80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 04-23-07, 11:48 AM   #1 (permalink)
MDarius's Avatar
Starter or Park Paul?
So I've searched on starter contacts thinking that was my problem, but it doesn't sound like it is.
Occasionally when I start the truck all the lights go on, you can hear the fuel pump kick in and the fan work, but no start. No clicking, grinding, or even an attempt. Turn the key again and maybe you get the same result and maybe the truck will fire right up without hesitation or problems. It behaves just like you had it in Drive instead of Park. I have tried moving the shifter back and forth, starting in N instead of P and I get the same intermittent results. Inconclusive, but it doesn't appear that 'resetting' to make sure it knows it's in Park has anything to do with it.
I recently pressure washed the undercarriage...I know a lot of people say this is bad, but I was paying for service to be done on the front end and didn't want to pay labor time for their tech to knock off mud and grease.
Any thoughts?
"That was the best trip EVER!" - most commonly heard phrase from the back seat since getting the 80
-White 95 FZJ80 | Specs: CDL, OME 2.5'' Med lift, Nitto Terra Grapplers 285/75R16
-Green '94 | Locked and stock...Sold!
-Discovering the West one trail at a time.
MDarius is offline   Reply With Quote
Old 04-23-07, 12:22 PM   #2 (permalink)
jjhancock's Avatar
I had similar problems. I ordered new starter contacts and plunger from CDan and have had no problems since. It seems as if not everyone has the exact same symptoms but that the remedy is the same in most cases.
jjhancock is offline   Reply With Quote
Old 04-23-07, 01:08 PM   #3 (permalink)
DanKunz's Avatar
As stated above....starter issue or ignition switch. I would start with checking the contacts to the starter.
Dan Kunz
1996 FZJ-80 "AV0CAD0"
2000 UZJ-100 "T0WCAD0"
Member: TLCA, GA Cruisers, Upstate Cruisers
Donate to SAVE TELLICO!
_____________________________
Originally Posted by eventhough:
"apparently I just need to play with it until it feels right... "
DanKunz is offline   Reply With Quote
Old 04-23-07, 01:23 PM   #4 (permalink)
MDarius's Avatar
Cool. Thanks.
Old 04-23-07, 04:13 PM   #5 (permalink)
The quick brown fox .....
Beowulf's Avatar
At least one other person found that he needed a new ignition switch.... at least I think that was what ended up being the problem. Do a search and let us know what you find. I know he said the starter was OK... several times... so he went with the ignition switch.
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
Beowulf is online now   Reply With Quote
Old 04-24-07, 11:15 AM   #6 (permalink)
MDarius's Avatar
Thanks B. I just spent the last hour+ reading all the pages on his posts (Roncruiser). The ignition switch did not resolve the problem ultimately. He purchased a new starter from CDan and 2 weeks later had not had the problem. I posted to see how it is going now.
Mine is a little different in that there is no audible 'CLICK' from the starter. After reading all those posts I'm leaning towards neutral kill switch...I'm also leaning towards a headache! I power washed the undercarriage and I'm thinking I may have shorted something out on that kill switch.
Old 04-24-07, 11:29 AM   #7 (permalink)
roncruiser's Avatar
My problem was rthat I began by replacing the old starter with a used starter. The used starter turned out to be bad too which led to replacing the ignition switch. In the end, it was the solenoid that turned out to be bad in both starters. What luck
The good thing is that I learned so much about my ignition system !!!
1994 1FZJ80 - Locked;CDL Switch
Engine: Rotella 5w40; Tranny:Mobil1 Synthetic
Bilsteins:B46-1477 FRONT; B46-1478 REAR
Bridestone Dueler A/T Revo's 285/75/16 on LX450 rims (2nd set)
OME:Springs 850 FRONT/863 REAR
Hanna Quality Rear Bumper
roncruiser is offline   Reply With Quote
Old 04-24-07, 03:13 PM   #8 (permalink)
MDarius's Avatar
Yes you did, as did the rest of Mud! Holy cow that was quite the thread! But, I think if it were summarized it would make for a great FAQ / Tech write up.
