06-10-07, 01:35 PM
fatherofdaughterofromer
JDM Aux Fan Install - It doesn't get easier
With as packed as my engine bay is I felt I needed to add an Auxiliary fan. I had forgotten how much room there is in a stock truck for good airflow and was reminded after changing the filter on my daughters LX450.
I was talking to Cdan a few months ago about his set-up and he uses a JDM Fan and said it bolts right in with no modifications.
True to Dan's word, take off the grill. Attached fan using three bolts and wire it up, simple as that. No need to remove the horns or make brackets.
I installed a 30 Amp relay in the engine bay with always hot 12V so I can let it run even when the engine is off. I also wired in a manual switch so I could control when it comes on and off. I put the switch in the little grommet below the ignition.
Installing the fan itself took 20 minutes if that. The relay, switch and wiring another 20-30 minutes.
This was one of the easiest mods I had done.
How does it work. Driving around town today in 81 deg heat (no AC on) the temp gauger climbed up to about 198. Switched the fan on and it dropped 10 degrees in minutes.
Don't forget this is a DC fan. If you wire it back wards it will blow out instead of in so check it before you put the grille on. I had to guess which way to wire it and check the airflow direction before putting the grille back on
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
06-10-07, 02:01 PM
Great writeup!
This is definitely going to be one of my first mods. The A/C in my LX doesn't blow quite as cold as I'd like while setting in traffic (in 90º+ FL heat), and I bet that fan on the condenser makes a difference. Lower engine temps would be a welcome side effect as well. May I ask what your total cost was for this mod?
'97 LX450 - 136k, tree & rock enhanced
'95 Volvo 854 Turbo - 265k, highway star
Originally Posted by SUMOTOY
I just mathed boost is *exactly* the same as gearing Ken!
06-10-07, 02:05 PM
You want to do what...?
-10F is good!
'97: 89K, 3xlock, Custom HD roo bar for sale, see Classifieds for SnT, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 112K, the better half's...
DD Accord
souped up DR650
06-10-07, 02:31 PM
Where did you get the relay and thermostat for the job?
Brett in San Antonio
Alamo City Land Cruisers
Lone Star Land Cruisers - Austin
Texas Rovers
South Texas Rovers
'97 Lexus LX 450
'91 Range Rover Classic
06-10-07, 02:32 PM
Pinoy 4WD Journey
Hey Ken,
Is the fan same as the fan on 91-95 4Runner? That was a clean install. Another completed mod, eh?
Noel
97 LX450 unlock, IH8MUD decals, CDL/Pin7, HIRs, Cup Holder, 100 pads, GS LEDs, OEM grab bar, sidemarkers, ARB bar/XD9000, PIAA 520, 295/75R16 NTG, Kaymar Deluxe/tire carrier, OME850J/863, Slee speedo gear/SS brakelines/caster plates, ARB fridge, silicone PHH/FHH, Xantrex 1750 inverter, auto up and H2O temp mods. Need install: OEM subtank, BIC 95300B dual batt, blue fan clutch, OEM rear locker...
94 4Runner, OEM 4.88 gear, V6 3VZE
04 Taco Ext Cab SR5 V6 TRD RR DIFF LOCK, sliders
06-10-07, 02:39 PM
Don't know if it is the same as the 4runner, I ordered it from Cdan, he can tell you.
Relay is mounted on the firewall next to my aux fuse box. No thermostat since I am turning it on manually in the cab.
It was a little over $200 bones for the fan, don't remember exactly as it has been sitting in my garage for a while during my month in Australia. Switch and relay and wire another $16.
The relay came from Checker. It was one for a external light setup. Make sure the pacakge includes pinout information.
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
06-10-07, 04:06 PM
I would love to get a pusher fan but the space in front of my grille is eaten up with the intercooler rad. and tranny cooler. If this summer's temps cause problems it's hood scoop or other venting on the slate.
06-10-07, 05:38 PM
in JDM configuration the fan is activated when the a/c is turned on.
06-10-07, 07:03 PM
I wish I had room for this thing - with the intercooler in the way it is hard to find the fit. I think some extension blocks to basically push the plastic grill out might make it work? Still a sideways view will give the truck the appearance of the grill falling forward. Looks like a wonderful mod though.
97 FZJ80, Locked & Loaded, Safari Turbo, Safari Intercooler, Ceramic Coated Custom Exhaust, Ron Davis Racing Radiator, OME HD 2.5" Suspension, DBA Slotted Rotors, New Toyota Calipers All Around, Toyota Pads, 33" Revos, ARB Front Bumper, Center Diff Switch, Slee Stuff: Roof Rack, Step Sliders, Skid Plates, SS Brake Lines, DC Drive Shaft. HG PM'd, 9.5psi and climbing, My Rocky Mountain Mojo Mobile!
06-10-07, 07:13 PM
#10 (permalink)
aux fan wireing
Greetings
This is how mine is wired. Works flawlessly, and maintains cool vent temps while not moving. Manual switch with indicator light lets me know when the fan is in operation
http://forum.ih8mud.com/showthread.p...bc%27s+cooling
Steve
94' 175,000
94 FZJ80, Nitto Terra Grapplers 295's, Hanna sliders, CDL Switch, Aussie Locker, Lifted Spare, Slee front bumper, M12000 with incabin controls, Slee skid plate, OME springs/shocks, A-piller mounted aux temp gauge, Surepower battery system, Aux condensor fan, 1500 watt inverter, hand throttle, CB.
06-10-07, 07:15 PM
#11 (permalink)
Originally Posted by 4x4CPOSEADOG
Hey Ken,
As per CDan - No. You can use the male plug from a 93+ (IIRC) Runner fan to rig up the wiring though.
Romer - Where you gonna put your hand throttle now?
Chado
"No man has found 'pure space,' nor seen the outside curtains, where nothing has a place."
"Who needs a home when you have a colostomy bag?"
"Everyone likes to dance to a happy song with a catchy chorus and beat so they can sing along."
06-10-07, 07:19 PM
#12 (permalink)
Romer
Do you have the part number? I have a balance with Mot I'd like to spend.
Jon
'79 FJ40 33" MTRs, 2" OME;' 96 FZJ80 Retro 100% OEM Lockers, CDL, OEM Hand Trottle, OEM Grab Bar, JDM Cooling Fan, OME 851/860, OEM SubTank in process
"The monstrous evils of the twentieth century have shown us that the greediest money grubbers are gentle doves compared with money-hating wolves like Lenin, Stalin and Hitler, who in less than three decades killed or maimed nearly a hundred million men, women, and children and brought untold suffering to a large portion of mankind.” Eric Hoffer
06-10-07, 07:24 PM
#13 (permalink)
Originally Posted by Cruiser804
Romer
Jon
88590-60010
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
06-10-07, 07:53 PM
#14 (permalink)
Parts Geek, M1 Mechanic
Hey Ken,
No.
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
06-10-07, 07:56 PM
#15 (permalink)
oooh, I think I may be ordering that puppy...summer is on here in ATL. 93 today!
Dan Kunz
1996 FZJ-80 " AV0CAD0"
2000 UZJ-100 "T0WCAD0"
Member: TLCA, GA Cruisers, Upstate Cruisers
Donate to SAVE TELLICO!
_____________________________
Originally Posted by eventhough:
"apparently I just need to play with it until it feels right... "
06-10-07, 08:48 PM
#16 (permalink)
What is the big benefit of doing this? Are you essentially adding life to your engine? besides allowing to run cooler? Dumber question: you are adding a second fan to the engine bay? confused...
James
97 FZJ80, "La Mula," ARB, HIDs, Tire Carrier, Sliders, OME 850J/863 springs, L shocks, 295/75/R16 ATs, Slee TC Skid Plate, Rear Storage, CB, LEDs, SS Brake Lines, Rear work lights, HIRs, CDL pin 7
01 325I Sport Packaged DD
http://bohemianjsr.blogspot.com/
06-10-07, 09:26 PM
#17 (permalink)
It pushes more air through the condenser and radiator. Especially helps when you're in a slow go situation with the AC on. Mounts in front of the condenser behind the grill.
Chado
06-10-07, 09:34 PM
#18 (permalink)
Nice.. Now I know which way I'm going...
Kirk D
4 sale My 94' FZJ80 Factory Locked 251k, Nitto 285/75/16. CDL switch, Diff breather extensions. LandTank (Thanks) Modified Blue Hub, CB, aftermarket temp gauge, 14" Aux fan, Slee Harness's. Alpine in-dash DVD, 5.1 decoder.
06-10-07, 09:48 PM
#19 (permalink)
Hey Ken,
The Second Gen 4Runner is a clutch driven fan.
'94 lockered FZJ80
"Fish and plankton and sea-greens and proteins from the sea" - BOX
06-10-07, 09:50 PM
#20 (permalink)
My question is has anyone successfully replaced the stock fan with any kind of electric fan config? I'd love to ditch my clutch-driven fan.
'94 lockered FZJ80
06-10-07, 09:52 PM
#21 (permalink)
I did it on my 88 4runner with a flex-a-lite dual setup custom fit for the 4runner...
Kirk D
06-10-07, 10:28 PM
#22 (permalink)
yeah, me too. And I want to do the same with my LC.
'94 lockered FZJ80
06-10-07, 10:41 PM
#23 (permalink)
That has been discussed quite a bit, and while there are advantages, the reliability if the stock fan wins out.....
No problem, I'll just tow the pig to Salt Lake on a UHAUL trailer......
95 T100, beater edition (vacationing in Idaho)
97 Land Cruiser, Collectors Edition
01 Sequoia Limited
02 Camry, Commuter Chariot Extraordinaire
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
06-10-07, 11:13 PM
#24 (permalink)
My brother's truck has a new blue hub and a 14" electric pusher, mine has an older blue hub that has been tuned up with 10,000 fluid. Mine out performs his big time! I bought the same fan at the same time as his and have sold it. The tuned up blue hub works very well, can now sit in traffic at 115F+ and still have nice cold air from the vents.
If you have a supercharger, then everything changes. Due to the fan size, spacing it will never move as much air as a stock fan, even with an upgraded clutch. With the S/C adding the pusher is a good upgrade.
Copper State Cruisers #007
06-10-07, 11:31 PM
#25 (permalink)
TRU, I wonder if your fan pushing that much air decreases your mileage?
01 Sequoia Limited
06-10-07, 11:40 PM
#26 (permalink)
Romer- IIRC, CDan has exactly the same setup and he said that his produced no significant coolant temperature decrease. 10F is huge! Are you sure the decreae is not due to the fan clutch changing fan speed or the thermostat opening? I have a 14", 3000CFM pusher fan installed and, while AC performance is much better, coolant temperature does not change according to OBD2. And I have verified that it is pushing air into the condensor and it is sealed against the condensor properly.
How did you measure this 10F decrease? Can you take multiple measurements with fan on and off and post them? Is there anything else you did differently from CDan to get such a great coolant temp decrease while he did not? I'll post some measurements from my setup soon for comparison.
Ex-'93 LC Owner; Now w/ '97 LX, no lockers. Bought 7/02 stock w/35k mi. Now at 113k mi w/ARB bar, OME 850/860, Revo 285s, 150A Alt, SS brake lines, Silicone PHH, Breather Ext, PCV Catchcan, CDL, ScanGauge2, Aux Fan, landtank-fanclutch-mod, Slee Speedo, Mobil 1. Soon: sliders, TJM locker
06-11-07, 12:00 AM
#27 (permalink)
I'm of the mind that most any vehicle manufacturer's OEM electric fan will be as good as any clutch fan, because when a car builder offers a 7 or 10 year warranty on a drivetrain with an electric cooling fan, he's going to put top quality parts and labour into the assembly of that fan to prevent warranty claims due to overheating.
If something like Ford's 19" Crown Vic (fleet/cop) fan or Mazda's dual fan from the older RX7 pulled enough CFM, I'd give it a try.
**Note: I don't live in a hot climate. Overheating, even when stopped in traffic for extended periods isn't an issue here.
'94 lockered FZJ80
06-11-07, 12:06 AM
#28 (permalink)
Been running it for a year and if anything the mileage is slightly better.
06-11-07, 06:05 AM
#29 (permalink)
ThinkTank Waterboy
I remember reading that after Dan "tuned" his blue clutch that the pusher made no difference. And at that point only opening the hood helped lower the temps.
Rick Bigelow
'96 215k
Groveland MA 01834
06-11-07, 07:05 AM
#30 (permalink)
I have not tuned my blue clutch, I will do that later. This was a sample of one as I just installed it. Driving in traffic stop and go, no AC. Turned the fan on and saw the aftermarket temp gauge go down, could have been coincidance, but I think a good part of it is due to the fan. I will run some more tests. I think Dan did his test with the AC on. I also know that if Dan doesn't turn it on in hot weather with the AC On, the temp goes up.
Dan is the one who recommended I get one. I wouldn't think he would do that if I wouldn't see any real difference. He told me about being able to sit in high heat with the AC blasting and the fan on not letting the truck get hot.
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
