Old 02-13-07, 06:17 PM   #1 (permalink)
ThinkTank Waterboy
landtank's Avatar
Front axle evaulation for FAQ
With so many questions on caster and front end alignments and issues I thought I'd put together a post on how I evaluate an axle for problems.
I'd do this if I had problems or before I brought the truck in for an alignment.
I like to start at the passenger side of the vehicle first. This is mainly do to the fact that it's the first wheel right off of the steering box.
Once I've jacked up the passenger side wheel off the ground I do a cursory check of the lower knuckle arms. There have been issues with these nuts loosening up and the arms coming loose and giving driving issues.
Attached is the jack in place and a shot of the lower knuckle arm.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-13-07, 06:19 PM   #2 (permalink)
ThinkTank Waterboy
landtank's Avatar
The next thing I do is check for bearing play in the tire. This is done by grabbing the tire at 12:00 and 6:00 o'clock positions and lifting the bottom of the tire as you push the top of the tire. Any play here would mean that the bearing is loose and needs your attention.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-13-07, 06:25 PM   #3 (permalink)
ThinkTank Waterboy
landtank's Avatar
Next up is to look for play in the tire rod ends. This time you grap the tire at 9:00 and 3:00 o'clock positions and push left and right. Any free movement would mean that a Tie rod end is likely worn. Since we've started on the passenger side and free movement would be in the drag link which goes from the steering box to the knuckle arm on the passenger side. Attached are pictures of both ends of the drag link and the hand position for checking for play.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-13-07, 06:27 PM   #4 (permalink)
ThinkTank Waterboy
landtank's Avatar
Next up is to check for play in the trunion bearings. This requires the use of a bar as you alone might not be able to get the needed force on the tire to feel the play. You'll need to lift the tire with the bar. I usually have my left hand on the rim to feel the place
Attached is a pic of how to set up the bar and where the trunion bearings are located.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-13-07, 06:31 PM   #5 (permalink)
ThinkTank Waterboy
landtank's Avatar
At this point I put the passenger side tire back on the ground and perform the same set of checks on the driver side.
The only difference is that and play in the tie rod check would be a result of a warn tie rod end on the tie rod. This is the rod that travels behind the axle and links the two tires together.
Attached is a picture of a tie rod end
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-13-07, 06:33 PM   #6 (permalink)
ThinkTank Waterboy
landtank's Avatar
The last check would to be sure that the clamp that holds the Tie rod in place is positioned properly so as not to contact the leading arm and give a false reading on the rack.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-13-07, 06:36 PM   #7 (permalink)
Addicted to MUD Porn
locrwln1's Avatar
TLCA# 16879
Very nice. I don't really have anything constructive to add but eeewww I'm glad the underside of mine doesn't look like that. Yeah rust free.
Sorry.
Jack
KE7NCK
1996 FZJ 80 (explorer)
2002 F350, PSD, 6SPD,4X4,CC, LWB (hauler)
1995 Mazda MX-6 (speedster)
locrwln1 is offline   Reply With Quote
Old 02-13-07, 06:37 PM   #8 (permalink)
ThinkTank Waterboy
landtank's Avatar
During these checks, any play needs to be identified. This usually requires a second person to do the moving and you to grab onto the suspect parts and find where they are loose.
Loose would mean that there is some free play where there is little to no resistance in movement. Being able to apply enough force to get some flex out of the system doesn't constitute play.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-13-07, 06:38 PM   #9 (permalink)
boydmick's Avatar
TLCA# 13903
When checking for play in the trunion bearings; which way am I moving the rod?
Boyd (stuck on rock)
KI6RCM
1997 White FZJ 80 - "SuperMilquetoast" aka JAFW80
I'm not satisfied until you're not satisfied.
boydmick is offline   Reply With Quote
Old 02-13-07, 06:43 PM   #10 (permalink)
ThinkTank Waterboy
landtank's Avatar
Sorry.
Jack
Cameras tend to accentuate red so they always look worse then they are.
On a side note Massachusetts is starting a new sanding policy. They found that by adding brewery remnant to the sand they can greatly reduce the amount of salt used and it's more effective. All this and it costs less also.
It just smells like a frat house after a party when you drive on it the next day.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-13-07, 06:44 PM   #11 (permalink)
ThinkTank Waterboy
landtank's Avatar
You're lifting the tire with the bar. I'll edit that at the top.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-13-07, 06:47 PM   #12 (permalink)
Waggoner5's Avatar
Great post, I may steal some of it for a sticky to be attached to another thread. people like pics.
Dang the salt is bad up there.
G
Gary Waggoner
Golden, Co
1989 FJ62 SOA, 502 Mercruiser, ARBs Sold
1987 HJ61 SOA, Cable Locks, 39k miles Sold
1965 FZJ45 Pickup on Slee'd 80 chassis, plan B with 4.7 V8
2003 Tacoma, ARB, OME, SC, TRD Sold
2007 100 series, ARB, OME, Slee'd
TLCA 10689
LSLC 2000
Rising Sun 2007
www.powerplayracing.net
Waggoner5 is offline   Reply With Quote
Old 02-13-07, 07:06 PM   #13 (permalink)
ThinkTank Waterboy
landtank's Avatar
G
My last drive was 7 hours on I90 in NY after a snow flurry. Those bastids were out in force as it was a lean year up to that point and they needed to get out on the roads.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-13-07, 07:54 PM   #14 (permalink)
Waggoner5's Avatar
I had no idea it was that bad.
Gary Waggoner
Golden, Co
TLCA 10689
LSLC 2000
Rising Sun 2007
Old 02-13-07, 08:18 PM   #15 (permalink)
peepers's Avatar
this is a good idea. all of this is. i brought my truck to land tanks to have him help me with the phh and it turns out my wheel bearings were loose as hell.
i had been complaining about castor and all time time it was play in the wheel! these checks will take no more than one hour. i am going to do them every time i get the grease gun out at 5K or so...
peepers is offline   Reply With Quote
Old 02-13-07, 08:45 PM   #16 (permalink)
The quick brown fox .....
Beowulf's Avatar
Great post Rick. Thanks! We have tried to describe these procedures numerous times so now all we have to do is remind someone to look for this thread.
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
Old 02-13-07, 08:55 PM   #17 (permalink)
Grench's Avatar
TLCA# 16296
This needs to be linked from the troubleshooting FAQ. It cleared up a few things for me. I was fully unaware of how to check the trunnion bearings.
Great writeup!
FZJ80 1
1996 MoonGrey FZJ80 125K - Lotsa toys/extras/mods/maint.
FZJ80 2
1996 Red FZJ80 120K- Fac lock. 861/862 OME.
Grench is offline   Reply With Quote
Old 02-14-07, 05:18 AM   #18 (permalink)
stayalert's Avatar
Kudos Rick, as for the salt The brewery by product can be expensive but I've experienced favorable results with it. At a college in Needham, MA that I used to work at the grounds crew used it. I was the safety person at the time and within minutes of the application my phone was ringing of the hook regarding some weird smell all over campus.
Nice job documenting some good things to know/do.
(its not just the beverage of choice anymore)
stayalert is offline   Reply With Quote
Old 02-14-07, 05:31 AM   #19 (permalink)
RacerLex's Avatar
Great info, I'm gonna check my Cruiser today. Thank you!!!
1996 Lexus LX 450 (locking diffs)
2006 Lexus LX 470
The bitterness of poor quality is remembered long after the sweetness of low price is forgotten.
RacerLex is offline   Reply With Quote
Old 02-14-07, 08:55 AM   #20 (permalink)
Chevinater77's Avatar
thanks for the great info! Being new to the cruiser world this site has nothing but help and great people! The pictures help to visualize exactly what your talking about! Thanks
Its not a Passion, its an Obsession
Cruiser~95 stock 80 series, Goodyear Forterra Triple-Treds, Samco sport PHH.
Princess Ride~2008 Toyota Tundra Crewmax limited
Chevinater~ 77 Chevy 3/4 ton 350/350/203 with 44 front 14ff rear, 4.56s, 6 inchs 35x12.5x16.5 bfg m/t
Chevinater77 is offline   Reply With Quote
Old 02-14-07, 10:36 AM   #21 (permalink)
Rookie2's Avatar
Yes, nice work Rick.
1997 LX-450, Basically stock.
Rookie2 is offline   Reply With Quote
Old 02-14-07, 12:58 PM   #22 (permalink)
AllenTenT's Avatar
Most excelent , thanks Tank
97 1HD-FT, walbro, intercooled, locked, Battlez2.5"-rancho adjustable, 33" ATs 35" MT, 2 spares, fridge, shower,TJM and winched
AllenTenT is offline   Reply With Quote
Old 02-14-07, 04:43 PM   #23 (permalink)
vkfzj80's Avatar
TLCA# 17207
landtank, thanks for the write up, that is exactly what I needed, very useful info.
95 TLC, factory locked, CDL switch
F.O.R. lift kit, 4.88 gears, 315 Dick Cepek FCII
vkfzj80 is offline   Reply With Quote
Old 02-14-07, 04:49 PM   #24 (permalink)
Parts Geek, M1 Mechanic
cruiserdan's Avatar
TLCA# 11332
Rick,
How is it that a guy as old as you still has all that hair and it aint grey?
Don't you have a teenage daughter?
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
Old 02-14-07, 05:55 PM   #25 (permalink)
ThinkTank Waterboy
landtank's Avatar
Originally Posted by cruiserdan View Post
Rick,
Yup the daughter is 18 and the man child is 14. My father was bald at 21 however my grandfather on my mothers side died at 83 with every last strand still in place, but by then it had grayed.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-14-07, 06:38 PM   #26 (permalink)
Beowulf's Avatar
Baldness (or the lack of) is inherited through your mother's genes.
-B-
Old 02-14-07, 07:45 PM   #27 (permalink)
cruiserdan's Avatar
TLCA# 11332
Yup.
My mother's father was a billard ball......
He used to say that he was 6 feet tall but his hair was only 5 feet 10.
Old 02-22-07, 08:44 PM   #28 (permalink)
always broke
alkaline747trio's Avatar
So if you have play in the 12 and 6 motion, what is the cure?
What?
Upstate Cruisers
alkaline747trio is online now   Reply With Quote
Old 02-22-07, 08:47 PM   #29 (permalink)
ThinkTank Waterboy
landtank's Avatar
The wheel bearings are most likely loose and need to be inspected and setup correctly.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-22-07, 08:51 PM   #30 (permalink)
always broke
Is it possible that the 54mm nut is loose? Mechanic said that might solve the problem.
What?
Upstate Cruisers
