tlcwagons.org
Slee4+1 w/ Bilstein 7100s
Well it's getting there. Still not done but the big mile marker of installing shocks got done today thanks to Rick (Inverness) and Dale.
Still to do- bumpstops, 4x4Labs relay & tierod w 1 ton tre's, front swaybar drop...probably other stuff. I have to mess w/ the front 7100s b/c Bilstein randomly welded the angle of the resivoir tube 10 degrees higher...dammit! If Bilstein had a vagina, I'd punch it. Hard. No real verdict on the shocks, but will update w/ I get some offroad time on them. What we have- 7100's w/ 400/100 valving. Custom mounts, we (Mike, Rick, me) take credit for the cool lower rear shock mount- but Mike discovered we didn't re-invent the wheel! It's been done in JPN... Slee 4 springs (they are awesome) and 1" spacers. Slee panhard adj/control arm adj/ dc driveshaft Other Slee stuff I can't think of... Also check out Rick's photos on installation http://www.flickr.com/photos/80_on_i...7600184098497/ Here are some pics- Front lower mount ![]() rear lower mount ![]() ready to install ![]() front shock ![]() rear shock ![]() full stuffage ![]() front driver's side
Very sweet setup. I like the mounts that you guy's fabbed up.
What was your decision process to get to the reservoir shock versus the 5125? Can't wait to hear the results after some good road and trail time. TR __________________ TroutRunner 1996 LX450 - 850J/863+10mm, 305 MT/R's, Hellroaring BIC Dual Optima 34M's, 12V Outlets 4X4 Labs Rear, Shortbus Front, Hanna Sliders, Slee Transfer Skid, Warn 9.5XP with 100' Masterpull Syn Line OEM Sub-tank, ARB Fridge 2004 4Runner - 3" OME Lift, 32" Nitto Terra Grapplers Last edited by TroutRunner; 05-27-07 at 03:54 AM. |
KI6MIE
Nice pics James. Did you guys start with C channel to make the mounts?
__________________ Andrew 1971 FJ-40 Rubicon tested, 2F powered, some mods 1976 FJ40 Rusting slowly in the back yard 1984 FJ-60 H55f, 4.11, OME, Daily Driver 1989 FJ-62 117k-son's driver for now-low and slow 1997 FZJ-80 Driveway queen |
Thats a beauitiful setup.
Those 7100's and Slee springs are crazy sexy! Daddy!Im very courious what the day to day difference between the 5125 & 7100? ken __________________ 97 with thingy's and dodads ![]() Now with added geek KI6JEO
IH8MUD Tour Guide
sweet. I always found it funny that those beautiful bilstein's with all the polish and shine, use cheap ass hose clamps to hold the reservoir on....
__________________ 95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . . Remember it's a gateway drug, so it will actually lead to "crystal meh". |
Nice pioneering work... I can see the line forming already
![]() I look forward to hearing about the ride (with the 7100's) |
tlcwagons.org
Andy, yes- here is a picture- we fabbed them out of square stock. That is what we had on-hand. C-channel would work too. Rick has an excellent facility so we could fab to our heart's desire
If you look at Rick's photos, you can see more details too ![]() ![]() why 7100? The important thing is the valving needs to be appropriate for the truck. I don't think the 5100 series even comes 400/100 - construction materials and internal design is different too. Also, the 7100 is not an emulsion shock. custom valving-you can do yourself, completely owner-rebuildable-basically lifetime units, fade-free... Yeah the hose clamps are cheap but I think billet clamps are in our future! hehe Note we did Upper heim/lower bushing. W/ this setup, we have absolutely no binding of the shock (as w/ stock post mounts). Only limited by links & bumpstops
Could someone explain valving in the 400/100 sense versus 255/70? Benefits? Downsides?
Also, what is entailed in rebuilding or servicing a shock like the 7100 on your own? Do you have more pics of the upper heim joint? Ricks page gives a hint, but I was wondering how you built these. Thanks, TR __________________ TroutRunner 1996 LX450 - 850J/863+10mm, 305 MT/R's, Hellroaring BIC Dual Optima 34M's, 12V Outlets 4X4 Labs Rear, Shortbus Front, Hanna Sliders, Slee Transfer Skid, Warn 9.5XP with 100' Masterpull Syn Line OEM Sub-tank, ARB Fridge 2004 4Runner - 3" OME Lift, 32" Nitto Terra Grapplers Last edited by TroutRunner; 05-27-07 at 02:50 PM. |
tlcwagons.org
x00/x00 is the rebound/compression valving. the lower numbers are softer/designed for lighter vehicles. For example a stock 80 will take softer valving than a fully armored/lifted one.
The 7100's come w/ heims. It is a uniball that allows a lot of articulation and no binding. The downside is that it can transmit more noise into the cabin as bushings dampen those out. (altho I haven't noticed any extra noise yet) We used bushings on one end/heim on the top. As w/ a SAW,FOX, etc. The 7100 uses valve stacks (thin washers) that you add/take out to adjust the valving. I believe the only really specialized tool you will need is a nitrogen tank (or go to a place and have them 'charge' the shocks) 7100 has a schraeder valve for easy charging. Here is the picture of the upper uniball joint
#10 |
HQ Motorsports, INC
nice work James, great pics along with the writeup
#11 |
tlcwagons.org
Thanks Ken, thanks Pasquale, 450 Dude
Here is more detail and specifics on how we did it by Rick Bilstein shock install on the 80 Mike, James and I teamed up and designed, manufactured and installed shock brackets with shocks for our respective 80's. In addition, James and I installed Slee's 4" lift with 1" spacers on both of our trucks. What can I say, 4" was not enough and 6" was, well... too big. James and Mike did quit a lot of research on shocks and mounting hardware. With Ali's help, plus the given compression/extension parameters we decided on Bilstein 7100s with 400/100 valving (MDL# AK7112SB99-400/100). Shock Size Requirements for Mike's truck differed a bit, so some descriptions aren't applicable. With the sway bars off and the truck flexed, the rear shock dimensions were 18-1/2" compressed and 30" extended. The top rear shock eye-to-pin converter bracket reduces the distance by 1-1/4" and the bottom rear eye-to-eye converter bracket reduces distance by 1-1/2". Added together there is a 2-3/4" reduction of space between the shock mounting points. Therefore, the shock requirements were 18-1/2" - 2-3/4" = 15-3/4" compression space and 30" - 2-3/4" = 27-1/4" extension space. After looking at manufactures spec's James and I decided on the 12" short body shocks. Mike used 14" shocks. I bought them here and at the time they had them in stock with the desired valving: http://www.eshocks.com/bil_ORvh.asp?...Index=4Q1&Man\ f=All&SubChar=Q <http://www.eshocks.com/bil_ORvh.asp?..._Index=4Q1&Ma\ nf=All&SubChar=Q> Converter Brackets Both the pin-to-eye and the eye-to-eye converter brackets are made from 2" x 2" x 3/16" tube steel x 1-1/2" long and eight are needed. One face of the tube steel has a welded seam. This side of the tube will be cut off to create a "U" bracket, it's important to keep this in mind when laying out the holes. Pin to Eye bracket: 1) In all the brackets drill two 1/2" holes for the shock eyebolt. In four of the brackets drill a 1/2" mounting bolthole (this is at the base of the U). 2) Cut two chamfers to allow for shock rotation. 3) Cut off the welded seam face to create a U shape. 4) In the mounting hole, a 1/2" x 1-1/2" bolt was welded in. 5) A washer was welded at the base of the four of the bolts to insure that the new front brackets remain centered in the trucks mounting holes. 6) The stock top rear mount was replaced altogether with a 5/16" x 1-1/2 x 6" long steel flat bar. Holes were drilled to match the stock bracket including the slotted hole. A "U" bracket was welded, as close to the slotted hole as possible to allow for the mounting bolt, in addition, the bracket was rotated 20 deg to allow for hose clearance. Mike created one of a kind custom rear upper mounts that bolt above the chassis. Eye-to-Eye bracket: A thick wall pipe was reamed out so that the I.D. was 3/4" (Later we found the rear panhard tube, a cut-off from the Slee adjuster, is the correct size). The tube was cut to 1.5" long. It was welded to the above-described U bracket, so that the holes axis are at 90 deg to each other. Shock Bushings Bilstein provides heim joints on their shocks. We decided to use urethane bushing on the bottom shock mounts and keep the heim at the top. Some of the reasoning was that the heim joints can be noisy and with water, dirt and mud so prevalent at the bottom of the shock it seems sensible to use the urethane. Time will tell. The urethane bushing has a 12mm ID steel sleeve, which needs to be reamed to 1/2". The urethane joints fit perfectly in the new brackets, the heim joints are 5/8" wide and the space in the new shock brackets is 1-5/8", so, two 1/2" spacer bushings were cut to fill up the space. Bronze bushings used as spacers would do just fine. Urethane bushings: http://www.offroadwarehouse.com/Stor...p!ProdID!15917 <http://www.offroadwarehouse.com/Store_ViewProdDetail.asp!ProdID!15917> (This link is for a Fox shock, call for the Bilstein version.) Shock Installation 1) Both the front inner fenders were cut out with a 3" hole saw to allow for the reservoir hose clearance. A plywood template was used to locate and drill the hole. 2) The shocks were compressed and wired in the closed position. 3) Brackets were installed on the shocks, along with the urethane bushings and spacer bushings. 4) Install a shock and locate and install the reservoir on the shock. Check for hose and reservoir for clearances. With the reservoir on shock, the hose can be adjusted by twisting the reservoir. Conclusion There is none. With the truck flexed, the rear shocks were at the extension and compression limits. Lowered bump stops and limit straps will be required, if wheeling without the rear sway bars. In the next few weeks bump stops designs will be looked at. The first real test will be this coming up weekend to the East Mojave, but I think it will take quite a few trips and various trail conditions to reach a conclusion. I would like thank to Dale for lending a helping hand. Installation photos will be here and added to in the next few days: http://www.flickr.com/photos/80_on_i...7600184098497/ |
#12 |
James , I Really appreciate all the impressive work you and the "crew" have put into this. Thanks for posting all the details and bringing all this "new $hit to light"
#13 |
tlcwagons.org
LOL
the dude abides... just don't spill the beverage, man Here is a good pic of full stuffage w/o bumpstop drops- tire contacts wheelwell/frame rail. It will need about 4-6" bumpstop extension. ![]() almost forgot to mention we are running Hanna Quality 1.0 beta version Caster Correction Plates
#14 |
Nice setup. I considered the 7100s from eShocks but don't have the $$$ with the wife wanting to buy a house this year. A couple notes though...
You should consider replacing those plain nuts and split washers for metal lock nuts or even Ny-loks. I would never trust split washers w/ plain nuts on something that is prone to high vibration. They might help the thread engagement too it not a slightly longer bolt would help. Dumb question; I see you have the adjustable panhard, is the axle centered? Have you considered 1" or 1.5" wheel spacers? Try a set on the rear and retest. If it works add them to the front. There is no sense adding huge bump stops for only a little rubbing at full stuff. In the 1st post, 2nd pic it appears there is room outboard that spacers may help you out. If it works you might only need a 3" bump stop spacer. Of course this is all dependent on how much travel you have left on the rear shocks. __________________ 1994 80 - Some stuff Tornado Alley Cruisers - TAC Those who can, do; those who can't, criticize. |
#15 |
Nice work. Those are good looking shocks. I've always liked the bilsteins. I had 5100's on my first minitruck and 5150s with the piggyback reservioron my last minitruck and absolutely love them. I wish I could afford some 7100s for my 80, but it would be overkill right now since it's main duty is my wifes daily driver.
Anyway, looks great and good work. __________________ Adam Tolman - '93 FZJ80 M y R O T W http://forum.ih8mud.com/80-series-te...ox-rocket.html |
#16 |
IH8MUD Tour Guide
dumb question alert.....
For bumpstopping; it appears to me that there are two bumpstops, one in the spring and one mounted on the frame. So would you lower both or just the bumpstop on the frame? __________________ 95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 315 Nitto, stainless brake lines, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . . Remember it's a gateway drug, so it will actually lead to "crystal meh". |
#17 |
tlcwagons.org
--Lockwashers- good eye, they are temporary. I didn't get enough of the locknuts (so Rick had some splitwashers on hand) but will be picking up some at the store this week.
--Axles are centered. Actually, Rick pointed out the same thing- so good eye again, we took those pics to show that exact thing I do have room to spacer out the wheel and stuff some more but I don't want to use them. Dropping the frame bumpstop will be insurance for the shock... at that point, I think we had about 2" left on the shock? gotta double check that. CJ, I plan on the frame bumpstops, not the one inside the coil. I'm not sure why there are 2... |
#18 | |
I hear ya there. Kind of silly to be redundant in the bump stop dept. especially on the front. The fronts could be spares for the rear in a pinch. Maybe the extra bumps are for those crazy folks down under that travel the bush at 80mph? __________________ 1994 80 - Some stuff Tornado Alley Cruisers - TAC Those who can, do; those who can't, criticize. |
#19 | |
The New Avocado
There is no set standard - shocks are a spring dampener, so ideally they are tuned to the springs as different spring designs and rates require a different amount of dampening (as well as different types of vehicle builds in terms of added weight). That's always been the value of OME - the springs and shocks are designed as a system for the vehicle. The FOR 3.5" kit is much more lightly damped (using 5125's) due to the spring design. You wouldn't put 400/100 in conjunction with those springs. The upper heim is standard on 7100's if somebody hasn't pointed that out... __________________ 1995 FZJ80 - F.O.R. 3.5" lift - 35" trxus MT - 5.29's - Custom SROR Tube Bumpers - De-plasticized - Dented - Dieted |
#20 |
Per the tech support/sales guy(forgot his name) in Cali the 400/100 valving was originally setup for Range Rovers (ie. heavy pig as well). This valving can be had in the 5150 series if you special order your shocks and pay an additional ~$70/shock. The price of the shock and special valving fee ends up real close to 7100s that are rebuildable yadda yadda yadda.
#21 |
tlcwagons.org
7100's have heims standard top & bottom. We popped out the bottoms and replaced w/ bushings.
400/100 is what I would try even w/ OME heavies 7100 rebound/compression are independently tuneable I believe. So you can make it softer/firmer on one end rather than both. Anyway, for the effort of fabbing, I wasn't staying with an emulsion shock. If so, I would just get new OME's. They are cheap, a good shock, and bolt-in. |
#22 |
IH8MUD Junkie
James,
Excellent write up and detail. I'm in the middle of doing a similar set up to what you guys did, (4" Slee's and Bilstein 7100's). I have the springs and weld in adjustable panhards ready to go soon, and then plan on taking flex measurements to see what length shock to go with. I have a few Q's for you; As far as your rear lower eye/eye adapter goes; Was the only reason you went with them because you chose to do the urethane mounts? Otherwise you could mount the 7100 heim joints to the factory mount, right? Or was there any clearence issues with using the stock lower mount? __________________ Jeff 97 FZJ80 Soon to be Rubicon Tested Mother Approved! (Rubithon 08 baby!) 84 4runner SOLD |
#23 |
tlcwagons.org
12" short body. Mike has 14" and it requires an exponential amount of work, but you know Mike's truck! It must conquer and devestate all!!
Rear Lower mount: - heim is too small to fit over the OEM (factory) mount. - If you push out the heim and use a bushing over the OEM mount, the bushing will be too thin and disintegrate. - If you use a metal spacer in lieu of poly, you will have some shock binding and possibly that will damage or stress the shock and/or mount mounting variations- - the mount we came up with (which I think is uber cool ) allows for no shock binding, bushing or heim mount (meaning we could have left a heim in there). And, if we carry 1 front/ 1 rear old shock, stock OME shock can be mounted back in a trail emergency- you can cut off the OEM lower mount post and basically weld an adapter there and slide a bolt thru (like the upper adapter). That is another option. this would allow you to drop the mount location down a few inches if you have a longer shock (LandcruiserPhil did this) *of note- Rick had the foresight to engineer it w/ all the same size bolts in mind. This way, carrying trail spares and fixes are minimal and easy. I really think it is a brilliant, simple tip. -The real difficulty is at the top side w/ hose clearance. So pay careful attention to it and if you come up w/ more ideas there, I think we would really love to hear them. thanks! |
#24 |
tlcwagons.org
