80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 02-19-07, 12:45 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
CreeperSleeper's Avatar
Just got MetalTech spacers! (DIY)
Saturday, I picked up my new MetalTech 2” front coil spacers! These things are beefy…
I decided to do a DIY install so that everybody can see how easy it is to get rid of your stinkbug stance...
The Install:
Tools required- floor jack, jack stands, basic socket set.
The first thing I did was do a base measurement. From floor to fender was 39”.
Then I got the truck on jack stands.
And removed my tires.
Note- I don’t have my swaybars anymore, but if you still do, I would recommend disconnecting them from the axle.
Next step was to remove the shock at the bottom mount.
Note- At this point, the only thing that is holding up your axle is the friction in the bushings. Make sure that you don’t over-extend your break lines!!! I never had a problem with my 4” longer SS lines, but I did keep my floor jack under the pumpkin just in case.
Then you need to get the springs out. I am running OME “J” springs, so I have to step down on the rotor a bit to get enough room to pull the spring out.
Next you will remove the bump stop at the top spring mount. Just two nuts and it falls.
Now attach the bump stop to the spacer. I used the original hardware for that.
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes View Post
Dewd- You would bend those spindles if I tucked them into the passenger seat You are a candidate for a bobbed 80----not a high clearance bumper.
CreeperSleeper is offline   Reply With Quote
Old 02-19-07, 12:45 PM   #2 (permalink)
Now reattach the bump stop and spacer to the bump stops original location. I used the included nuts and washers.
The springs go back in next. Because I have J springs, I needed a little help on this part. My camera man had to stand on the rotor while I set the spring. It was just a bit to tight for me to do myself. (Or I am a bit too skinny, which is probably the case.)
Jack up the axle so you can reattach the shock. And, if you have them, sway bar.
Bolt back up the tires and you are done!
Before everything settled, this is where she measured.
After driving around the block it seemed to settle out perfect.
And of course you gotta test it!
Overall, I am really impressed with the quality an fitment of the MetalTech spacers. These boys know how to do things right. It’s nice that we now have an option of getting a spacer that is taller than 1” (MetalTech sells 1.5” and 2”) and is metal, so it will last the lifetime of the truck. Great job guys!
KE7VSA - MetalTech
Old 02-19-07, 02:38 PM   #3 (permalink)
AKcruiserfreak's Avatar
Very informative post. Thanks for taking your time to take some pics. I didn't know we had any other choices out there other than the 1" spacer. Looks good, A little battered, but good!
TK
1966 FJ-45lv resto. in progress
1966 FJ-45lv donor
1971 FJ-40 fun truck, resto. in progress
1974 FJ-40 donor
1985 FJ-60 donor
1985 FJ-60 OME, 33's, roof rack, etc.
1993 FZJ-80 OME, 285's, sliders, ARB, M12000,CDL mod, etc.
AKcruiserfreak is offline   Reply With Quote
Old 02-19-07, 02:45 PM   #4 (permalink)
LOL! That's the good side! These are a new product from MetalTech. The 1" spacer is all the choice that we used to have. Last week MetalTech came out with these and I jumped on them. As stated earlier, these things are extreamly well built and, IMO, the only option in regards to spacers.
KE7VSA - MetalTech
Old 02-19-07, 03:07 PM   #5 (permalink)
fzj80kidpen's Avatar
Nice shoots
___________________________________
FZJ80KIDPEN
96' FZJ80 186K miles
285/75/R16,OME 850/860's,locked,LED's
Homebrew Rear Bumper and sliders, Flareless and Line-X
fzj80kidpen is offline   Reply With Quote
Old 02-19-07, 03:16 PM   #6 (permalink)
Tools R Us's Avatar
Looks good! I find them easier to install if you bolt the spacer to the cone, put the cone in the spring and install them together.
Copper State Cruisers #007
Old 02-19-07, 03:24 PM   #7 (permalink)
80krazE's Avatar
Thanks for taking the time. Nice write-up, good pics. Curious, how did you know to go to 2" spacers? Measurement of difference between front and back, on level ground?
1997 FZJ80: OME 2.5" Heavy, Slee front + IPF 900XSD, Slee Light & Aux Harness, 255/85 BFG MT
2005 Porsche 911(997) Carrera Cabriolet
I used to get high on life, 'til I realized it was laced with idiots.
80krazE is offline   Reply With Quote
Old 02-19-07, 05:05 PM   #8 (permalink)
Thermodyn's Avatar
Great write-up. Gives this man a little encouragement and hope.
Thanks!
1997 LX450 - Factory locked
1996 Land Cruiser - Factory locked
"If I must choose between peace and righteousness, I choose righteousness!" - Theodore Roosevelt
Thermodyn is offline   Reply With Quote
Old 02-19-07, 05:23 PM   #9 (permalink)
Hmmm... didn't think of that.
KE7VSA - MetalTech
Old 02-19-07, 05:24 PM   #10 (permalink)
I didn't... I just used the bigger is better princapal! To be honest, I don't have any bumpers or any of my stuff loaded. Who knows how it will sit when it's done. But for now it looks awesome!
KE7VSA - MetalTech
Old 02-19-07, 05:25 PM   #11 (permalink)
Thanks!
This is about a half job... I think my fan clutch was harder to do.
KE7VSA - MetalTech
Old 02-21-07, 08:10 PM   #12 (permalink)
KE7VSA - MetalTech
Old 02-21-07, 08:31 PM   #13 (permalink)
C6H12O6's Avatar
That bump is disgusting.
I can't imagine getting that girl's face on my big, hairy stomach.
If you're gonna be a bear, be a grizzly.
Steve the Fly Fishing Science Teacher
1995 FZJ80 ~ Lockers, winchless ARB, 2.5" OME, bent-up, rattling, leaky Borla exhaust, MetalTech Sliders, multiple oil leaks, 285 Revos.
HAM: KE7VRZ
http://web.mac.com/stevenlent/cruiser/cruiser.html
C6H12O6 is offline   Reply With Quote
Old 02-21-07, 08:34 PM   #14 (permalink)
LOL... How about this one?
KE7VSA - MetalTech
Old 02-21-07, 08:54 PM   #15 (permalink)
always broke
alkaline747trio's Avatar
So about 6" of lift, still no caster correction? Feeling the need for it yet?
What?
Upstate Cruisers
alkaline747trio is offline   Reply With Quote
Old 02-21-07, 08:57 PM   #16 (permalink)
Nah. It's a little darty at times, but still not bad enough for me to go thru all the headache of correcting it. Besides, my 80 will be 3-linked in the front eventually.
KE7VSA - MetalTech
Old 02-21-07, 09:02 PM   #17 (permalink)
always broke
Cool deal, that's my plan too. Now I just gotta unload these Gen. 2 Slee Arms to recoup some of the cost.
What?
Upstate Cruisers
Old 02-21-07, 09:03 PM   #18 (permalink)
LOL! That shouldn't be too hard...
KE7VSA - MetalTech
Old 02-21-07, 09:04 PM   #19 (permalink)
always broke
If outback offroad would just hurry up with that 3-link then things would all be good.
What?
Upstate Cruisers
Old 02-21-07, 09:10 PM   #20 (permalink)
I didn't realize that they were making one. I think that Mark at MetalTech is going to do a 3 link on his and I was planning on stealing his research.
KE7VSA - MetalTech
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/138451-just-got-metaltech-spacers-diy.html
Posted By For Type Date
Metal Tech Coil Spacer (Group Purchase) - Toyota Forums :: Toyota Nation This thread Refback 11-14-08 03:53 PM
Lexus LX-450 - Page 21 - 4WDTrips.net Forums This thread Refback 10-22-08 06:07 PM
