05-21-09, 01:56 PM
#121 (permalink)
Rookie
Ill check that after work today! thank you for your help.
have you ever had the problem with your power window not working?
05-21-09, 02:01 PM
#122 (permalink)
Originally Posted by BenQ
I bought the Pioneer speakers and i was working on the passenger side first. i am having difficulty removing the door panel. i unscrewed the two screws at the arm rest and the single screw that attached the plastic handle bezel. i went along and popped out all the clips that i could find. i popped our the black triangle peace at the corner of of the window. i did all this, only to find that it was still fixed to the door somehow. i still couldn't slide the door panel up enough to remove it from the door's topmost interior cross rail. so i approached this problem like i do most- i used more muscle. but i got the feeling like i was at the point of damaging something, so i stopped. my question to you is : is there a notoriously hard clip to reach or a trick to removing the front door panel? (yes...i know its probably been covered in countless threads so you can post me a link to the thread and make fun of me if you want. i will only cry a little bit)
and now for a more concerning question. i pulled the plugs on power unlock and power window switch from this passenger side door, now the window wont go up or down. the driver side control and passenger side control cant make this window work. the weather in Washington can be pretty wet so i would like it if i didn't have to cruise around with my window permadown. i could appreciate any help or give advise on this situation.
So you pulled the plug and it doesn't work, but uh did you plug it back in before hitting the switch?
Originally Posted by Grench
Doesn't the arm rest have 3 screws? Two in the main portion then one at the top where the handle meets the door (hidden behind a little rectangle snap in piece)?
This, 3 screws. I didn't see this at first and got me frustrated for 5 minutes thinking I was gonna break the panel. Then oops...there she is
'96 FZJ80 197k daily assphault queen rusty
'04 WRX wagon 2.5L 244whp/298wtq
05-21-09, 07:54 PM
#123 (permalink)
Rookie
yeah. i plugged the window control back in.
i went with Best Buy's advise, they handed me the 1642Rs and said that they would work..sure enough...they don't fit. i dont think they know about the headache of the '97 LC. i'm going back to Best Buy right now to exchange them.
05-22-09, 07:35 AM
#124 (permalink)
Make sure the safty button on the driver side is not pushed by mistake.
96 LX450; Locked; 2.5" OME; 4.88; Nitto 295/75/16 TerraG; CDL Pin 7; Second battery; Slee's light harness and sliders; IPOR skid, ARB, M12000.
05-23-09, 02:49 PM
#125 (permalink)
Rookie
I played with the wires a bit and now the window works. there might have been some build up or dirt blocking the connection. i really dont know what the problem was, but it seems to work fine now
It looks like i am having similar problems as other '97 land cruiser owners. i will just remove the stock grilles because i dont think i can find a replacement speaker that can fit behind it. i feel defeated...
10-31-09, 01:09 PM
#126 (permalink)
Help: I can't get the door panel off
I'm trying to do this speaker upgrade but cannot get the door panel off. I've searched the forum but no one tells how to do it, other than "jiggle it as you lift". The problem is that the black plastic cover at the front interior corner of the window that covers the side mirror mounts seems to be in the way. And all the jiggling of the door panel to remove it has resulted in the corner of that black plastic piece cutting the leather on top of the door panel.
How do I remove that black plastic piece so I can lift off the door panel?
These are the front doors; all screws have been removed and snap in fasteners around the perimeter of the panel have been released.
Thanks!
Garth
95 FZJ80
10-31-09, 03:22 PM
#127 (permalink)
Three screws, right? You also need to disconnect the light at the bottom as well as the switches.
I don't remember taking off the black plastic piece, but I could be wrong. I seem to remember having to slightly maneuver it around that. The is also a snap in fastener right near the top near the black plastic part. I think the speaker grills need to come off to.
1995 Locked FZJ80
2007 BMW XChallenge
10-31-09, 03:41 PM
#128 (permalink)
I hope someone can help me...
Where is the location of the stock amp on a '94 FZJ80... and Can I get access to all my speakers (separately) from there?
Like each separate: Front door, Front dash, rear door, stock sub and rear cargo top speakers...
Or are the front door and dash in same line / and rear door and cargo in same line also...
I would like to install a new amp/xover and not have to route new wires, if I can jump that block, I'd be very happy. I just need to find it.
1994 FZJ80 Factory E-Locked
10-31-09, 04:19 PM
#129 (permalink)
Malta (Chip Plant) NY
Thanks!
Pry the black plastic piece off with your fingers and a flat head screw driver. Probably use the window side to insert the screwdriver. The bottom leather area might scratch. It's pretty easy.
Pat Doyle
1994 White FZJ 80, leather,CDL switch. rear winch hitch attachment .-SOLD
1996 White FZJ 80, 7 seats,leathered up, CDL,Locked,LandTanks MAF, 2" OME lift/Shocks,Revo's.
10-31-09, 04:21 PM
#130 (permalink)
Think it is inside rear pass.side compartment behind the 3rd seat. You have to reach inside it and/or take the rest of the plastic off the interior.
Pat Doyle
11-01-09, 05:26 PM
#131 (permalink)
Originally Posted by IdahoDoug
Wow, added the rears this afternoon and re-evaluated everything. Used Skillet's mounting and for those without a dremel you can also use an ordinary soldering iron with the blade thing (they all come with one) to cut the plastic baskets.
What is "Skillet's mounting" and how did you mount the new 4" speakers into the rear doors? I found that they don't fit into the original baskets. I've butchered up one of the baskets (cut the whole back off the thing) to get the new speaker to fit, but now I don't know how to get the speaker to stay mounted to the basket. Any ideas would be appreciated as I'm an ignorant sot when it comes to stereo stuff. \
Thanks guys!
Garth
95 FZJ80
11-02-09, 02:01 AM
#132 (permalink)
Post up some pictures of the hacking you've done and maybe that'll give a starting point for helping you.
1966 FJ-40 Under Construction.
1985 4Runner. Something to play with while the 40s out for mods.
2003 GMC Sierra Quad-cab. Duramax diesel w/ all the toys. Diablosport Predator tuner and 33" tires.
11-10-09, 11:28 AM
#133 (permalink)
Ok, I've finished the install and the speakers sound great! Much crisper sound and deeper base than the stock speakers. I ordered 6.5" Pioneer TS-G1641R speakers for the front, but received TS-G1643's instead. However, the TS-G1643's fit. The rears are 4" Pioneer TS-G1041R speakers, and all fits behind the stock speaker grills/door panels. And FWIW, both pairs of speakers (front and rear doors) cost less than $70 since they're discontinued. The current models list for that much or more for just one pair. I love shopping on the Internet.
Thank you everyone for taking the time to post tips, pics and instructions on this forum; it's great! Here are some pics from my install. Hopefully they will help someone else out who maybe needs a little more guidance like me...
I had great difficulty removing the door panel because the black triangular trim piece at the front of the door window (covers side mirror mounting bolts) would not allow the door panel to be removed, and I couldn't figure out how to remove it without possibly breaking it. Well, after enough frustration I figured "what the hell! If it breaks, it breaks!" I was lucky that it didn't break, but here are some pics of how it's mounted.
Two tabs secure the bottom to the door, and there's a single pin that is press fit into a hole with a plastic sleeve. To remove, merely slide a flat blade screwdriver under the cover close to the pin location and pop it off. It helps to have the window open so you're screwdriver handle has some room to move. Simple really!
The window switch/doorlock control panel simply pops off. Use your flat screwdriver to pry the FRONT up, lift and pull forward to remove it. this will disengage the tab that locks the back down.
Garth
95 FZJ80
Reason: Added additional clarification.
11-10-09, 01:30 PM
#134 (permalink)
Remove the door handle latch cup by removing the single screw and popping it up from the rear. The front has a tab that engages the door, so it cannot be popped up from the front without risk of breakage.
Garth
95 FZJ80
Reason: picture did not load for some reason.
11-10-09, 02:05 PM
#135 (permalink)
Removing the door panel - follow the instructions by others earlier in this thread - remove the screws and then use a flat screwdriver to pop the fasteners loose from behind the panel around the perimiter, then lift the panel out. Here is the door with the panel removed:
My original OEM speakers are clearly shot!
The 6.5" Pioneer TS-G1643R speakers for the front do not sit flush against the door as the magnet hits the window channel inside the door.
I positioned each speaker and drilled 3 new small holes to secure each speaker with the longer screws that came with the speakers since the Toyota speaker screws were too short.
I then used some foam insulation from Home Depot to line the perimeter of the speaker opening in the door.
Here, you can see the foam sticking out from behind the speaker. As I snugged down the speaker screws, I raised and lowered the window to make sure the speaker didn't push the window track out of alignment and cause binding:
I soldered the wires from the Toyota speakers to the new wires that came with my speakers. This allows the new speakers to plug directly into the stock Toyota harness in each door.
Here's the door reassembled:
And a close up of the speaker:
Garth
95 FZJ80
11-10-09, 03:12 PM
#136 (permalink)
Rear Speaker Install
The rear speakers I installed are 4" Pioneer TS-G1041R speakers.
Note: It is not necessary to remove the rear door panel to install the rear speakers. Merely use a flat screwdriver to pop the speaker cover off of the speaker and mounting basket.
The rear speakers are mounted in a 'basket' which holds them off of the actual door frame. And the OEM speaker grill snaps into this basket. The stock speakers are secured to the basket with a single screw in the back. I removed the OEM speakers from the basket and found that the magnet on the back of the Pioneers is too large to fit into the basket. I first tried enlarging the cavity with a barrel sanding drum in my drill press, to no avail. Then I decided to just cut the back of the basket off with a jig saw. Unfortunately, I forgot ti take pictures when I was modifying the basket, so some of these pics come from other threads on this forum.
Here's a stock speaker mounted to the basket, and a modified speaker basket. Picture courtesy of nakman:
I used a jigsaw to cut the back of the basket tub off the basket housing. Here, Romer is using a die grinder to clean up the basket opening. This wasn't necessary with the Pioneer speakers as the magnet had plenty of room once the back of the basket was cut off.
Here's the new speaker installed in the basket and the door:
I secured the new speaker to the basket with JB Weld, visible at perimeter of speaker and basket:
Although, if I were smarter I would have just used some longer screws like Romer did in this picture:
I offset the speaker mount tabs slightly from the basket's mounting tabs for the speaker cover and found that it fit perfectly - no modification required to the speaker to clear the grill mounting tabs.
Here's my completed install:
Garth
95 FZJ80
Reason: To add a note.
11-10-09, 05:01 PM
#137 (permalink)
Nice write-up. Thanks.
Ron
1978 FJ40 - Restoration project with 58K miles
1994 FZJ80 129K miles Locked with 295 Terra Grapplers, OME heavies, ARB front bumper, Warn 9000
1994 FZJ80 with 43k miles. Tons of Parts for Sale Thread and pics here: http://forum.ih8mud.com/parting-out/316462-1994-43k-plus-3-other-80s-%40-pick-part.html
1984 FJ60 - Fairly Rustfree Texas Truck, Rebuilt Engine with 5K (For Sale)
1984 Harley FLTC
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/163991-high-praise-pioneer-speaker-replacement-behind-stock-grille.html
| Posted By |
For |
Type |
Date |
| I Quit - Rising Sun Member Forums |
This thread |
Refback |
09-09-09 03:27 PM |
