Old 03-06-07, 09:16 PM   #1 (permalink)
FloridaFJ80's Avatar
3FE Dual Batt Setup and Homemade Rack
For all the 3FE owners here on MUD, I wanted to show you my Dual Batt Setup along with my homemade rack.
Dual Batt Setup:
I had an extra Deep Cycle battery just laying around in the garage (have a boat) and well I decided to make a Dual Batt Setup.
So I went Shopping. I wanted a system to where I would be able to use a battery to run my accessories(10"sub and 500w amp, 12v outlets, fridge, radio, lights, 400w inverter etc) and at the same time have something in reserve for the inevitable dead battery. I didnt want it to be to complicated and easy to use. So I went with the 3 way switch used on boats. I also used a Blue Sea Fuse Panel for my (5) 12v outlets. Each outlet is individually wired with 14 ga wiring. For the main Battery connections to the switch I used 4ga wiring. In between each battery and the switch is a 300 Amp inline fuse. I mounted the secopnd battery in the cargo area right behind the passenger side 2nd row seat.
I will let the pics speak for themselves. I will be upgrading the batteries to an Optima Red top for Battery #1 and an Optima Blue Top Deep Cycle Battery for Battery #2, pretty soon. All in all the system can be done for under $200 not including the batteries.
Frank
1992 FJ80 Semi-Stock
2008 Prado VX - TRD'd
305/70/17 Maxxis Bighorn M/T
TJM 3" Suspension Lift
Safari Rack with Fogs
Factory Digital Inclinometer/Compass
Rear storage system
Dual Battery Setup
On Board Air
FloridaFJ80 is offline   Reply With Quote
Old 03-06-07, 09:25 PM   #2 (permalink)
fatherofdaughterofromer
Romer's Avatar
TLCA# 13968
Garage
Nice write-up. I had your original (pre-install) included in the FAQ. I have added this one to go with it
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Romer is offline   Reply With Quote
Old 03-06-07, 09:32 PM   #3 (permalink)
Safari Rack:
My friend, 80Jay, gave me a set of Publix(grocery Store) Aluminum Shelf racks, which can hold up to 1500lbs. So I took them in and joined them together, I painted them black. I then went to Home Depot and got 2 L shaped 1/8 steel beams. I bolted them up to each end so the racks would not flex. I then ordered some of the quick and easy clamps. and then I joined them to the racks using some 10" steel mending plates that I picked up at Home Depot. and then I bolted them to the rack, and then I mounted it to the rig. Here are the pics.
my 180 lbs along with a full size spare
after wheeling in Naples
Frank
Rear storage system
Dual Battery Setup
On Board Air
Old 03-06-07, 09:47 PM   #4 (permalink)
Special Thanks to 80Jay for hooking me up.... Here are some pics of 80jay in action...
My rig pulling out 80jay out of same spot where I got stuck the nite before.
Frank
Rear storage system
Dual Battery Setup
On Board Air
Old 03-07-07, 07:06 AM   #5 (permalink)
robmir's Avatar
Hi Frank: My only concern would be the rack brackets position. You should put them as close as possible to B and C pillars.
1993 FZJ80, 2" OME, 305/70-16, Auburn Locker, F&R TJM bullbars,Long Range 150 ltr gas tank, 170 Amp alt, 240 amp 3 Battery Isolator & 3 Deep Cycle batt,4 DBA slotted rotors, Carbon/Ceramic pads, SS/Teflon brake hoses, Warn 9000, PIAA 80 Racing,Coil&Shock Dampened Front Seats.Engel 60 Qts Fridge.
robmir is offline   Reply With Quote
Old 03-07-07, 10:21 AM   #6 (permalink)
sseaman's Avatar
?nice work, how much noise does the rack create?
98 4runner 150k
04 Sequoia 85k 4x4 Limited
sseaman is offline   Reply With Quote
Old 03-07-07, 11:53 AM   #7 (permalink)
sseaman - I have not noticed any noise increase whatsoever, even when I ride with the sunroof open.
robmir - thanks for the tip I will be seeing on moving my rack as close to the pillars as possible.
Frank
Rear storage system
Dual Battery Setup
On Board Air
Old 03-07-07, 02:14 PM   #8 (permalink)
80jay's Avatar
TLCA# 18207
all I can say is that we put both the batteries and the rack to the test and it all held up like a charm. Good job with evrything.
1991 Fj80
1987 Fj60
2008 Fj
80jay is offline   Reply With Quote
Old 03-07-07, 05:12 PM   #9 (permalink)
slinger5150's Avatar
If you ever start running alot of accessories and really need the reserve of that second battery, you might want to increase to 0ga. wire between the 2 batteries. I'd imagine that's a decent length run between the 2. You'll lose a bit of juice if the ga. wire is too small.
slinger5150 is offline   Reply With Quote
