02-15-07, 04:39 PM
Getting my 1st LC 80 tomarrow tow question
Newbie here, intro's later
Getting my first LC 80 2/16/07
Have to take my 4Runner and tow dollie by my self to get.
200 mi, O Trip, will be towing 4R, A.T on return trip.
Question is should I,
Disconnect my 4R's A.T's drive shaft.
Does it have to remain running in order to tow back with drive shaft still conected and in neutral?
My thoughts are to keep it running in neutral for the return trip, realisticly being towed 70-80 miles it shouldent use enough gas idling vs. labor d.c'ing then connecting shaft.
Any thoughts?
THX,
IH8W8
02-15-07, 04:41 PM
The quick brown fox .....
I don't know anything about a 4Runner. If it has a VC in the Xfer then you want to remove the DS of the wheels that will be rolling on the ground. I'm guessing you will put the front wheels on the dolly so remove the rear DS.
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
02-15-07, 05:03 PM
Direct disconnect differential
Depending on the year of the 4Runner you have, you may have a direct disconnect differential & your best bet is to get the front wheels on the dolly & locked in then put the whole xfer case in nuetral along with the trans. Should work like a champ. Hope that helped.
02-15-07, 05:10 PM
I'm going back to 79-95 I can't believe what I'm hearing.
02-15-07, 06:42 PM
I'd pull the rear shaft no matter what. No need spinning the TC output even if it is in neutral. All that lube foaming in there. Not to mention what would happen if you hit a bump or something and it did knock it into gear. Stranger things have happened.
Eric V. TLCA 7328 ADIDALC LICENSED OVERLANDER
99 UZJ100 "Barnicle Edition" Vorfab front bumper and sliders, MHHS diff drop, ARB front locker, 4x4 labs rear bumper with custom designed swingouts, OME springs/shocks/torsion bars
FJ68 PROJECT LEGO 60body/80chassis
PM me about Wagon Parts FS
"real environmentalists don't pave roads" "dents are like tattoos with better stories"
www.WildWildWestArt.com
02-15-07, 09:23 PM
Do you have pertinent input to the guy's question?
-B-
02-15-07, 09:41 PM
always broke
-B-
He is "the guy"...
02-15-07, 09:46 PM
I think he might be another incarnation of Tardnado, but nonetheless, he is a classic troll.....
I'd pull the shaft and make sure the front wheels are off the ground....
No problem, I'll just tow the pig to Salt Lake on a UHAUL trailer......
95 T100, beater edition (vacationing in Idaho)
97 Land Cruiser, Collectors Edition
01 Sequoia Limited
02 Camry, Commuter Chariot Extraordinaire
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
02-15-07, 09:50 PM
Originally Posted by alkaline747trio
He is "the guy"...
Duhh. Sorry for the dumb statement then.
-B-
02-16-07, 08:37 AM
#10 (permalink)
He is "the guy"...
Now that was funny
Anyhoo, I'd get the front wheels up on the dolly and pull the rear shaft....
That goes for ANY 4WD/AWD/RWD car/truck being towed without a flatbed...
Rick
02-16-07, 02:02 PM
#11 (permalink)
good observation, i was thinking the same
New and Improved now with 100% more horsepower, 70% more torque and 4.1 Low range!
02-16-07, 02:15 PM
#12 (permalink)
what he said
a) not sure why he is asking about runners in thif forum but..
b) leave the tranny out of gear, the Tcase in 2wd and tow away..
Pull the rear DS if it makes you feel better.
If you do not pull the rear shaft. do NOT put it in neutral..
02-16-07, 04:14 PM
#13 (permalink)
None of the 4Runners come with a VC in the transfer and FT 4wd? ? ?
-B-
02-16-07, 04:18 PM
#14 (permalink)
what he said
At leat untill 2003 or so that I know of there are no AWD runners. they are selectable..
Let me check.
They do have awd (multimode) diffs starting in 2003.
So putting the front tires on a dolly and pulling the rear shaft would be the best idea.
engine running is not necessary.
I do not know where the slip shaft is on the 2003/later runners..
if it is at the tcase. There are more things to worry about.
02-16-07, 04:24 PM
#15 (permalink)
Which part of tn you from?
1997 LX-450, Basically stock.
02-16-07, 04:29 PM
#16 (permalink)
If by "Troll" you nean having multiple knowladge of multiple Toyota 4x4's not limited to LandCruiser's then, yes, I am a "Troll"
If you guys want to act like snobs then you'll be much more "comfortable" in a RangeRover.
I ask simple questions, I give information to the best of my abilities to help others, not limited to LandCruisers. (L@@K @ you might learn something) There are other Toyota 4x4's you know.
LandCruiser....HolierThanThou
ALL AT's have the same way they should be towed. In my case I did leave it running , ideling for the 1hr return trip with the DS attached.
2MK as long as the internal pump is lubricating by the engine running, and the pump is not beeing towed with engine off.
Not DCing my DS cost me $2. I am lazy, you pull it for a dollar!
I have owned too many Toyota trucks to even list, I am not a Doctor or a Lawyer, I did not just go out and buy a HolierThanThou, and sitting around the house bored join a club.
THIS is where I stand sorry to offend, could you pass the GREY PUPON?
IH8W8
02-16-07, 04:33 PM
#17 (permalink)
what he said
Nice chip on your shoulder there amigo
02-16-07, 04:47 PM
#18 (permalink)
*All* A/T do NOT have the same way they should be towed.
I would recommend that you learn more about the drive train of your new-to-you 80-Series before you try the same thing with it.
-B-
02-16-07, 05:26 PM
#19 (permalink)
The only thing new to me is making sure the front wheels are off the ground when I put it on the dollie, "multi mode" is not AWD, all AT's do have the same way to be towed(You mean TC^^^^Dont you), and"Depending on the year of the 4Runner you have, you may have a direct disconnect differential & your best bet is to get the front wheels on the dolly & locked in then put the whole xfer case in nuetral (  this locks the TC frt.2rear  ) allong with the trans. Should work like a champ".
And I apperently have some sort of wood shavings on my shoulder.
Seriously, I love hearing your comments and I obviously needed an opinon.
This was a quickly put together, thus I needed an answer.
The funny thing is the confidence, I usually look for confidence in a reply.
I'm having a blast here, thanks for all your answers and trying to help.
02-16-07, 06:02 PM
#20 (permalink)
always broke
Why in the world would you leave it running? Whoever told you that was a complete moron.
02-16-07, 06:17 PM
#21 (permalink)
what he said
You leave it running to continue lubrication to the rear bearings in the tranny.
Funny thing, up until a second ago I thought you were proudly talking about your all terrain tires
If your truck has some sort of AWD/part time system and you tow it on a dolly without removing the rear DS you risk damaging the coupler.
If your truck does not have some sort of AWD system and you put it on a dolly but throw the tcase in neutral, and do not remove the rear DS you will be spinning the front DS... Potential issue there..
02-16-07, 06:58 PM
#22 (permalink)
IH8W8
 Whatever dude, nobody here has ever had any other toyota than a landcruiser..............
Excuse me while I bow to your superior knowledge.
01 Sequoia Limited
02-16-07, 07:22 PM
#23 (permalink)
Sponsored by...?
Any thoughts?
THX,
IH8W8
You've come to an 80 series Land Cruiser forum asking what you should do to tow your unknown year '4R' zero trip A.T. Your question was difficult to understand, as you used shorthand we're not familiar with around here. You got some bad information in reply (Yeah, putting a part-time T-case in neutral and towing with the rear driveshaft installed would be a bad idea  ). We're all sorry. Ask us some questions about towing the 80 Series you just bought, we'll get those right. At least most of us will.  If you want good answers for towing your 4Runner, ask in a 4Runner forum. You might want to tell them what year 4Runner you have, though.
-Spike (Welcome!)
His 1994 TLC 'White Elephant' +6"/35" Locked and loaded.
Hers '95 TLC Bare bones.
"I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown
02-17-07, 09:12 AM
#24 (permalink)
always broke
200mi trip? I'd pull the rear DS...
02-17-07, 09:15 AM
#25 (permalink)
what he said
Well yeah..
