07-10-07, 10:35 AM
LSPV Adjustment with Pictures
Hi all. The LSPV adjustment is a topic that seems to come up pretty often, so when I was doing mine I took some photos for posting here.
Credit where credit is due -- searching for LSPV will lead to a post by Hayes in which the 'mud community explains how to do this. Maybe I'm dense, but I still felt some pictures would help, so here they are with a simple step-by-step. Hopefully fellow one-  driveway mechs will find it helpful.
The LSPV is most easily accessed by removing the left rear wheel. It's held to a bracket the frame, in front of the shock, by two studs that pass through an oval slot, and secured there by two nuts.
Common wisdom is to move it down 1/4" for the OME Heavy lift. I used a Sharpie to mark the current location of the LSPV, the desired location, and the LSPV itself.
I also marked the back side so as to keep the same horizontal orientation. I don't know if it matters, but it seems like it can't hurt.
Anyway, loosen those two nuts a bit and slide the LSPV down until the marks line up. Tighten it back down and it's done.
That's really all there is to it. In hindsight it's one of the simpler things there is to do.
07-10-07, 10:43 AM
What lift are you running? How much real world lift did you gain? These are factors.
2000 4Runner Sport Edition PP 1" Lift Coils / 32" Tires / Norcold / RTT / ARB coming soon!
SOLD! 97' FZJ80 "Junior" Black/ARB winch bar/OEM Lockers
07-10-07, 10:48 AM
OME heavy, first post edited for clarity. If you have the numbers for other lifts, posting them would be helpful.
07-10-07, 10:49 AM
You want to do what...?
there were threads where the desired adjustment was calculated as a function of lift etc with the lever arms length and all that.
'97: 89K, 3xlock, Custom HD roo bar for sale, see Classifieds for SnT, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 112K, the better half's...
DD Accord
souped up DR650
07-10-07, 11:14 AM
Turbo Diesel Lover
thanks for your time to post it dude ..
HJ-60 2H-T Intercooled Tencha
Originally Posted by crushers
07-10-07, 01:42 PM
Thanks for the post
07-11-07, 08:17 AM
what is the measurement for moving the LSVP if you have medium springs?
1997 FZJ80 - Supercharged w/ F&R lockers, 285/75r16, ARB w/ Warn9000, 2.5" Slee Lift
1973 FJ40 - Soft top, 2" lift, 33x10.5 BFG, Pwr Str, H4 Lights, Warn 9000
Calgary, Alberta Canada
07-11-07, 09:32 AM
Hill,
Look here, especially at posts 4 and 6.
Ed
07-11-07, 10:45 AM
FAQ worthy??
Seems like it might be...
10-07-07, 04:49 PM
#10 (permalink)
I messed up the threads on one of the bolts that attaches the LSPV to the frame bracket and now the nut wont thread on. the other bolt is fine. Is one bolt enough to keep it secure/safe?
1996 T O Y O T A LAND CRUISER FZJ-80
132K, Locked, Snorkeled, Pin7+CDL, ARB front Hella'd, IPOR rear and skid plate, Metal Tech Sliders, Slee 4", 4.88's, 35" Cooper STT's, 17" Sequoia wheels, Line-X'd roof
10-07-07, 07:14 PM
#11 (permalink)
IH8MUD Junkie
Looks real easy to bad mine is rusted to hell! I got the nuts loose but the two bolts from the adjusting bracket are sized into the valve housing, more PB Blasters or a new bracket.
1993 FZJ80 127,000 OEM rear locker, rear Slee bumper, Hanna Sliders, front ARB, Warn M12K, Lightforce 240's, Snorkel, OME 850/863, BFG AT KO 285’s, CDL with Pin 7 Mod, George's LEDs and more to come!
Gotham City Land Cruisers
10-07-07, 07:18 PM
ERG80
This message has been deleted by ERG80.
10-07-07, 08:30 PM
#12 (permalink)
Soak those nuts!!!!
I had to soak my nuts for almost a week to get my LSPV adjusted.
Based on my farm experience, if the box end wrench slips off once, use the penetrant, wait, then switch to a 6 pt socket, if it wont' turn, spray again and wait. Heating bolts up often helps, but because of the valve parts etc... heat shouldn't be applied. IMO you are extremely lucky if you get LSPV nuts loose on the first try.
1980 40 50k Tan no ps, no ac, (sold, Memphis Bound)
1996 80- DD, Black, Original HG,
10-10-07, 04:48 PM
#13 (permalink)
On my very heavy lifted 80 I couldn't get enough adjustment on the LSPV to get the brake balance right. Thinking about it, the rate of adjustment it gives is based on stock spring rates not uprated. So if you're running heavies then even if you reposition the LSPV and associated hardware to account for the amount of lift you still haven't accounted for the increased spring rate. If you put 250Kg in the back heavies won't drop as much as stock springs but you still need the bias that you'd get with stock springs for 250Kg...
I ended up cutting the rod that goes to the axle so just a small length sticks out of the LSPV and adjust it manually till I'm happy with the balance and forget about automating it.
Jon m0zxj
01 UZJ100 auto - lifted, locked, front bumper, sliders, snorkel, big tyres etc.
93 HDJ80 12v auto - lifted, oem locked, front bumper, sliders, big tyres etc
10-10-07, 10:28 PM
#14 (permalink)
this statement is true with the assumption that the bolts are not rusted solid to the LSPV and it will move, other wise there is much work involved (ask me how I know  )
95 TLC, factory locked, CDL switch
F.O.R. lift kit, 4.88 gears, 315 Dick Cepek FCII
10-30-07, 10:59 AM
#15 (permalink)
Please repost the pics. Looking forward to doing mine.
1994 1FZJ80 - Locked;CDL Switch
Engine: Rotella 5w40; Tranny:Mobil1 Synthetic
Bilsteins:B46-1477 FRONT; B46-1478 REAR
Bridestone Dueler A/T Revo's 285/75/16 on LX450 rims (2nd set)
OME:Springs 850 FRONT/863 REAR
Hanna Quality Rear Bumper
07-24-08, 08:51 PM
#16 (permalink)
fatherofdaughterofromer
So I am a little slow, did this mod in 5 minutes, but marked it from the other side and left the rear driver tire on. Great modification
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
07-24-08, 09:51 PM
#17 (permalink)
Did it make a discernible difference? Did you go through the gyrations of calculating the amount of movement, or did you just go for a quarter inch and call it good?
Since I did this writeup I've taken the OMEs off and gone back to stock. I'm really glad I marked the original position; it made going back to stock really easy, and it would also have served as a zero point for changing lifts.
Reason: typo fixed
07-24-08, 10:12 PM
#18 (permalink)
I just did the .25" as my lift is more than medium to see if I could tell the difference and I could. I may tweak it more later
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
09-28-08, 10:08 AM
#19 (permalink)
Wow. My bolts weren't rusted at all and they loosened on my first try. I didn't remove the rear tire either.
It took me about 2 minutes to mark the location with a sharpie, loosen the bolts, push the LSVP down 1/4", and tighten the bolts.
The pictures by ed97 were extremely helpful in locating the LSVP and figuring out which bolts to loosen.
I'm not sure why pushing the LSVP helps, but after the lift (heavy front, med rear) my brakes didn't seem balanced and my rear brakes started making noise after a couple months.
So, I decided to give this a try and now the rear brakes appear to engage more appropriately. Noise went away for now, but I also need to check if I need new rear brake pads.
96FZJ, 175k, 100 front pads, Alpine speakers on 4 doors, 94 brass rad, FIAMM horns, LEDs in doors/domes, HIR lows, 850/N73 heavy fronts, 860/N74E med rears, ShortBus front, Hanna sliders, Scangauge II, 285 Revos, PHH, IPFs, Range Rover cup holder
My FZJ80 Mods Pictionary
