01-31-07, 11:10 PM
#1 | | Forum Regular
| 10 amp gauge fuse keeps blowing Any idea why my 10amp Gauge fuse keeps blowing. I have replace 3 in the past year  .
Boz
__________________ 1997 LX 450 2" OME lift, custom fab bumpers 1/4" plate and 2" roll bar. Most of the pink panty stuff is off |
02-01-07, 04:48 AM
#2 | | 250+ Club
| Which 10 amp fuse? Just a little more information would be helpful. Not saying I can help you, but the more information provided the better for someone who can help.
__________________ 1994 1FZJ80 - Locked;CDL Switch
Engine: Rotella 5w40; Tranny:Mobil1 Synthetic
Bilsteins:B46-1477 FRONT; B46-1478 REAR
Bridestone Dueler A/T Revo's 285/75/16 on LX450 rims (2nd set)
OME:Springs 850 FRONT/863 REAR
Hanna Quality Rear Bumper |
02-01-07, 08:45 AM
#3 | | Forum Regular
| As posted "Gauge" fuse. runs all the switches and guages.
02-01-07, 09:42 AM
#4 | | 250+ Club
| Sounds like the little problem I have. #10 in the center second one down?
This fuse also supplys power to yor window relay. Mind tends to blow when switching betwen forward and reverse only when off road and more often with CDL in low range. Originaly thought it was my trailer wiring but ruled this out when I ripped the wiring out. On occasion a nasty trail bump has also blown this fuse.
My gut tells me that there is probably a short in the rear passenger back up/brake light system as this seems to be the common denomiter.
Good luck and carry extra fuses
__________________ 90 JDM HDJ81 Lifted, Magic dialed, Turbo Diesel
93 FZJ80 De-flared, de-bumpered and Aussied DD SOLD to a new Addict.
HZJ79L 5speed diesel for work
I had an awkward moment once, just for the experience!
My son schooooooling us on air time... http://www.youtube.com/watch?v=RsmObkHUkSU |
02-01-07, 04:04 PM
#5 | | Parts Geek, M1 Mechanic
| Quote:
Originally Posted by BOZ Any idea why my 10amp Gauge fuse keeps blowing. I have replace 3 in the past year  .
Boz |
When does it blow? Is there a pattern?
At one time I had 50 watt hallogen backup bulbs and those things would pop my gauge fuse about every two months. Maybe there is a problem in your back-up circuit?
__________________ Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock. 2009 Dodge Challenger SRT8, 465 horse HEMI, 6 speed manual trans, cop-attracting-red. Kimberly Kamper and some Garands. |
05-14-07, 10:03 AM
#6 | | 250+ Club
| So,
I have ripped out the trailer harness and the (Number 7) 10 amp fuse still blows, added ground wires and still...now normally this happens when in locked CDL low and reverse, but twice driving in forward high range after a jarring bump caused by the hitch catching solid rock This leads me to think that the system is shorting via the frame or body, but where.
My guess again is the right rear???
Of course I carry extra fuses and may add a 10amp breaker until the culprit is rooted out.
Another thing, would a short cause Low reverse to cut out at higher rpm's? this is a new gremlin.
05-14-07, 12:59 PM
#7 | | Forum Regular
| A lttle background on the problem I had: I was driving down the road here in Tucson with the A/C on. It was about 100 degrees outside and all of a sudden the A/C shut off and the gauges in the dash stopped working. After replacing the fuse, everthing was fine until i turned the A/C compressor back on, the fuse blew again. It only happend when I turned the A/C comprssor on, not the blower fan, heater, rear heat, or anything else on the heat/A/C control panel. So, I took a Toyota wiring schematic for the gauge circut and began testing things on the circut. At first, all indications pointed to the A/C cut relay behind the main engine computer. After I replaced that, the problem continued. So, I took the test further and now determined that the clutch on the compressor is the culprit. It was pulling about 20 amps and i THINK it is supposed to pull about 5 or 6. But, while i was there i found that the compressor is aftermarket anyway and Toyota sells the clutch and the compressor as one piece for the 1FZ  .
I hope my living without A/C in Tucson for the past 2 weeks without A/C could maybe help you identify a problem quicker.
Cheers |
05-14-07, 02:30 PM
#8 | | Addict
| This may help: http://homepage.mac.com/dfmorse/Fuse...5.1/index.html
There is a lot of stuff hooked up to fuse #7, the GAUGE fuse. Time to do some isolation trouble shooting.
__________________ D.F.Morse
1994 FZJ80 Kazumatized 90000 mi
1979 FJ-40 80000 mi
Here endith the lesson |
05-22-11, 07:05 PM
#9 | | 250+ Club
| I seem to have just acquired a similar problem. I've gone through six fuses today alone. It seems to blow either after a while while driving in high range, but almost instantly while reversing. At first I thought it was my recently installed GPS that I tapped into the ignition switch, but I rerouted it to the power outlet in under the hood and I've just gone through two more fuses trying it out since then.
__________________ '92 HDJ81 - Locked, de-flared, OME 2.5", 33" on 15", Cruisin Off-Road sliders and skidplate, Rage Big Bore exhaust, crappy aluminum bumper, Warfield drawers, XRC 12 Comp, Garmin 62s, modded ARB steel basket with Pilbara, comfy sheepskin seats
TLCA #20716, 4WDABC #2251, Coastal Cruisers |
05-23-11, 11:30 AM
#10 | | Parts Geek, M1 Mechanic
| Have you added anything to the back up lamp circuit or increased the wattage of the backp bulbs?
05-23-11, 12:56 PM
#11 | | 250+ Club
| Quote:
Originally Posted by cruiserdan Have you added anything to the back up lamp circuit or increased the wattage of the backp bulbs? | The previous owner installed a hitch and trailer brake light control thing. I'll see if I can pull that out and try again. thx.
