80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 06-12-07, 07:11 AM   #1 (permalink)
Rookie
Cool Dumb/Easy Electrical Question
Hi guys,
Here is a bit of a dumb question. I wanted to add two fuse blocks in the engine compartment for accessories (like many of the guys on this forum have done).
One Fuse block will be 12v BAT and the other will be 12v Switched (to Ignition).
Here is my question: Inside the engine comparment, where is a good place to tap into 12v switched? (12v Bat is pretty obvious). The coil has two lines a grey line and a red line. Is either one of these a good candidate? I'd hate to weaken the ignition signal to the coil.
Thanks,
Rod Diaz
'96 LX450
Roddiaz1 is offline   Reply With Quote
Old 06-12-07, 07:13 AM   #2 (permalink)
fatherofdaughterofromer
Romer's Avatar
Garage
I tied in at the battery
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Romer is offline   Reply With Quote
Old 06-12-07, 12:06 PM   #3 (permalink)
Rookie
How is that switched? I need a source that has no power when the ignition switch is in the off position.
Thanks,
Rod
Old 06-12-07, 12:10 PM   #4 (permalink)
LX_TREME's Avatar
X2 ^ same here
Thanks,
Rod
Easy, The wire to cigarette lighter.
LX_TREME is offline   Reply With Quote
Old 06-12-07, 12:13 PM   #5 (permalink)
Danke!
-Spike-'s Avatar
If you're putting in a fuse block, you're probably thinking of drawing a significant amount of current. You won't find a switched power wire capable of doing that. Rather, you can use any switched lead in conjunction with a relay to switch a high-amperage wire directly from the battery.
-Spike
His 1994 TLC 'White Elephant' +6"/37" Locked.
Hers '95 TLC Bare bones.
"I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown
-Spike- is offline   Reply With Quote
Old 06-12-07, 12:23 PM   #6 (permalink)
EricE's Avatar
-Spike
What he said.
'94 1FZ-FE
200K on chassi, 82K on long block, USA, WA
OME medium springs/shocks; Slee Short Bus Front Bumper; Cabinet drawers in back; CarComputer sound system. York OBA.
EricE is offline   Reply With Quote
Old 06-13-07, 06:51 AM   #7 (permalink)
Rookie
Cool Relay
Yes, the relay is a great idea. I'll go with that.
As far as the ciraget lighter, mine is always hot. Ignition on or off. Not sure if that's because I have LX 450 or because it got re-wired by someone else (PO).
Thanks for the ideas,
Rod
Old 06-13-07, 10:37 AM   #8 (permalink)
The quick brown fox .....
Beowulf's Avatar
Rod
Stock wiring on your LX450 would mean the cig lighter socket is switched with the ignition. If yours is always hot it is not stock. Check to be sure you have proper fusing to this modified 12v outlet. The stock assembly also has a tiny fusible link on the back of the cig lighter receptacle; in addition to the 5amp (IIRC) fuse in the fuse panel to the left of the steering wheel.
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
