I see a number of mudders installing OEM auxiliary 13 gallon tanks, as well as aftermarket auxiliary 44 gallon long-range tanks. Both appear to have the downside of sourcing used Aussie dual-filler necks, transfer gas pumps, sub-tank gauges and sub-tank cutover switches.
This 38 gallon tank from Man-a-Fre:
http://www.man-a-fre.com/parts_accessories/fj80lx450longrangereplacementfueltank.htm
appears, at least on the surface, to have the advantage of fitting where the stock 25 gallon tank fits, and reuses all existing parts without having to source (though I realize sourcing may be part of the fun).
What I do not know is:
1) Will this interfere with bolt-on sliders such as Slee's;
2) Does this hang down too low; and
3) Will the existing tank skid plate work.
Does anyone have any experience with this tank?
Thanks!
Description of tank on the Man-a-Fre website: "Finally a high capacity replacement tank for your FJ80/LX450 that does not require the installation of an auxiliary tank, and associated plumbing. This 38 gallon replacement fuel tank mounts where your OEM tank did originally, and re-uses the OEM sending unit, fuel pump, and filler. Made of high quality aluminized steel, and fully baffled and trapped for off-road use.
Will not fit 1990-1992 FJ80 Land Cruiser."
Thanks!
