80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 02-23-07, 02:54 AM   #1 (permalink)
aklosak's Avatar
e-lockers in '91 HZJ80
three quick questions,
1) is it possible to fit into '91 HZJ80 front FF axle e-locking diff from later model ?
2) Is it possible to exchange rear axle from later model (>'94, with lockers) into '91 ?
3) can I put some aftermarket air-conditioning into '91 HZJ80 (1HZ engine)?
any comment would be welcome :-)
regards
andy
aklosak is offline   Reply With Quote
Old 02-23-07, 05:25 PM   #2 (permalink)
ScottsHZJ80's Avatar
Andy,
I don't know about the lockers from later models, but I do know that air con was a dealer fit option on the lower spec models here in Australia. This being the case it shouldn't be too hard to retrofit, if you can source the bits somewhere.
'93 HZJ80 Std Wgn, 1HZ, 5 speed manual.
ScottsHZJ80 is offline   Reply With Quote
Old 02-23-07, 05:39 PM   #3 (permalink)
northerner
semlin's Avatar
hdj81s came with f/r lockers and full floating front/rear axles for 1990 and 1991 so the answer to one and two is yes it can be done but you likely don't have the ECM to control them. the locker part requires that you will need to buy the locked axles from somewhere and custom wire it. there are threads here on how to do it on a vehicle that is already FF rear. where you are going to a FF rear it might require other brake changes, and a complete rear axle out to the lug bolts.
93 fzj80
66 fj40L
m101cdn trailer
91 LS400 sedancruiser
64, 2x65 honda ct 200
67, 2x68, 3x69, 72, 75 Honda ct90
83 Honda ct70
48 Ferguson TE20
"Diplomacy is the art of having someone else impose your will on you" Lester Pearson
"I have the conch" Piggy
wfc 4812-2635-4880
semlin is offline   Reply With Quote
Old 02-23-07, 06:55 PM   #4 (permalink)
Swowie's Avatar
2. Yes you can! I just did it over the Christmas holiday. I put in a 96 axel. I had to go to rear disk brakes. If you can find a 94 or later axel it will bolt right up. The 96 sway bar is heavier on the rear but the body mount points are the same. You will need a new e- brake cable too. I had a minor problem piloting the drive shaft to the differential flange that required me to grind on the pinon nut a little. Otherwise it was a bolt right up.
"Large increases in cost with questionable increases in performance can be tolerated only in off road vehicles and fancy women." with apologies to Lord Kelvin
Swowie
92 - 80 w/OME lift, BFG LT315/75 R16 AT's, 96 axels w/4.88 locked F&R
CSC #086
Swowie is offline   Reply With Quote
Old 02-24-07, 03:37 AM   #5 (permalink)
aklosak's Avatar
Thank you for all your comments,
it's nice to hear 3x yes to all my questions :-)
thanks
andy
