LinkBack (4) Thread Tools Display Modes
Old 04-13-07, 11:34 AM   4 links from elsewhere to this Post. Click to view. #1 (permalink)
Cool Intercooler for TRD Supercharger
2 posts in one day!! new record..
I wanted to install an intercooler on my supercharger but i did not want to.
1. block the air into my radiator, so that I over heat.
2. install 5 feet of tubing and have a ton of lag.
3. position the intercooler where it could get hurt.
So I purchased a 3" thick, bar and plate intercooler with 3" inch inlet and outlet, the size is like 14 x 16 (actual size of the cooling area not the including the inlet or outlet).
I purchased a hood scoop from a Subaru WRX (not STI) and installed it in the hood and ducted it over the intercooler, on the inter cooler I mad a gasket that seals the hood scoop to the intercooler and forces the air through it.
The inter cooler in mounted over the a very small section of the head, but mostly over the open area over the exhaust manifold.
The intercooler is plumbed with 3 inch mandral pipe from the supercharger to the intercooler and has a silicone sleeve between the intercooler and a flange on the intake manifold.
I know you are wondering how it works???
Well, I can say that it has made the biggest difference in performance, in 50-60 degree weather I can run the engine hard for any amount of time, stop and put my hand on the cooler and it is cold to the touch!!!
We drove to Moab a week ago from Orem and with stock gearing, 35 inch tires and loaded with 4 people and all our gear, we made it over soldier summit in overdrive at 70 plus without effort, I am very impressed, I had not even hopped for it to work this well.. On the way back from Moab, the really steep hill between green river and price, I was doing almost 80 in overdrive...
Sorry to the members that have no idea of the hill I am talking about, but for comparison my stock 80 would struggle to hold 50 over soldier summit and the other hill mentioned.
later
96 LX450, Factory Lockers, TRD Supercharger with Intercooler, 5 inch (ish) lift, 35x12.50 R17 tires..
blarsen is offline   Reply With Quote
Old 04-13-07, 11:48 AM   #2 (permalink)
MTNRAT's Avatar
Whoa, More pics and diagrams and a write up please.
97 lx450, factory lockers, slee springs, 315/75R16 MTR,s,4.88s, supercharged,ARB, m12000, slee rear bumper and tire carrier, slee sliders,
MTNRAT is offline   Reply With Quote
Old 04-13-07, 12:58 PM   #3 (permalink)
MTNRAT
Well at least you're not asking for much.. (joke)
I will see what I can do, but just moving all the vacuum lines and other stuff out from where the intercooler is mounted took about 10 hours.. I have almost 30 hours into the whole hood scoop/intercooler install.. the hardest part by far was the 3" pipe from the supercharger to the intercooler.. I had to cut the end off the SC exit pipe in order to get the 3" pipe in.. plus the radius on the pipe bend going back to the intercooler is only about 2 inches, so I had to custom make that radius.. (the tightest I could find was 3" inch pipe with a 3" radius U bend)..
later Bret
Old 04-13-07, 01:13 PM   #4 (permalink)
Parts Geek, M1 Mechanic
cruiserdan's Avatar
TLCA# 11332
What about heat-soak when you are moving slow off-road?
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
Old 04-13-07, 01:23 PM   #5 (permalink)
airlaird's Avatar
Absolutely, get more closer pics please...no one has ever thought of that routing as far as I know. Can you give us a part number and where you bought the intercooler?
airlaird
airlaird is offline   Reply With Quote
Old 04-13-07, 01:27 PM   #6 (permalink)
C-Dan
I am not very worried about heat soak on the trail (it will happen). The intercooler will not get any hotter than the stock supercharger setup (worst case) at very slow trail speeds, and I had no problems with heat before (knocking, overheating, etc). I have read a ton on air flow and intercoolers and it seems that 20mph is enough air to cool the intercooler and remove the max BTU's.. the crucial part is making the air move through the intercooler and having NO way for the air to go around it and lessoning the effect of the potential air you have. Having said that.. i have enough room for a 7"diameter, high performance fan on top of the intercooler and have a setup in mind that would put a heat sensor in the outlet of the IC to turn the fan on at a given temperature to cool the charge.. But the main reason for the IC is for driving to and from the trail, vacations and adventures with the family, and it works perfectly for that..
later
Bret
Old 04-13-07, 01:33 PM   #7 (permalink)
Smile
Airlaird
I will hunt around for the part number for the IC, I purchased it a year ago and since moved to a new house.. I may have bookmarked the site? (I hope)
I am sorry that I don't have all the info on my install, I must admit that I have had it done for a month and have not wanted to get flamed from people who have nothing better to do than give people crap.. I am happy to say that all the questions have been very good and i will see what I can do to provide the information to those interested..
thanks
Bret
Old 04-13-07, 01:41 PM   #8 (permalink)
It is a very good intercooler for the price.. (you can pay lots more)
This is where is purchased the intercooler:
http://www.justjap.com/parts_nintercoolers.htm
and this is the closest one to the size I used:
Cooling-Pro Universal Intercooler - Small Type
Bar and plate - 280 x 300 x 76mm - 3 Inch outlets
$149...
later
Old 04-13-07, 01:45 PM   #9 (permalink)
ThinkTank Waterboy
landtank's Avatar
I like it.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 04-13-07, 01:53 PM   #10 (permalink)
Poseidon, look at me
NaterGator's Avatar
TLCA# 18767
Cool idea, but like Dan said, what about heat soak when you are moving slow? Did you somehow protect from exhaust heat rising up? This would be wicked if you could shield it from below and duct the bottom so that the air dumps out into the fender to keep under hood pressure correct.
'96 LX450, 33" Revos, OME lifted, etc, etc
Love the life you live, live the life you love. -Bob Marley
Selfishness is not living as one wishes to live, it is asking others to live as one wishes to live. -Oscar Wilde
Right-click image transloading made blindingly easy.
Originally Posted by fsusteve View Post
What are you talking about bro, I'm a long time gator fan.......
WFC: 0473-9763-9112
NaterGator is offline   Reply With Quote
Old 04-13-07, 01:55 PM   #11 (permalink)
The quick brown fox .....
Beowulf's Avatar
Bret,
You should never let the "fear of critique" stop you from posting anything, especially a solution as creative as this one. Some view questions as flaming and some get defensive but, for the most part, those here in the 80-section will appreciate your work and your ingenuity.
Numbers and data also make us happy. How about a 4-wheel dyno run?
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
Old 04-13-07, 01:57 PM   #12 (permalink)
airlaird's Avatar
Thanks Bret
Bret I appreciate it..don't be timid about posting your install, heck you enlightened me with how you did your install, and it looks looks great. Try to post some over head views of the set up please.
airlaird
Old 04-13-07, 02:06 PM   #13 (permalink)
Doc
Utarded
Doc's Avatar
TLCA# 17266
Garage
I'm wondering if you wrapped your exhaust header with that heat tape? I hear it's really effective. Would also help reduce potential heat soak in the intercooler.
Eric, Utah operations commander- Tall Corn Cruisers.
1993 Landcruiser, 197K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
Doc is offline   Reply With Quote
Old 04-13-07, 02:49 PM   #14 (permalink)
mot
I ruin surprises.
mot's Avatar
Good stuff!
Thanks for sharing, and would like to hear/see more about it myself as well!
Mot
mot is offline   Reply With Quote
Old 04-13-07, 02:52 PM   #15 (permalink)
I had planned to make a exhaust vent for the bottom of the IC and dump it down the fire wall and out next to the exhaust... But, I soon found out that with a 3" core the extra room under the IC and the head (just on the far right side of the IC) runs out rally fast.. so if I would have made a pan for it I could have potentially restricted the flow through part of the IC. I started thinking about the Head gasket and how it always go's out by #6, and if I left the IC without a pan and ducting it would direct cooler air directly on that part of the motor and could help the HG in the long run to stay cool and last longer.
I have not wrapped the exhaust with the heat wrap, but I do have the stock exhaust shield in place. I did figure that I could use some if it became a problem.. So far it works perfectly, MUCH better than i could have wished for, the cool air flows very easy through the ic and just blows cool air onto the exhaust and out under the truck.
Bret
Old 04-13-07, 03:00 PM   #16 (permalink)
fzjchase's Avatar
Reminds me of the STi setup with a top mount intercooler. Except that it's a flat four and turbo-charged...
40th FZJ80 #3333 - 188k miles, 285 BFG AT's, & etc.
Look KG481 SL - DA, Custom Wheels, & a lot of miles.
fzjchase is offline   Reply With Quote
Old 04-13-07, 03:02 PM   #17 (permalink)
As for the flaming part, Its really hard when you (me) have been planning this IC install for over a year, reading everything I could from the Tuner Car guys (they know IC's) and investing a lot of time and money to make something as good as i could, and to have someone who may be having a bad day glance at the post and rip me a new one... I fully understand that it happens VERY little on IH8MUD (great people). But in the end, trying to get things across in this kind of form is difficult at best and a disaster at worst, most of the time i just choose to shut my mouth (see keyboard) and glean as much information from reading the posts as i can, i comment very little and post almost never.
Bret
Old 04-13-07, 03:56 PM   #18 (permalink)
Rainy Day FZJ's Avatar
Looks wonderful, any idea of the rough cost?
95 FZJ80 -sold
2004 Dodge 2500 Cummins tow rig
1997 BMW M3 sedan
2005 21' Rampage toy hauler to carry the Honda ATV's
Rainy Day FZJ is offline   Reply With Quote
Old 04-13-07, 03:57 PM   #19 (permalink)
Trunk Monkey's Avatar
TLCA# 11251
I like, a lot. The intercooler on my truck uses a radiator placed in front of the main rad. and I've never liked that set up. But, on an interesting note, we shot some before/after intercooler temps on mine and saw about a 20 degree drop. Much more than I thought it would be.
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
Join or renew your TLCA membership - CLICK HERE
Trunk Monkey is offline   Reply With Quote
Old 04-13-07, 04:12 PM   #20 (permalink)
Cost:
Intercooler $150
Mandrel pipe $100
Silicone Elbow and 2 sleeves $50
vacuum lines $5
WRX Hood Scoop (used) $100
Sheet metal (for ducting scoop) $10
Ultra Dense Foam/silicone gasket for top of IC $45 (Had to make it my self)
30 hours install time, Priceless!! (and 1 year of Orem City's Internet time)
later Bret
Old 04-13-07, 04:23 PM   #21 (permalink)
fatherofdaughterofromer
Romer's Avatar
TLCA# 13968
Garage
Nice write-up. Do you have part numbers and web sites to order the stuff from?
A good diagram and some more pics would be great.
Think about if you were a reader is there enough for you to do the mod yourself.
Excellent thread. You have done what a lot of folks have talked about and wanted (and still do) to do themselves (Including me )
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Romer is online now   Reply With Quote
Old 04-13-07, 04:46 PM   #22 (permalink)
Romer
Thanks a lot, I will work on some illustrations and part numbers (or links) to the parts needed, the really sad thing is that i didn't take picture as i put it together, I get working on things and find it hard to stop even for food.
As for the intercooler in front of your stock radiator, I learned that putting one in front of the other makes them both function less than they should, it blocks the air to the LC Rad and in turn makes a dead air space between them and stops the air from going through the IC like it could. the front mount IC is very efficient if you can mount it so that it is not in front of you LC Rad and you have a way to Duct the air so that it must go through the IC not around it, the only place I could do this is where the Factory winch would mount, and then place a scoop on top of the bumper to catch the air and then duct it through the IC... It turned out to be a lot of work and I choose the top mount..
later
Old 04-13-07, 04:50 PM   #23 (permalink)
Beowulf's Avatar
How is access for maintenance of things like the spark plugs, valve cover gasket, PCV, etc?
-B-
Old 04-13-07, 04:56 PM   #24 (permalink)
Access?
All that is needed to remove the intercooler is to loosen 2 stainless clamp (crap I forgot those in the price!!) and lift it out. takes 30 seconds.
Good question..
PS. I am leaving work and won't be back on Ih8mud until Monday..
later and thanks
Bret
Old 04-13-07, 06:15 PM   #25 (permalink)
Cattledog's Avatar
Great work!
96 lx 450 stock, with 285's and R.B. MAF housing.
2006 Sienna LE 8 passanger, 3 kids and Room to spare!
Cattledog is offline   Reply With Quote
Old 04-13-07, 07:47 PM   #26 (permalink)
clarkrw3's Avatar
TLCA# 15560
Great work...If I had thought of this I would have picked up a supercharger before they were discontinued.
'96 LX 450 67K locked, ARB Bull Bar, Slee 6", Slee step sliders, Slee rear tire carrier, slee skid, CDL, 315/75-16 MTR's, etc. ROTW
'07 FJ Cruiser locked, 285/70-17 MTR's
Copper State Cruisers #38
TLCA #15560
Rob Clark
clarkrw3 is offline   Reply With Quote
Old 04-14-07, 08:43 PM   #27 (permalink)
Kenso's Avatar
I've done nothing but think about this very same mod since I bought my s/c kit. Seems like an ideal solution. The only thing I was concerned about was hacking up the hood for the scoop (and how it might look). Yours seems to blend into the look of the truck fairly well. I'm really glad you posted this, gives me the motivation to attempt something similar myself. If you get a chance, how about some more pics, especially of the hood/front end from a further distance away. I'd like to get a better idea of how I might like that WRX scoop.
95 FZJ80
00 ITR #106
How to customize the startup text on your Scion headunit
My 80
Kenso is offline   Reply With Quote
Old 04-16-07, 03:33 PM   #28 (permalink)
cool build. could be utilized with a turbo too.
the heat sink thing isn't an issue. the air going into motor probably isn't much cooler while wheeling but wouldn't be any hotter than without one either. and at least an intercooler in this location isn't in front of the motor when wheeling like mine.
one may argue that this intercooler is too small for our motor but If this intercooler can flow a 2.5l motor to 10+ psi at 7000 rpms it could arguably flow our 4.5l at 6psi and 5000rpms. do you have boost guage numbers taken at the intake manifold pre and post intercooler? this would give an idea. does the eaton m90 on the cruiser application take the bypass pressure signal from supercharger itself or from the intake manifold? if your setup is taking the pressure signal at the supercharger (pre-intercooler) you may want to take a line from the intake manifold itself (post intercooler)so as to make sure your intake is seeing maximum boost and not leaching off a psi or two due to the resistance of your intercooler.
97lx450
1 tons and 42's
4" slee coils, sliders, bumpers, 3" exhaust, custom turbo, HG pm/Valve job/seals, sweet custom skid plate, Sleeoffroad parts, Buys oe parts from Cruiser Dan
my build
http://forum.ih8mud.com/hardcore-cor...j80-build.html
98 100 series. rear locker.
2008 6.7L dodge 2500 quad cab
ezgo electric golf cart crawler build pend....
2002 porsche C4S
Dusty is offline   Reply With Quote
Old 04-17-07, 11:12 AM   #29 (permalink)
knorrena's Avatar
Nice job. I recently test drove an Acura RDX and it had a similar IC setup and my brain started wheeling away, then you post yours. I am sold on the idea and now you have me looking up ICs. Do you recall how much room there is between the hood and the top of the valve cover? I am going to guess about 4.5".
Karl
1997 LX 450 202000kms, locked, 285 Revos, Supercharged.
2004 lx 470 61000kms stock
You cant kill yourself on a pogostick. (Harry Parker, world famous geostatistician)
knorrena is offline   Reply With Quote
Old 04-17-07, 12:08 PM   #30 (permalink)
4.5 inches would be really close... good luck
Bret
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/149478-intercooler-trd-supercharger.html
Posted By For Type Date
Untitled document This thread Refback 11-21-09 08:53 PM
Indice: Archive through This thread Refback 06-01-09 12:39 AM
Indice: Leggenda del toytalebano This thread Refback 05-30-09 05:43 AM
Recommendation on where to get hood cut - Rising Sun Member Forums This thread Refback 07-23-08 11:26 AM
