02-13-07, 06:17 PM
| | ThinkTank Waterboy
| Front axle evaulation for FAQ With so many questions on caster and front end alignments and issues I thought I'd put together a post on how I evaluate an axle for problems.
I'd do this if I had problems or before I brought the truck in for an alignment.
I like to start at the passenger side of the vehicle first. This is mainly do to the fact that it's the first wheel right off of the steering box.
Once I've jacked up the passenger side wheel off the ground I do a cursory check of the lower knuckle arms. There have been issues with these nuts loosening up and the arms coming loose and giving driving issues.
Attached is the jack in place and a shot of the lower knuckle arm.
__________________ Rick Bigelow
'96 215k
Groveland MA 01834
If you're not the lead dog, the view never changes |
02-13-07, 06:19 PM
| | ThinkTank Waterboy
| The next thing I do is check for bearing play in the tire. This is done by grabbing the tire at 12:00 and 6:00 o'clock positions and lifting the bottom of the tire as you push the top of the tire. Any play here would mean that the bearing is loose and needs your attention.
'96 215k
Groveland MA 01834
02-13-07, 06:25 PM
| | ThinkTank Waterboy
| Next up is to look for play in the tire rod ends. This time you grap the tire at 9:00 and 3:00 o'clock positions and push left and right. Any free movement would mean that a Tie rod end is likely worn. Since we've started on the passenger side and free movement would be in the drag link which goes from the steering box to the knuckle arm on the passenger side. Attached are pictures of both ends of the drag link and the hand position for checking for play.
'96 215k
Groveland MA 01834
02-13-07, 06:27 PM
| | ThinkTank Waterboy
| Next up is to check for play in the trunion bearings. This requires the use of a bar as you alone might not be able to get the needed force on the tire to feel the play. You'll need to lift the tire with the bar. I usually have my left hand on the rim to feel the place
Attached is a pic of how to set up the bar and where the trunion bearings are located.
'96 215k
Groveland MA 01834
02-13-07, 06:31 PM
| | ThinkTank Waterboy
| At this point I put the passenger side tire back on the ground and perform the same set of checks on the driver side.
The only difference is that and play in the tie rod check would be a result of a warn tie rod end on the tie rod. This is the rod that travels behind the axle and links the two tires together.
Attached is a picture of a tie rod end
'96 215k
Groveland MA 01834
02-13-07, 06:33 PM
| | ThinkTank Waterboy
| The last check would to be sure that the clamp that holds the Tie rod in place is positioned properly so as not to contact the leading arm and give a false reading on the rack.
'96 215k
Groveland MA 01834
02-13-07, 06:36 PM
| | Addicted to MUD Porn
| Very nice. I don't really have anything constructive to add but eeewww I'm glad the underside of mine doesn't look like that. Yeah rust free.
Sorry.
Jack
__________________ KE7NCK
1996 FZJ 80 (explorer)
2002 F350, PSD, 6SPD,4X4,CC, LWB (hauler)
1995 Mazda MX-6 (speedster) |
02-13-07, 06:37 PM
| | ThinkTank Waterboy
| During these checks, any play needs to be identified. This usually requires a second person to do the moving and you to grab onto the suspect parts and find where they are loose.
Loose would mean that there is some free play where there is little to no resistance in movement. Being able to apply enough force to get some flex out of the system doesn't constitute play.
'96 215k
Groveland MA 01834
02-13-07, 06:38 PM
| | 250+ Club
| When checking for play in the trunion bearings; which way am I moving the rod?
__________________ Boyd (stuck on rock)
KI6RCM
1997 White FZJ 80 - "SuperMilquetoast" aka JAFW80 I'm not satisfied until you're not satisfied. |
02-13-07, 06:43 PM
#10 (permalink)
| | ThinkTank Waterboy
| Quote:
Originally Posted by locrwln1 Very nice. I don't really have anything constructive to add but eeewww I'm glad the underside of mine doesn't look like that. Yeah rust free.
Sorry.
Jack | Cameras tend to accentuate red so they always look worse then they are.
On a side note Massachusetts is starting a new sanding policy. They found that by adding brewery remnant to the sand they can greatly reduce the amount of salt used and it's more effective. All this and it costs less also.
It just smells like a frat house after a party when you drive on it the next day.
'96 215k
Groveland MA 01834
02-13-07, 06:44 PM
#11 (permalink)
| | ThinkTank Waterboy
| Quote:
Originally Posted by boydmick When checking for play in the trunion bearings; which way am I moving the rod? |
You're lifting the tire with the bar. I'll edit that at the top.
'96 215k
Groveland MA 01834
02-13-07, 06:47 PM
#12 (permalink)
| | Forum Lifer
| Great post, I may steal some of it for a sticky to be attached to another thread. people like pics.
Dang the salt is bad up there.
G
__________________ Gary Waggoner
Golden, Co
1989 FJ62 SOA, 502 Mercruiser, ARBs Sold
1987 HJ61 SOA, Cable Locks, 39k miles Sold
1965 FZJ45 Pickup on Slee'd 80 chassis, plan B with 4.7 V8
2003 Tacoma, ARB, OME, SC, TRD Sold
2007 100 series, ARB, OME, Slee'd
TLCA 10689
LSLC 2000
Rising Sun 2007 www.powerplayracing.net |
02-13-07, 07:06 PM
#13 (permalink)
| | ThinkTank Waterboy
| Quote:
Originally Posted by Waggoner5 Great post, I may steal some of it for a sticky to be attached to another thread. people like pics.
G | My last drive was 7 hours on I90 in NY after a snow flurry. Those bastids were out in force as it was a lean year up to that point and they needed to get out on the roads.
'96 215k
Groveland MA 01834
02-13-07, 07:54 PM
#14 (permalink)
| | Forum Lifer
| I had no idea it was that bad.
Golden, Co
TLCA 10689
LSLC 2000
02-13-07, 08:18 PM
#15 (permalink)
| | Site Addict
| Quote:
Originally Posted by landtank The next thing I do is check for bearing play in the tire. This is done by grabbing the tire at 12:00 and 6:00 o'clock positions and lifting the bottom of the tire as you push the top of the tire. Any play here would mean that the bearing is loose and needs your attention. | this is a good idea. all of this is. i brought my truck to land tanks to have him help me with the phh and it turns out my wheel bearings were loose as hell.
i had been complaining about castor and all time time it was play in the wheel! these checks will take no more than one hour. i am going to do them every time i get the grease gun out at 5K or so...
__________________ TLCA #14504 '97 FZJ80, ARB Bullbar, IPOR rear bumper, factory lockers, Slee 4" lift, Toyo MTs, Austrailian Outback drawer, Hellroaring Dual batt system w/ dual Optimas, Lightforce 240s, etc, etc... My blog |
02-13-07, 08:45 PM
#16 (permalink)
| | The quick brown fox .....
Join Date: Mar 2003 Location: Somewhere in the foothills...
| Great post Rick. Thanks! We have tried to describe these procedures numerous times so now all we have to do is remind someone to look for this thread.
-B-
__________________ 97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete. Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
02-13-07, 08:55 PM
#17 (permalink)
| | Site Addict
| This needs to be linked from the troubleshooting FAQ. It cleared up a few things for me. I was fully unaware of how to check the trunnion bearings.
Great writeup!
__________________ FZJ80 1
1996 MoonGrey FZJ80 140K - Lotsa toys/extras/mods/maint. FZJ80 2
1996 Red FZJ80 140K- Fac lock. 861/862 OME. |
02-14-07, 05:18 AM
#18 (permalink)
| | Site Addict
| Kudos Rick, as for the salt  The brewery by product can be expensive but I've experienced favorable results with it. At a college in Needham, MA that I used to work at the grounds crew used it. I was the safety person at the time and within minutes of the application my phone was ringing of the hook regarding some weird smell all over campus.
Nice job documenting some good things to know/do.  (its not just the beverage of choice anymore  ) |
02-14-07, 05:31 AM
#19 (permalink)
| | 250+ Club
| Great info, I'm gonna check my Cruiser today. Thank you!!!
__________________ 1996 Lexus LX 450
2006 Lexus LX 470 The bitterness of poor quality is remembered long after the sweetness of low price is forgotten. |
02-14-07, 08:55 AM
#20 (permalink)
| | Forum Regular
| thanks for the great info! Being new to the cruiser world this site has nothing but help and great people! The pictures help to visualize exactly what your talking about! Thanks
__________________ Its not a Passion, its an Obsession
Cruiser~95 stock 80 series, Goodyear Forterra Triple-Treds, Samco sport PHH.
Princess Ride~2008 Toyota Tundra Crewmax limited
Chevinater~ 77 Chevy 3/4 ton 350/350/203 with 44 front 14ff rear, 4.56s, 6 inchs 35x12.5x16.5 bfg m/t |
