03-03-07, 09:44 AM
Oil Gauge Mod???
Has anyone done an oil gauge mod (similar tothe temp gauge mod) to make it more accurate?
If not modded gauge, how about a replacement gauge and, or sending unit?
D
DTaylor
96 FZJ80, Performance Engine Overhaul; (crank worked; head shaved & flowed) Injectors flowed; Intake polished; Exhaust polished. PS Cooler; CDL switch; Cup holder. Silicone heater hoses, green coolant, Rustoleum ft bumper paint, Powdercoated engine junk.
03 Harley Davidson Road King
03-03-07, 10:32 AM
Does the oil gauge need a mod?
1996 FZJ 80, 1973 FJ 40
03-03-07, 01:00 PM
It is not accurate. It has no pressure # associated with it.
DTaylor
03-03-07, 01:21 PM
Not having numbers doesn't mean the gauge in innacurate, it simply means that it does not have a scale that you are familiar with. The purpose of an oil pressure gauge is to alert you if there is a problem with your engine from low oil pressure or high pressure, the number are irrelevant for day to day. If the gauge goes significantly above the line at 2/3, you know that either the pressure relief spring for the pump is broken or the sender is bad. If it doesn't come off the line at the bottom you have no pressure. It communicates all the things an oil pressure gauge should, so there is no need to modify it.
You know your life is screwed up when you are getting divorced, fighting over custody, watching all of your money getting pissed away, being treated by her and her family as the anti-christ, and yet, finding your life has drastically improved.
03-03-07, 02:21 PM
I agree with Cary sort of. I would like a real gauge, with real numbers. I have no idea if my 1/4 gauge at idle is 5 psi or 35 psi. As others have noted, the gauge is not linear, and is basically a moving idiot light.
Andrew
03-03-07, 03:37 PM
What about a mod so that good oil pressure reads in the middle, low in the bottom, and high in the top third? The 80 series oil gauge often indicates low pressure all the time. Isn't that what dtalyor is looking after? Has anyone ever attempted to actually work on the OEM oil gauge circuitry?
Ins't THAT the real question, instead of numbers and external gauges, to have the OEM gauge work over all of its scale for a proper visual cue of the oil pressure?
91HDJ81VX (The Beast), 4B JDM, since Nov 06
83BJ60 (The Old Faithful), Still Running, Gone to a New Home
83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out
76FJ40 (Big Red), April 87 - July 93
03-03-07, 04:05 PM
A moving idiot light is right. This would be a valuable mod just as the water temp gauge mod and possibly as simple. The fact that the stock gauge sits at the bottom does not mean that there is no oil pressure. As a matter of fact, my gauge reads just that when hot at idle. An aftermarket gauge and sender in the same mounting spot shows 25 psi, which is acceptable. Lets get the mod going if someone has time.
Gary Waggoner
Golden, Co
1989 FJ62 SOA, 502 Mercruiser, ARBs Sold
1987 HJ61 SOA, Cable Locks, 39k miles Sold
1965 FZJ45 Pickup on Slee'd 80 chassis, plan B with 4.7 V8
2003 Tacoma, ARB, OME, SC, TRD Sold
2007 100 series, ARB, OME, Slee'd
TLCA 10689
LSLC 2000
Rising Sun 2007
www.powerplayracing.net
03-03-07, 04:07 PM
I am curious about this too. While under load (up hill on the freeway) my gauge sometimes reads in between the two thirds line and the max line. The rest of the time it seems to hover right on the 2/3 line. It always makes me wonder if this is normal or not.
Can an 80 have too high an oil pressure?
There are no stupid questions, but there are a LOT of inquisitive idiots.
1994 locked! FZJ80 6M1
CDL switch
Slee harnesses
PIAA driving lights
HIR upgrade bulbs
03-03-07, 04:34 PM
ΜΟΛΩΝ ΛΑΒΕ
what would you do to it?
mine spends most of its time at 2/3 mark (relief pressure) and the rest at the 1/3 mark at hot idle, seams just fine to me.
If your 1FZ is showing something different than might be a fault not as by design
1988 FJ62 on 33s
1996 LX450 on 33s
03-03-07, 05:47 PM
#10 (permalink)
That is possible. My truck and Dans both show really low oil pressure at idle. Mine I know for sure is 25-35 hot but shows 0 on the factory gauge. I was hoping to see something more accurate like the water temp mod.
Gary Waggoner
Golden, Co
TLCA 10689
LSLC 2000
Rising Sun 2007
03-03-07, 06:06 PM
#11 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
the temp gauge mod dealt with a known intensional flat spot from Toyota "middle temperature stable" written on the back in Chinese
http://forum.ih8mud.com/chit-chat-section/57834-can-anyone-here-read-translate-kanji.html
The oil pressure gauge has no such fault as issued, your gauge or sender has an error.
1988 FJ62 on 33s
1996 LX450 on 33s
03-03-07, 07:39 PM
#12 (permalink)
I like they way mine works . Before the temp guage mod you could tell if the motor was getting warmer on long grades. I can also tell the diff between 10 30 M1 and 15 30 mobil 1.
03-03-07, 07:42 PM
#13 (permalink)
You want to do what...?
as long as it doesn't have a flat spot in the wrong spot, it's fine with me. Mine seems fine to me.
 : '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!
 : '03: 115K
DDs: Accord, Prius
 : souped-up DR650
03-03-07, 09:13 PM
#14 (permalink)
OK, I assumed that the gauge was similar in design as the water temp.
Gary Waggoner
Golden, Co
TLCA 10689
LSLC 2000
Rising Sun 2007
03-03-07, 09:22 PM
#15 (permalink)
http://forum.ih8mud.com/showthread.php?t=57834
I tend to agree with the fault being in the sender or the gauge. My 1HZ reads 1/3 at 3000rpm and bottom mark at idle when engines at operating temp.
With an after market gauge on the truck it reads 40psi at idle and 65psi at 3000rpm.
I've shorted the sense wire at the pressure sensor to earth and the gauge read 1/2. I'm told by many 80's owners in Oz that this is quite normal and the gauge in the truck is pathetic and not designed for accurate information.
If some one can come up with a mod I'd be very interested. I just want the gauge at 1/3 at idle and 2/3 at 3000rpm.
Pete. R.
1990 GXL
1HZ Manual
Canberra
Australia
03-04-07, 08:17 AM
#16 (permalink)
Originally Posted by maverick_sr71
snip
well, IIRC, that's what mine shows....
 : '03: 115K
DDs: Accord, Prius
 : souped-up DR650
03-04-07, 09:54 AM
#17 (permalink)
Exactly like on my JDM...
This is very interesting... I would assume that a healthy gauge would peg to the top with the sender wire grounded! The mod then would require modifiyng the gauge meter in such a way to increase deflection, possibly by reducin tghe value of a resistor inline with the movement itself...
Exactly my point... Anyone with a spare dash gauge they are willing to offer for research?
03-04-07, 05:26 PM
#18 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
you guys are not listening, making something do what it did when it was new is not a "mod" it is called a "repair".
I have a spare oil pressure gauge but it already does this, there is nothing to mod.
1988 FJ62 on 33s
1996 LX450 on 33s
03-04-07, 06:06 PM
#19 (permalink)
I agree, don't see any dead spot in mine. It reads at the 1/3 idle and 2/3 at cruise. To test pull the wire connector off of the sender, turn the key on and the gauge should read at the bottom, not move. Ground the wire at the sender and the gauge should read at the top, if not repairs are needed.
Copper State Cruisers #007
03-04-07, 07:15 PM
#20 (permalink)
ThinkTank Waterboy
the only time I've had a low idle pressure reading is when the engine was running hot. I assumed it was from thinning out the oil some.
Rick Bigelow
'96 215k
Groveland MA 01834
03-04-07, 07:27 PM
#21 (permalink)
What about going to some aftermarket gauge that can be modified to fit into the same space occupied by the factory "moving idiot light" needle gauge?
If anyone knows of a smallish gauge that reads in actual psi numbers, this would be an improvement, with no need for a second location.
I admit I don't have the skills or time to come up with this, but I bet someone on the forum does.
DTaylor
03-04-07, 07:43 PM
#22 (permalink)
ThinkTank Waterboy
I don't get this one at all guys.
Right now you have a gauge that fluctuates between lines on the gauge.
But what you would really like is a gauge that fluctuates between numbers on the gauge.
Numbers, lines, what does it matter? Once you know the operating range it's moot. You'll not be concerned until the needle is out of that range.
Rick Bigelow
'96 215k
Groveland MA 01834
03-04-07, 08:47 PM
#23 (permalink)
instead of putting us down telling us you have one for sale, why don't you participate in the discussion on how to fix the damn thing?
03-04-07, 10:02 PM
#24 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
you completely missed my intent,
The gauge is not for sale, some one asked if anyone had a spare stock gauge to start working on a "mod" I am the one that spear headed the temp gauge mod. so hypetheticly I would be a good canidfate to figure out this "mod" only problem is this gauge already does exactly as below from the factoy so there is nothing to "mod" and nothing I can do to it.
1988 FJ62 on 33s
1996 LX450 on 33s
03-04-07, 10:26 PM
#25 (permalink)
He is not putting anyone down. Just stating that there is nothing wrong with the "damn thing"
03-05-07, 02:07 AM
#26 (permalink)
Your assumption is that it functioned as desired when new. I understand that the 1HZ oil pressure gauge never functioned as it should from new. The gauges were "set-up" to work for the 1FZ, 1HD and the 1HZ. Unfortunately this mass production techniques requires some "sacrifices" and the oil pressure gauge was one of those compromise areas.
I've not heard of any 1FZ's in Oz having issues with the gauge but many 1HZ's do have issues with the gauge.
Pete. R.
1990 GXL
1HZ Manual
Canberra
Australia
03-05-07, 07:47 AM
#27 (permalink)
Sorry about my impatience, Raventai. I've adjusted the fuel and and temp gauges on my 60 working with spares before I attempted it on the ones in the dash so I thought that someone had found a way to adjust the problematic oil gauge on the 80.
As for the gauge needing a 'mod' instead of a repair, so many of these seem to be inaccurate in the same way, a 'mod' seemed to be the proper description of what was needed. Maybe that was inaccurate.
I wish I had a spare to fiddle around with (maybe I will if Eric V will sell me his spare dash cluster), maybe you could describe the oil gauge circuitry a bit?
03-05-07, 02:48 PM
#28 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
sure, there is not much to the oil pressure gauge as compared to the water temp gauge.
there is a "U" shaped piece is sheet metal, the closed end hangs in free air, one part of the open end is hard mounted the other is hooked to needle via a linkage, a wire winds many turns around one of the arms of the "U"
one side of the wire is switched + from the ignition switch. the other is grounded through a variable resistor in the sender,
I assume this forms an electromagnet and the two arms of the "U" either attract or repel each other in proportion to the current going through the wire and this moves the needle.
sorry for the poor pictures, it was dim and shutter times were long.
1988 FJ62 on 33s
1996 LX450 on 33s
03-05-07, 03:42 PM
#29 (permalink)
okay, this one is easy.... why would one need a mod to the gauge? there isnt too many automotive engines made that wont survive with only 5lbs of pressure....
So if one had this mod what would you expect it to do? it goes up when the RPMs do and goes down when the RPMs do as well.
If it were to fluctuate would you even notice? there wouldnt be any problem if it did (it is normal to go up and down a bit) the temp mod helps make a more sensitive temp reading so when it does begin to move you can shut it down before you do damage to the engine.
The oil pressure will not cause detrimental damage if fluctuating... that is common.
New and Improved now with 100% more horsepower, 70% more torque and 4.1 Low range!
03-05-07, 04:43 PM
#30 (permalink)
Back to my original post. My factory gauge reads 0 when there is 25-35 psi oil pressure. Others do the same thing. The question was simple, and has been answered. My gauge or sender has an issue along with DTaylors. We will fix it. I was hoping that the gauge could be modded as easily as the water temp to use the full range of the gauge more accurately, but it can't so we can stop worring about it.
Gary Waggoner
Golden, Co
TLCA 10689
LSLC 2000
Rising Sun 2007
