04-30-07, 09:21 PM
| | Forum Regular
| removing third member Hello, I need to remove my rear third member from my fj80, factory locker, and I don't have a service manual yet? I am not having luck finding an article on it. Can someone give me some advice or a link for instructions?
thank you |
04-30-07, 10:19 PM
| | Site Addict
| The gist is: - lock the rear locker before you start
- drain rear axle & have cold beverage
- remove both rear axles
- remove rear driveshaft
- disconnect locker wiring and vent tube
- remove locker motor protective cover
- remove all but one nut from the 3rd member
- take brief break, you may need it
- remove last nut and prepare for one heavy lift, if you're doing this on the ground think bench press
- have another cold beverage
Reassemble in reverse order. I don't have my MM handy so I can't tell you the torques or the P/Ns of the seals and gaskets. All in all it's not a difficult job. Remember to clean everything really well before you go back together and have fun.
__________________ 1994 80 - Some stuff
1988 4runner - cute little brown thing affectionately known as "sh*t stain" Those who can, do; those who can't, criticize - Unknown Strive for perfection in everything.
Take the best that exists and make it better.
If it doesn't exist, create it.
Accept nothing nearly right or good enough. Sir Henry Royce Co-founder, Rolls Royce
05-01-07, 09:20 AM
| | 250+ Club
| 8.5 - Slip a floor jack under the third member before you remove that last nut.
__________________ 96 FZJ80 | 97 FZJ80 |
05-01-07, 10:13 AM
| | Forum Lifer
| The third weighs about 75 pounds. Not too bad.
__________________ Dan Kunz
1996 FZJ-80 " AV0CAD0"
2000 UZJ-100 "T0WCAD0"
Member: TLCA, GA Cruisers, Upstate Cruisers
Donate to SAVE TELLICO!
_____________________________ Originally Posted by eventhough:
"apparently I just need to play with it until it feels right... " |
05-02-07, 10:39 AM
| | 250+ Club
| A brass hammer will come in handy in removing the cone washers that hold the axles in. You'll need a axle nut socket as well. Some have used a Dana 60 front hub socket (I think) or you can buy the OEM tool from Dan. rear axle service photos Rear axle service - FF http://forum.ih8mud.com/showthread.p...304#post432304
__________________ '79 FJ40 33" MTRs, 2" OME;' 96 FZJ80 Retro 100% OEM Lockers, CDL, OEM Hand Trottle, OEM Grab Bar, JDM Cooling Fan, OME 851/860, OEM SubTank in process "The monstrous evils of the twentieth century have shown us that the greediest money grubbers are gentle doves compared with money-hating wolves like Lenin, Stalin and Hitler, who in less than three decades killed or maimed nearly a hundred million men, women, and children and brought untold suffering to a large portion of mankind.” Eric Hoffer |
05-05-07, 01:47 AM
| | Forum Regular
| Thanks for all of your input |
05-05-07, 01:29 PM
| | Wrench Bender
| Quote:
Originally Posted by psfpilot 8.5 - Slip a floor jack under the third member before you remove that last nut. |
never found a good way to purch the third on the jack, I Just do it by hand. it is heavy but doable.
__________________ 1988 FJ62 on 33s
1996 LX450 on 33s |
07-22-07, 09:16 PM
| | Forum Regular
| so what happens IF you didnt lock the axle first?
can you still pull it all out.
do you have to take the actuator off before the chunk will come out?
im getting mine read to do some gears.
__________________ 1993 OE F/R lockers, 35 TSL Q78 skinnys , J springs L shocks, self made 2.5" level spacers front, Warn 9.5XP, Safari snorkel. 4.88s ..... should have gone 5.29
