80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 01-27-07, 09:42 AM   #1 (permalink)
ThinkTank Waterboy
landtank's Avatar
Copnstant hose clamps? real time help!
I'm helping another member "Peepers" with his PHH today. The hose is on but I'm not sure how to use the Constant hose clamps to be sure they are installed correctly.
I searched here and checked the vendor site and didn't find any instructions there.
We have some other work to do while that tire is off so I was hoping for some guidance otherwise we'll have to make a best guess and hope for the best.
thanks
Rick Bigelow
'96 215k
Groveland MA 01834
landtank is online now   Reply With Quote
Old 01-27-07, 10:00 AM   #2 (permalink)
Montana Cruiser's Avatar
Rick -
I was able to find some information that may help here;
http://www.rotorclamp.com/design-eng-assist.php
# Hose Clamps
Rotor Clamp constant tension type hose clamps will compensate for changes in joint diameter due to compression set in a hose. This feature eliminates leaks and the need to re-torque a clamp. Factors to consider when sizing a clamp:
* CTB type clamps: The clamps have a number designation equivalent to the outside diameter of the joint to be clamped, expressed in millimeters (Ex.-CTB-27).
* HC (SAE Type "E"), HW and DW (SAE type CTW )- Clamps have a range of recommended application diameters, listed on the spec pages as "A, B and C" diameters. The nominal diameter of the clamp is the clamp size divided by 16.
* The joint diameter will equal the fitting outside diameter plus twice the wall thickness, including the tolerances associated with each.
* The clamp must be large enough to fit over the maximum diameter of the joint bead and hose at this point (see illustration).
You can use a smaller clamp on an application to increase force. This can be done by placing the clamp on the fitting, installing the hose and sliding the clamp "backwards" up to the bead. Ideally, a clamp should be sized to fit onto the joint when opened to 90% of full (as a safety factor) and close to no less than the nominal (size) diameter when in the final position.
- Nate
2000 4Runner Sport Edition PP 1" Lift Coils / 32" Tires / Norcold / RTT / ARB coming soon!
SOLD! 97' FZJ80 "Junior" Black/ARB winch bar/OEM Lockers
Montana Cruiser is offline   Reply With Quote
Old 01-27-07, 10:08 AM   #3 (permalink)
Cattledog's Avatar
Hey Landtank,
I assume the clamps are made by breeze? If so torque them th 35 to 40 inch/lb, per breeze tech service.
See post 16 in So tell me why I shouldn't use worm drive clamps with silicone heater hose?
96 lx 450 stock, with 285's and R.B. MAF housing.
2006 Sienna LE 8 passanger, 3 kids and Room to spare!
Cattledog is offline   Reply With Quote
Old 01-27-07, 01:00 PM   #4 (permalink)
ThinkTank Waterboy
landtank's Avatar
Thanks guys. I have an inch lbs click set wrench but couldn't get it in there so I let Peepers make the call. It seems leak free and he's out of my garage so all is good AFAIC.
Rick Bigelow
'96 215k
Groveland MA 01834
