80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 05-15-07, 12:52 AM   #1 (permalink)
rdublin's Avatar
Cat run out of lives?
I have a strong suspicion one or more of my cats has died. Driving home from work today I gradually lost power and the exhaust note disappeared. My wife noted that she usually can hear me pulling up to the house, but not now. Also, the vacuum line on the bottom of the EGR blew off. From what I've read on Mud, these are signs of a failed cat. It did throw a P0420 once when I was in Baja six weeks ago, but it never came back after being cleared. I know I had a crack in the crotch of the Y pipe in the exhaust header, which I had plugged with muffler putty before Baja, but it is now leaking again. As I understand it, that will only throw off the O2 sensors, but I'm guessing if it is causing the truck to run rich it could have overheated the cats with unburned fuel? Are there any other diagnostics I can perform? Note that I am not showing a CEL, though I would have thought if the cat failed it would throw a P0420 again??
Thanks,
Rod
Rod Daebelliehn
Folsom, CA
TLCA #3363
'72 FJ40 "Molly" Stocker
'96 FZJ80 "Ruby" ARB Front, Hannah Sliders, Kaymar Rear , INTI Rack, Factory e-Lockers, Body by Rubicon
rdublin is offline   Reply With Quote
Old 05-15-07, 06:30 AM   #2 (permalink)
fzj80kidpen's Avatar
Plan on getting a new 3 phase cc and be doen with it.
They are tiny compared to the stock 2 phase cc.
___________________________________
FZJ80KIDPEN
96' FZJ80 186K miles
285/75/R16,OME 850/860's,locked,LED's
Homebrew Rear Bumper and sliders, Flareless and Line-X
fzj80kidpen is offline   Reply With Quote
Old 05-15-07, 07:30 AM   #3 (permalink)
rdublin's Avatar
Unfortunately I live in the People's Republic of Kalifornia and the OEM cats are the only legal solution.
Rod Daebelliehn
Folsom, CA
TLCA #3363
Old 05-15-07, 07:50 AM   #4 (permalink)
450,000+ mile club
JohnnyC's Avatar
Is this your dead cat?
I may have found your dead cat....is this it?
JohnnyC is offline   Reply With Quote
Old 05-15-07, 09:32 AM   #5 (permalink)
rdublin's Avatar
Looks about right. I'll have to pull the sliders to be sure!
Rod Daebelliehn
Folsom, CA
TLCA #3363
Old 05-15-07, 09:22 PM   #6 (permalink)
IH8MUD Thread Killer
Koffer's Avatar
Yep sounds like its clogged .
OK here comes the Getto Fab fix .
Drop the rear cat and pull it out . If you cant look thru it its beat if its got some big chunks in it the front one gone too.
Now tie up the rear pipe and take to for a cruise . If you have good power back (other then just sort of loud) you may have gotten lucky and toasted just the rear one .
Heres the Getto part . Knock the middle of the 2nd one and install the shell . then replace both O2s and if the one cats still working you'll not toss a code and may pass smog (in NJ it passes the sniffer and the eye test).
Other then that Mr T and Cdan dogs will eat like kings
Todd
64' FJ40, 86' BJ70, 96' FZJ80 , 66'M416 and a 92' M101CND
Koffer is online now   Reply With Quote
Old 05-16-07, 08:07 AM   #7 (permalink)
rdublin's Avatar
[QUOTE=Koffer;2168885]Yep sounds like its clogged .
.... Heres the Getto part . Knock the middle of the 2nd one and install the shell . then replace both O2s and if the one cats still working you'll not toss a code and may pass smog (in NJ it passes the sniffer and the eye test).
[QUOTE]
Thanks - I'll give that a try Saturday morning.
BTW - I did find that KC Converters carries rebuilds, $175+core for the front and $275+core for the rear. However, when I told them I was in Kalifornia, they said they could still do it, but it would cost more to provide a unit that is CARB certified (they apparently have to pack the cats with more material). The salesperson said they would call the factory to get the "special" price and call me back. Still waiting for that call but I will post the results when I get it.
Rod Daebelliehn
Folsom, CA
TLCA #3363
