and 42's pending..... Budget Blown 98 100 series. rear locker. 2008 6.7L dodge 2500 quad cab |
#53 |
Will a forklift work?
