03-29-07, 09:57 AM
| | Forum Regular
| ABS light on, and I dont care. simple as that. my ABS light is on, and has been for 3 years. I don't care. I hated when the ABS actually worked because they would activate even if i wasn't braking hard. I want to turn off the stupid idiot light. is there a fuse i can pull or something? thanks.
__________________ I'll be sleeping in the back of my pig buggy.
1996 Land Cruiser......Green and very Stock. |
03-29-07, 10:11 AM
| | 250+ Club
| Pull the dash and then pull the bulb out. Search CEL Light Replacement and you should run into a tutorial on how to remove the gauge cluster and pull the lights behind it.
__________________ 1996 LX450. 33" BFG A/T TA KO, TJM T17, OME 2.5 Hvy, Warn X8000i ATΩ |
03-29-07, 12:19 PM
| | 250+ Club
| There's a fuse for all the lights, I believe.
Look on the fuse diagram on the fuses under the hood, and there's probably an ABS.
Just like the one for EFI which turns off my check engine light often.
Whenever I drive on freeways....
__________________ 1994 FZJ80. Stock as hell. Lockers. Slee skid plate. Better speakers + CD player, no flares. Lame. |
03-29-07, 01:27 PM
| | Utarded
| Quote:
Originally Posted by tomatopants There's a fuse for all the lights, I believe.
Look on the fuse diagram on the fuses under the hood, and there's probably an ABS. | The ABS fuse disables ABS, not the ABS light. Pulling the fuse will cause the light to come on (and in this situation, stay on). Either pull the cluster and take the bulb out or stick a piece of black electrical tape over the cluster cover.
__________________ Eric, Utah operations commander- Tall Corn Cruisers.
1993 Landcruiser, 197K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW |
03-29-07, 04:26 PM
| | Forum Regular
| Remove the lower kick panel by the drivers side door under the dash. There you will find the ABS computer. Unplugging it will turn the dash light off and disable ABS.
__________________ First, it was the cruisers. Now, I went and got the nitro racing bug (see avatar). Boy... Is my wife pissed!!!
94 fzj80, factory lockers, 2 1/2" OME, 285's
H2 Recovery Unit
73 fj40, electronic ignition, 4" lift, 31's
Currently, just a driveway ornament |
03-29-07, 06:19 PM
| | 250+ Club
| Quote:
Originally Posted by Doc The ABS fuse disables ABS, not the ABS light. Pulling the fuse will cause the light to come on (and in this situation, stay on). Either pull the cluster and take the bulb out or stick a piece of black electrical tape over the cluster cover. | Well I figure if you pull out the EFI fuse and the check engine light goes off, then if you pull the ABS fuse, the ABS light will go off, while not really solving the problem.
03-29-07, 07:19 PM
| | Site Addict
| I pulled the dash and pulled the ABS light.  No light no worries.
I know about the liability crap posted before. I prefer no ABS.
__________________ 1994 FZJ80, stock, emerald green, 175k
TLCA #14457
LSLC Member TX_TLC ROTW "We will know how long they last when the first one wears out." |
