04-25-07, 12:00 PM
| | 250+ Club
| My LC has turned into Christine....Help! ***Emergency is over, but I still need advice, thanks!***
My wife just called and reported that she was driving in the neighborhood. All the lights on the dash came on, she pulled over and shut off the engine. She said it didn't shut off when she turned the key. She turned the key and drove it the 200 yards in to he school parking lot and shut it off. the engine stopped, but she could still hear the fan. She opened the hood and said that the engine was not running but the belts were spinning and so was the fan. Impossible???? What the heck? Fan clutch? I'm going home in a little bit to check it out, but this is weird!
__________________ "That was the best trip EVER!" - most commonly heard phrase from the back seat since getting the 80
-White 95 FZJ80 | Specs: CDL, OME 2.5'' Med lift, Nitto Terra Grapplers 285/75R16
-Green '94 | Locked and stock...Sold!
-Discovering the West one trail at a time.
Reason: Quick update
04-25-07, 12:03 PM
| | Forum Lifer
| YOu better hurry, your starter contacts are stuck and at the very least you will have a fried starter and battery, worst case a burned up truck. Tell her to start it and shut if off repeatedly until it quits making noise.
__________________ No problem, I'll just tow the pig to Salt Lake on a UHAUL trailer......
95 T100, beater edition (vacationing in Idaho)
97 Land Cruiser, Collectors Edition
01 Sequoia Limited
02 Camry, Commuter Chariot Extraordinaire
"A vehicle's capabilities are inseparably linked to the mental instability of the driver" |
04-25-07, 12:04 PM
| | Forum Lifer
| Quote:
Originally Posted by MDarius My wife just called and reported that she was driving in the neighborhood. All the lights on the dash came on, she pulled over and shut off the engine. She said it didn't shut off when she turned the key. She turned the key and drove it the 200 yards in to he school parking lot and shut it off. the engine stopped, but she could still hear the fan. She opened the hood and said that the engine was not running but the belts were spinning and so was the fan. Impossible???? What the heck? Fan clutch? I'm going home in a little bit to check it out, but this is weird! | The starter solenoid contacts stuck, remove a battery cable, NOW! Can cause a fire!
__________________ Kevin Patterson '96 LX450 '84 4x4 Mini '73 FJ40 Copper State Cruisers #007
"We have come to the conclusion that we can run our car over any road that a man can take a team of horses and a wagon, providing we can get traction." Dr. Horatio Nelson Jackson, 1903 |
04-25-07, 12:13 PM
| | Forum Lifer
| Quote:
Originally Posted by Tools R Us The starter solenoid contacts stuck, remove a battery cable, NOW! Can cause a fire!  | Yup ^ x2 DISCONNECT the battery NOW!!! or the (-) negative battery terminal. |
04-25-07, 12:18 PM
| | 250+ Club
| Whew! Fortunately she did that. She found a wrench I keep in the back for emergencies and took care of it. Good girl!
New starter from CDan then I suppose.
-Discovering the West one trail at a time. |
04-25-07, 12:20 PM
| | 250+ Club
| You guys rock by the way! Thanks for the fast responses! I'm going home now to take care of things. Thanks!
Reason: left comment off.
04-25-07, 12:29 PM
| | Forum Lifer
| Depending on how long it ran, if it's not burned up, you can probably just replace the solenoid contacts and plunger.
04-25-07, 12:49 PM
| | 250+ Club
| Quote:
Originally Posted by Tools R Us Depending on how long it ran, if it's not burned up, you can probably just replace the solenoid contacts and plunger. | Thanks, that was my next question. I am home now and stopped off to check it out. My brand new belts show that they were running a little hot, but they are OK. She says that with the engine running it probably ran 3 minutes like that. With the engine off it probably ran another 1-2 minutes. Recognizing she was in panic mode, I'll give her a couple more minutes. So, let's say 5-7 minutes. What do you think? Just rebuild it, or buy rebuilt from CDan?
So, did you mean 'Solenoid contacts and plunger', or did you mean, 'Solenoid, contacts, and plunger.'?
If I need to replace the solenoid I may as well just get a new starter. If it's just the contacts I can do the rebuild. What say ye?
More info: She disconnected the negative cables from the battery clamp. When I touch the heavy gauge cable to the negative post, nothing happens. When I touch just the smaller cable to the post there is a clicking on the wheel well. There must be solenoid on the wheel well also? This is with the key off.
04-25-07, 12:50 PM
| | 250+ Club
| Good luck. Hope there was not too much damage. Is this why changing the starter contacts and plunger a PM job and to avoid this situation?
__________________ James
97 FZJ80, "La Mula," ARB, HIDs, Tire Carrier, Sliders, OME 850J/863 springs, L shocks, 295/75/R16 ATs, Slee TC Skid Plate, Rear Storage, CB, LEDs, SS Brake Lines, Rear work lights, HIRs, CDL pin 7
01 325I Sport Packaged DD http://bohemianjsr.blogspot.com/ |
04-25-07, 12:57 PM
#10 (permalink)
| | 250+ Club
| I only had a no start 4 times over about 3 or 4 days. Very little warning. So, yeah, probably a good PM idea. A lot of posters report that they have been having it for months, or at least more than 4 times, which made me think I had a little time to troubleshoot the symptoms. A no start could be solenoid, starter contacts, alarm interference, Neutral position sensor (wrong name), etc. I was going to troubleshoot this weekend. I guess I'll be working on it tonight or tomorrow instead.
04-25-07, 01:01 PM
#11 (permalink)
| | Site Addict
| WOW Quote:
Originally Posted by MDarius Whew! Fortunately she did that. She found a wrench I keep in the back for emergencies and took care of it. Good girl!
New starter from CDan then I suppose. | My wife doesn't even know what a wrench is, let alone how to use it. You got a good woman there!
__________________ 4 Chevys and a Yota
1994 4X4 Silverado pickup
2000 S-10 pickup
2000 Monte Carlo SS
2003 Trailblazer LTZ
and a little old 1974 FJ-40 |
04-25-07, 01:07 PM
#12 (permalink)
| | 250+ Club
| YES I DO! And I already let her know it! From now on I think I'll keep it in the battery tray though.
Anybody want to chime on whether they think I should get an new starter or rebuild this one?
04-25-07, 02:02 PM
#13 (permalink)
| | Forum Lifer
| Quote:
Originally Posted by MDarius Thanks, that was my next question. I am home now and stopped off to check it out. My brand new belts show that they were running a little hot, but they are OK. She says that with the engine running it probably ran 3 minutes like that. With the engine off it probably ran another 1-2 minutes. Recognizing she was in panic mode, I'll give her a couple more minutes. So, let's say 5-7 minutes. What do you think? Just rebuild it, or buy rebuilt from CDan?
... | My test would be, put the cable on lightly, start the motor, immediately turn off and disconnect the cable if needed, if it sticks again. If the starter turns, starts the motor without issue your probably good to go with just contacts and plunger. Call C-Dan, he will set you up with the proper contacts and plunger.
Other than the above test DO NOT drive the truck until it's repaired.
04-25-07, 02:08 PM
#14 (permalink)
| | fatherofdaughterofromer
| Maybe the shaman knew you were going to start that poll
__________________ Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon |
04-25-07, 02:11 PM
#15 (permalink)
| | Site Addict
Join Date: Aug 2004 Location: Queens, NYC and sometimes Orlando, FL
| Yikes!!
That's it, I'm hearing way too many horror stories about run away starters
Tomorrow I'm gunna invest in a quick battery shut off switch |
04-25-07, 02:13 PM
#16 (permalink)
| | Forum Lifer
| Quote:
Tomorrow I'm gunna invest in a quick battery shut off switch  | Or simply replace the contacts?
04-25-07, 02:15 PM
#17 (permalink)
| | 250+ Club
| DOH!!!
04-25-07, 02:25 PM
#18 (permalink)
| | Forum Lifer
| Kragen/schucks/checker has a kit in stock for like 8 bucks with the contacts and plunger. I've used it on my 4runner and both 80s without issue........
01 Sequoia Limited
04-25-07, 02:28 PM
#19 (permalink)
| | Site Addict
| Quote:
Originally Posted by Tools R Us Or simply replace the contacts?  |
I've read a few posts on this happening even after the contacts were replaced (could be due bad installs), so I'm just gunna play it safe and get an emergency cutoff anyways |
04-25-07, 02:31 PM
#20 (permalink)
| | 250+ Club
| Quote:
Originally Posted by KliersLC Kragen/schucks/checker has a kit in stock for like 8 bucks with the contacts and plunger. I've used it on my 4runner and both 80s without issue........ | Hmmm...might be worth fixing the old one to keep as a trail spare and replace the problem starter with the new one from CDan.
