LinkBack (16) Thread Tools Display Modes
Old 02-17-07, 09:29 PM   #61 (permalink)
The quick brown fox .....
Beowulf's Avatar
Originally Posted by rlabair View Post
Will this mod also work on a 96 LX450?
Yes
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
Old 02-17-07, 10:15 PM   #62 (permalink)
rlabair's Avatar
Posted reply in wrong section. This is in regards to CDL mod, Sorry
I've just checked the Slee sites install instructions. They suggest the normal install location to be to the top left area near the hazard switch, that location holds my security switch. Is the connector long enough to reach the bottom of the controls to the left of the rear heater control switch? I guess the real question is, how much play do I have in the wiring?
rlabair is offline   Reply With Quote
Old 02-18-07, 09:02 AM
landtank
This message has been deleted by landtank.
Old 02-24-07, 05:09 PM   #63 (permalink)
Kenso's Avatar
This mod works great on 4runners too, did a friend's switch today on his '96 (the diode came in a 2 pack anyway). Just something to keep in mind if you know any 4runner owners. Probably works on most Toyotas from this era, thought I'd mention my success with it.
95 FZJ80
00 ITR #106
How to customize the startup text on your Scion headunit
My 80
Kenso is offline   Reply With Quote
Old 03-10-07, 11:12 PM   #64 (permalink)
rlabair's Avatar
Followed the thread advice by first securing diodes from Radioshack, pulled the unit, dremeled the tabs, installed the diode, reinstalled and it worked like a charm. Total time about 15 minutes. Excellent mod, thanks for sharing your knowledge and experience!
Old 03-15-07, 05:12 PM   #65 (permalink)
TLCA# 19542
X2.........thanks landtank, assuming you are the inquisitive genius that figured this one out.......mine whent the same as Rlabair's except I spread/sprayed my contacts and springs all over my workbench and had to figure out the puzzle......the tiny black spring from the window lock was a good one ..............works sweet.
"Stupid things, happen to smart people that are affraid to ask stupid questions"
93 FZJ80 Full Load w/lockers, 2.5 OME, #7pin/CDL, Custom Bumper w/M8274, 315 MTZs
78 FJ40 Retired.....never left me, not once.
81LJ, 89JLX, 01Vitara SUZUKI wifemobiles (the only other 4X4 to own)
76 Chevy PU 292 6cyl, Restored w/collector plates
If you find yourself Lost, Stranded or Thirsty in Southern B.C. CONTACT a recovery team.
MARLIN375 is offline   Reply With Quote
Old 03-15-07, 07:23 PM   #66 (permalink)
Rookie2's Avatar
It was actually a joint venture between Raventai and Landtank. If I recall, RT came up with the idea after figuring out the guage was a similar (maybe same) master switch as on some other Toyota's that had the auto up mod. After tinkering with it a bit without success he sent it to Landtank who volunteered to give it a shot. 30 minutes later we had a auto-up mod.
So... nice job guys .
Rookie2
1997 LX-450, Basically stock.
Rookie2 is offline   Reply With Quote
Old 03-15-07, 07:38 PM   #67 (permalink)
ThinkTank Waterboy
landtank's Avatar
Rookie2
Joint idea...he gave me a broken switch and I figured how to make it work.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 03-26-07, 03:13 PM   #68 (permalink)
The auto up Works
Thanks for the great advice, after a lot of contemplation I convinced myself to have a go at this one. I was a bit worried about frying the circuit board I must admit. Done my "97" 80 within 30 mins includes cleaning the contacts, my mate was a bit wary of what i was doing but within 1 min of seeing mine done we started his. I also wanted to add that the resistor I used was 4007 and It worked fine.
A GREAT MOD THANKS FOR THE INFO
Aus 80 is offline   Reply With Quote
Old 05-06-07, 09:48 AM   #69 (permalink)
EricE's Avatar
I just got done doing this to my '94. My circuit board was different than shown but it still worked. I looked for a picture of a diode on the silkscreen side (the side the components are on) but there was none. What I found was a couple of holes drilled through the circuit board. The holes looked like it was meant for a component to go there but none was there. The holes were drilled through so you could look at the traces(solder side) side of the board and find them. I connected my diode to the two pads (traces) where the holes were and pointed the diode toward the middle of the circuit board (line on diode toward the middle). It worked like a charm.
I then took off the rocker switch (promptly lost the circlip as it is really small) and filed down the stops. I was able to use a tiny wire to fashion an acceptable circlip.
A note about trying to get the window to stop in the middle. If you pull the rocker switch to full stops so it is in auto-up or auto-down mode you will not be able to stop the window in the middle. It will go to full extension. If you want the window in the middle you need to wait untill it has reached extension and then give it about 1.5 seconds...the logic in the circuit board then resets and you are now able to control it without it going full up or full down. Once at its stops you can control it either up or down in partials w/o it going into auto mode.
Easy mod. Thanks Lanktank.
'94 1FZ-FE
200K on chassi, 82K on long block, USA, WA
OME medium springs/shocks; Slee Short Bus Front Bumper; Cabinet drawers in back; CarComputer sound system. York OBA.
EricE is offline   Reply With Quote
Old 11-24-07, 03:43 PM   #70 (permalink)
Rookie
Auto-Up Window Mod
20 minutes ago I went out and started the auto up window mod. It all went as described and works great! Thanks! I used a 1N4004 instead of the 1N4001 because I had one (I think the only difference is the reverse voltage 400V vs 50V). I almost pulled the dremel out, but decided to remove the e-clip and use my belt sander to bring the tabs down (I am a lazy bastard). This mod will get used, wish it was easy to do for all of the windows. I do not have kids so I just have to keep my own head out of the way.
I bought Safado's rig, a 1993 FZJ80. Before the cruiser I took out a 4Runner which required a lot of wheel spinning to get up the hills (open diff's and IFS). The setup on these cruisers is so much better.
I do need a mod for the gas mileage, it is truly obscene.
Do the mod. You will be happy you did the mod.
Mike Ohler is offline   Reply With Quote
Old 11-24-07, 04:00 PM   #71 (permalink)
Beowulf's Avatar
Funny that you would bump this thread today. I printed the pictures yesterday and attempted this mod on a similar vintage Toyota-made vehicle (didn't work on that one though )
Removing the 2 tabs on the switch is very simple. You can take a small pair of needle nose pliars, grab the tab, and bend the tab up with a twisting motion, and it will break off cleanly. Takes about 5 seconds.
-B-
Old 11-24-07, 04:05 PM   #72 (permalink)
ThinkTank Waterboy
landtank's Avatar
I did a Camry switch but the diode has to go in a different spot.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 11-24-07, 07:53 PM   #73 (permalink)
Beowulf's Avatar
Maybe I should send you the window control and let you take a look at it. The board looked very, very close to the ones pictured above. It has auto-down so I'm guessing all the solenoid stuff is there. The printed side of the circuit board had an empty spot with what looked like a "missing" diode.
Guess I will take a closer look...
-B-
Old 11-24-07, 08:28 PM   #74 (permalink)
ThinkTank Waterboy
landtank's Avatar
let me know if you want me to look at it. It took me a while to figure out the Camry one as the missing diode wasn't screened on the board like the LC one.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 11-25-07, 03:58 PM   #75 (permalink)
Beowulf's Avatar
Thanks for the offer Rick. I opened it again and found another screened diode location. Soldered another in and it works great. Auto-Up on the daily driver again! Thanks for the hint.
-B-
Old 11-26-07, 02:07 PM   #76 (permalink)
ThinkTank Waterboy
landtank's Avatar
The Camry switch I modded was for the LC, I haven't got around to doing the Camry yet. Thing is I reach for that option all the time. Glad you figured it out.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-03-08, 02:30 PM   #77 (permalink)
LINUS's Avatar
I don't know how my search ended up here, but I'm going to go buy a few diodes tomorrow & do this too!
Now if I can only figure out why my windows craaaaaawwwl up in cold weather, I'll be golden.
'97 Black/Grey - Slee bars & skidplate , ARB , MT-R's , FZJ headgasket club.
LINUS is offline   Reply With Quote
Old 02-03-08, 04:49 PM   #78 (permalink)
Beowulf's Avatar
Many have reported that replacing the rubber guides in the window have helped tremendously. I have bought the part for the DS but have not installed it.
-B-
Old 02-06-08, 10:10 AM   #79 (permalink)
I did this mod - VERY HAPPY with it - THANKS!!
Regards,
Frank
93 80 series 4.5L Twin Cam Petrol with lots of accessories and mods
Check out the Digital Engine Temp Gauge w/Alarm to overcome OEM DEAD SPOT
franku is offline   Reply With Quote
Old 02-08-08, 06:37 PM   #80 (permalink)
NLXTACY's Avatar
TLCA# 19015
Rick...you kick butt!!!
It took me longer to go to the Shack and get the actual diode then it did to do the actual mod. In and out extremely quick. Shocked the hell out of my wife when she came home. Only wish this worked for all the windows. :P
Old 02-22-08, 04:02 AM   #81 (permalink)
joedm's Avatar
Talking woooohooooo!!!
ok, here's my version of this mod...
Here in Oz I guess the switch is just mirrored (on my 1997 LC). Have a look at the pics:
BEFORE:
And AFTER:
The diode is a IN4002.
Thanks a bunch Rick!
joedm is offline   Reply With Quote
Old 04-01-08, 07:08 PM   #82 (permalink)
IH8MUD Junkie
JerseyCruiser's Avatar
TLCA# 17061
Rick,
Awesome mod. for only .99 cents! I just finished, it only took 15 minutes and works great. Thanx for the great contribution to MUD.
George
1993 FZJ80 127,000 OEM rear locker, rear Slee bumper, Hanna Sliders, front ARB, Warn M12K, Lightforce 240's, Snorkel, OME 850/863, BFG AT KO 285’s, CDL with Pin 7 Mod, George's LEDs and more to come!
Gotham City Land Cruisers
JerseyCruiser is offline   Reply With Quote
Old 04-21-08, 08:03 PM   #83 (permalink)
Rookie
just did this took me an hour and 30cents and im no electrician only one thing can we have power to the windows all the time with having the keys out
chado100 is offline   Reply With Quote
Old 04-21-08, 09:55 PM   #84 (permalink)
not an addict
nuclearlemon's Avatar
TLCA# 1431
does anybody else find the auto mod makes them severly disappointed in other vehicles? everytime i get in my ford, i tap the switch and the window just cracks...then i get upset that i have to sit there and hold the button.
"to learn is to teach someone else"
only four cruisers left
nuclearlemon is offline   Reply With Quote
Old 04-21-08, 10:30 PM   #85 (permalink)
shanegtr's Avatar
I done this mod a little while ago after thinking about it for ages. One of the simplest and best mods I've done
shanegtr is offline   Reply With Quote
Old 04-21-08, 11:03 PM   #86 (permalink)
Originally Posted by Beowulf View Post
Many have reporting that replacing the rubber guides in the window have helped tremendously. I have bought the part for the DS but have not installed it.
-B-
I changed the window channels. Works great for me.
Next I try to do Landtanks mod. I sure hope I don't screw it up. Spare parts are scarce here. Maybe I better look for extra switches first.
Kalawang
LC80 Full time AWD
1HD-T 1990 model
4" Lift 33" Yoko Geo MT
Airtec Snorkel
Bullbar 9,000 Warn
PIAA CDL
Kalawang is offline   Reply With Quote
Old 04-22-08, 08:18 AM   #87 (permalink)
Beowulf's Avatar
Don't waste your time. The mod is very easy. Just don't take apart that window lock button no matter how tempting it looks.
-B-
Old 05-23-08, 12:35 PM   #88 (permalink)
thugmusk's Avatar
TLCA# 3842
Completed mine the other day. About 20 minutes. Just learned today the window continues up after ignition is turned off and the key is pulled,,,,gotta love it.
Awesome mod and kudos to landtank.
'87 FJ60 (10/09 - present)
'97 FZJ80 (03/08 - 08/09, crashed)
'83 FJ60 (11/99 - 12/00, sold)
'85 FJ60 (11/98 - 3/08, rusted, dismantled, parted)
'78 FJ40 (03/98 - present)
'76 FJ40 (10/94 - 11/97, stolen, not forgotten)
thugmusk is offline   Reply With Quote
Old 05-23-08, 12:59 PM   #89 (permalink)
Beowulf's Avatar
Just don't open the door before the window gets to the top or the window will stop and you'll have to stick the key back in to complete the up cycle.
I'm repeating, but this is a fun mod. I use it every Saturday morning when I pick up my latte at the Starbucks drive-thru. Yummy. Somehow I can't drink my coffee without thinking about Rick. Is that too much information or ???
-B-
Old 11-23-08, 07:04 PM   #90 (permalink)
acflyguy18's Avatar
For those who were wondering, I can confirm that you can jack up this "unbelievably simple" mod. I didn't read the entire thread and got the diode's and put it together backwards. Fryed part of the board and burned up the auto down diode. Lucky Me... However, I took the extra diode from the package and attached it on the back side like you do for the auto up and it all works. Just wanted to be the first to say I F#$@ed it up.
Dave
acflyguy18 is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/15277-auto-up-window-mod.html
Posted By For Type Date
Offroad 80's • View topic - Drivers window auto up mod This thread Refback 11-14-09 09:51 PM
Offroad 80's • View topic - Drivers window auto up mod This thread Refback 09-01-09 01:33 AM
Ôîðóì ñåòè Toyota4X4.RU -> Ýëåêòðè÷åñêèå ñòåêëîïîäúåìíèêè This thread Refback 07-03-09 12:19 PM
Offroad 80's • View topic - Drivers window auto up mod This thread Refback 07-02-09 05:28 PM
Auto passenger window switch?? - Page 2 - TundraTalk.net - Toyota Tundra Discussion Forum This thread Pingback 05-12-09 11:24 PM
Outer Limits 4x4 Board :: View topic - 100 series Sahara Electric Window Switches This thread Refback 11-07-08 01:36 PM
Outer Limits 4x4 Board :: View topic - 80 series auto up electric windows This thread Refback 05-18-08 03:38 AM
Offroad 80's :: View topic - Drivers window auto up mod This thread Refback 04-01-08 07:35 AM
keeping up with the Mall Cruiser's - Rising Sun Member Forums This thread Refback 03-21-08 11:08 PM
fortunerclub.net.ph :: View topic - Auto up/down switch This thread Refback 03-17-08 12:15 AM
Outer Limits 4x4 Board :: View topic - 80 series auto up electric windows This thread Refback 03-13-08 05:47 AM
Ptarmigan mods - 1995 FZJ80 - Page 14 - Rising Sun Member Forums This thread Refback 02-17-08 11:58 PM
Offroad 80's :: View topic - Drivers window auto up mod This thread Refback 01-09-08 01:35 PM
Toyota4X4.RU -> This thread Refback 01-06-08 03:35 PM
Outer Limits 4x4 Board :: View topic - 80 series auto up electric windows This thread Refback 12-30-07 12:33 AM
Offroad 80's :: View topic - Drivers window auto up mod This thread Refback 12-18-07 08:39 PM
