80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 03-05-07, 07:47 PM   #1 (permalink)
3FE 9.1:1 c/r pistons
I hate to drag this up.
Resurching verious motor threads I think I have found that no one has mentioned that the beloved 3fe only has a 8.1:1 c/r or compression ratio
are there any 9.1:1 cr pistons availible?
would this be a cheap and easy fix, and get the 3fe in the ball park of modern motors?
Main's shmain's it will live with this c/r.
It should also still run on low test.
Any one running any thing like this?
I have searched to no evale
Any thoughts?
tntoyota is offline   Reply With Quote
Old 03-05-07, 09:13 PM   #2 (permalink)
dd113's Avatar
The migthy 3FE is what it is. No aftm hi compression pistons that I have seen but there are total seal rings out there.
It actually is a fantastic motor and the culmanation of 40+ years of work.
David Dearborn
www.urbanlandcruisers.com
Foreign Minister for life of the White Trash of the Elwood Chapter.
Visit our E bay store:
http://stores.ebay.com/Land-Cruiser-Stuff
I collect Hello Kitty
dd113 is offline   Reply With Quote
Old 03-05-07, 09:20 PM   #3 (permalink)
I totaly agree.............and dont mind (drive it like a Diesel)
But......
is 9.1:1 high compression?
Old 03-05-07, 09:29 PM   #4 (permalink)
matt60/80's Avatar
I'm looking at Man-a-Fre's website right now and they have high compression pistions for the 3F @ 9.2:1. Man they are pricey.
matt60/80 is offline   Reply With Quote
Old 03-05-07, 09:32 PM   #5 (permalink)
THX
http://www.man-a-fre.com/parts_accessories/pistons.htm
TG it's not a V8!
Ahhh........to 2fe or not 2fe that is the question.
My 22r/e is 9.3:1 and runs on low test?
My 3vz is 9.0:1 and runs on low toast?
I think there FOS, and no performance figures?
How many year's they been sellin this?
Old 03-06-07, 12:04 AM   #6 (permalink)
extremetoy1's Avatar
Originally Posted by tntoyota View Post
THX
TG it's not a V8!
Why would you "2FE"
it is a 3FE
New and Improved now with 100% more horsepower, 70% more torque and 4.1 Low range!
extremetoy1 is offline   Reply With Quote
Old 03-06-07, 12:13 AM   #7 (permalink)
... Alive
Mark W's Avatar
The 3Fe has 8.5:1 compre4ssion IIRC. If you want more, just cut the head a little bit.
Why 2FE?
Bit more displacement (not much). More compression. longer rods which equal more torque from the same amount of down force on the piston. Same if not higher rpm limits right out of th box, and; the limit of the 2F is the rod bolts... these can be upgraded... Limiting factor for the 3FE is the side loading on the piston skirts which drop below the shortened cylinder bore. Nothing can be done about this).
Mark...
Mark W is offline   Reply With Quote
Old 03-06-07, 10:41 AM   #8 (permalink)
Moby's Avatar
Why 2FE?
Mark...
I made up my mind on this last week - 2FE for my FJ-62. My new (84) block is at the machinist right now. The real deciding factor for me was the rod ratio. 1.56 in the 3FE vs 1.88 in the 2F. The extra cubes are also nice - every little bit counts
Joel
'89 FJ-62
Moby is offline   Reply With Quote
Old 03-06-07, 01:45 PM   #9 (permalink)
Acording to Chilton
the 3fe has a c/r of 8.1:1 very low to me, yes it will run on water with that but I guess our fuel is of better quality hence:
22r/e 9.3:1
3fz 9.0:1
2MK, the c/r dictates the octane of fuel?
Moby, don't you mean stroke?
Lot's of stroke is good if you have an OverDrive.
Old 03-06-07, 01:47 PM   #10 (permalink)
... Alive
Mark W's Avatar
Don't ever use Chilton's for accurate info. Odds are a best 50/50 of it being right.
In this case I don't think it is. Not according to Toyota pubs I have seen.
Mark...
Old 03-06-07, 03:14 PM   #11 (permalink)
Please dont take this wrong 1: I have tried and tried but I cannot seem to find any better info.
2: Please dont take this wrong but, prove it
3: I agree with you about taking stock in any publication but I have found "Chilton's" way better than some others.................i.e, "Hayes"
Like I said please don't take that remark wrong
I just consulted the, all knowing, mother of all Toyota books, and literature the one the only..............."Toyota Truck and LandCruiser owners bible" and................
Just like any other specifics...................Nothing
I only bought that book to see the gear ratio's of Toyota transmissions.
What a waste.
Old 03-06-07, 03:35 PM   #12 (permalink)
dd113,
I've seen a few posts where you have alluded to a handful of tweaks that can be done to the 3FE to enhance eprformance. I've searched, but to no avail. Care to share?
Thanks...Don
dallen341 is offline   Reply With Quote
Old 03-08-07, 11:05 PM   #13 (permalink)
Originally Posted by dallen341 View Post
dd113,
Thanks...Don
crikets churping.......................shhh, be vewy, vewy kwiet
Old 06-23-07, 10:13 PM   #14 (permalink)
Lifer with a 2F-ETI
matt.mcinnes's Avatar
I agree every bit helps,
Larger flat faced Valves from Ferrea with a port and polish will increase air flow from 250cfm to 350cfm as well as increase the compression ratio over stock dished valves.
Better pistons from JE Part No 170771 will require a re bore giving you an extra few cc's. Con rods to suit the new pistons will be required.
Plenty more in the link in my Sig The Mule
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
matt.mcinnes is offline   Reply With Quote
Old 06-24-07, 07:08 AM   #15 (permalink)
jonheld's Avatar
2 or 3 years ago at CMCC, Jim Chenowith was giving a lecture on the RPM limitations of a 2F vs a 3F (amongst 100 other subjects). IIRC the 2F suffered from oil starvation at higher RPMs and the 3FE did not.
Jon Held
1991 FJ80 "Lumbering White Rhino"
My mind is a raging torrent, flooded with rivulets of thought cascading into a waterfall of creative alternatives.
http://www.sdsysdesign.com/tlc/
Buy your FJ80 FSM here:
http://www.sdsysdesign.com/tlc/fsm.html
jonheld is offline   Reply With Quote
Old 06-24-07, 12:53 PM   #16 (permalink)
Lifer with a 2F-ETI
I would agree and oiling mods are very much on the cards
Links
Mac's Space
On the rev limiter
Old 06-24-07, 12:59 PM   #17 (permalink)
... Alive
Mark W's Avatar
I don't see any reason that the oilin should be different between a late model 2F and a 3F. Same pump, same passages, same clearances. Different bearing sizes, so that may make a bit of difference. But the real problem in the two engines, respectively, is the rod bolts and the short rod/piston/bore. Both of these will be the failure point before oiling assuming that all systems are in nominal condition. And the rod bolts cane be addressed. The rod/piston/bore relationship can not.
Mark...
Old 06-24-07, 02:10 PM   #18 (permalink)
agent orange's Avatar
Is the problem just that the bore is short? I ask because the 3f rod is longer than a stock 350 rod and you can spin a 350 with a 5.7 rod all day long. The stroke is similar too.
1988 FJ 62- SUA, 1" body, 34" trxus mudders, 2.5" exhaust, 27spl Longs/Pig Inners, 4.88s, torsen LSD/lockright, 4runner brakes, other random stuff...
1986 pickup- 2wd, 22r, 4 speed, DD
agent orange is offline   Reply With Quote
Old 06-24-07, 08:39 PM   #19 (permalink)
Moby's Avatar
I'm pretty sure that stock 350s have a shorter stroke than the 3F/3FE (I think ~3.5"? vs. the 3F's 3.75"). 3F's have a rod/stroke ratio of about 1.56. The 350 is around ~1.6 if I remember correctly (which I may not be). Both of these are on what is considered the "short" side. But the 3f, with a shorter rod/stroke ratio and a longer stroke than the 350 is at more of at least a theoretical disadvantage when the rpms climb.
What a shorter rod/stroke ratio gives you is higher peak loads. The piston is accelerating and decelerating at BTC/TDC faster than with a longer ratio. As Mark has commented on in other theads the piston also tends to rock more in the cylinder which, especially with the shorter piston of the 3F, leads to higher loads on both the piston and the cylinder wall.
When I was looking at stroking a 3FE (yeah I gave that up quick ) I looked at a lot of rebuild kits and stroker combos in other engine types to see what people were building. There's almost nothing below a rod/stroke ratio of 1.55 and 1.5 is about the minimum you'll find. I also noticed that even with the stock stroke there are 350 rebuild packages with longer than stock rods (6" seems common) which tells me that people are looking to build "longer" rod/stroke ratio in 350s.
Joel
'89 FJ-62
Old 06-24-07, 09:03 PM   #20 (permalink)
photosynthesizing
pappy's Avatar
Garage
Mark...
Mark,
This is from the New Car Features publication from Toyota.
aka Bushrat
1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled!
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane
pappy is offline   Reply With Quote
