06-12-07, 06:11 AM
| | Rookie
| Dumb/Easy Electrical Question Hi guys,
Here is a bit of a dumb question. I wanted to add two fuse blocks in the engine compartment for accessories (like many of the guys on this forum have done).
One Fuse block will be 12v BAT and the other will be 12v Switched (to Ignition).
Here is my question: Inside the engine comparment, where is a good place to tap into 12v switched? (12v Bat is pretty obvious). The coil has two lines a grey line and a red line. Is either one of these a good candidate? I'd hate to weaken the ignition signal to the coil.
Thanks,
Rod Diaz
'96 LX450 |
06-12-07, 06:13 AM
| | fatherofdaughterofromer
| I tied in at the battery
__________________ Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon |
06-12-07, 11:06 AM
| | Rookie
| How is that switched? I need a source that has no power when the ignition switch is in the off position.
Thanks,
Rod |
06-12-07, 11:10 AM
| | Forum Lifer
| Quote:
Originally Posted by Romer I tied in at the battery | X2 ^ same here Quote:
Originally Posted by Roddiaz1 How is that switched? I need a source that has no power when the ignition switch is in the off position.
Thanks,
Rod | Easy, The wire to cigarette lighter. |
06-12-07, 11:13 AM
| | Vieler Dank!
| If you're putting in a fuse block, you're probably thinking of drawing a significant amount of current. You won't find a switched power wire capable of doing that. Rather, you can use any switched lead in conjunction with a relay to switch a high-amperage wire directly from the battery.
-Spike
__________________ His 1994 TLC 'White Elephant' +6"/37" Locked.
Hers '95 TLC Bare bones.
"I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown |
06-12-07, 11:23 AM
| | 250+ Club
| Quote:
Originally Posted by -Spike- If you're putting in a fuse block, you're probably thinking of drawing a significant amount of current. You won't find a switched power wire capable of doing that. Rather, you can use any switched lead in conjunction with a relay to switch a high-amperage wire directly from the battery.
-Spike | What he said.
__________________ '94 1FZ-FE
200K on chassi, 82K on long block, USA, WA
OME medium springs/shocks; Slee Short Bus Front Bumper; Cabinet drawers in back; CarComputer sound system. York OBA. |
06-13-07, 05:51 AM
| | Rookie
| Relay Yes, the relay is a great idea. I'll go with that.
As far as the ciraget lighter, mine is always hot. Ignition on or off. Not sure if that's because I have LX 450 or because it got re-wired by someone else (PO).
Thanks for the ideas,
Rod |
06-13-07, 09:37 AM
| | The quick brown fox .....
Join Date: Mar 2003 Location: Somewhere in the foothills...
| Quote:
Rod | Stock wiring on your LX450 would mean the cig lighter socket is switched with the ignition. If yours is always hot it is not stock. Check to be sure you have proper fusing to this modified 12v outlet. The stock assembly also has a tiny fusible link on the back of the cig lighter receptacle; in addition to the 5amp (IIRC) fuse in the fuse panel to the left of the steering wheel.
-B-
__________________ 97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete. Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
| Thread Tools | | | | Display Modes | Linear Mode |
