12-30-06, 10:13 PM
| | Forum Regular
| How much lube does my knuckle get? today i had the first signs of dry spindle bushings... i remember the propeller shaft zirks get about 3 pumps of moly... how much moly (?) does each knuckle get through the screw plug w/ the grease gun?
tia
Black 97 FZJ80 ~ 153,000m | Silver 06 Honda S2000 ~36,000m [wish list: oem springs, bilst shocks, toyo mt 33", 1" body lift] [fix list: a/c, birfs, exhaust, seat belts, windows, alignment] other hobby: evonetwork "everything should be made as simple as possible, but not simpler" |
12-31-06, 10:59 AM
| | 250+ Club
| Quote:
Originally Posted by tea LC today i had the first signs of dry spindle bushings... i remember the propeller shaft zirks get about 3 pumps of moly... how much moly (?) does each knuckle get through the screw plug w/ the grease gun?
tia | What were the first signs? Need more info.
About all you can do is take the ABS sensor out and dip a stick down in there and see if anything gets on it.
What year, how many miles on it since last birf job.
Consensus on this site seems to be that you can pump some grease in there but the its not likely to actually get into the birf.
You do not want to over fill it either as that can blow out the axle seal.
When you do a repack you are supposed to pack it 3/4 full to allow for thermal expansion. If you do not know the history of the vehicle then plan a front axle repack.
__________________ ___________________________________
FZJ80KIDPEN
96' FZJ80 186K miles
285/75/R16,OME 850/860's,locked,LED's
Homebrew Rear Bumper and sliders, Flareless and Line-X |
12-31-06, 11:06 AM
| | 250+ Club
| I agree that if you have sings of failure you should plan on a repack. Adding more lube may prevent further damage, but if there is noise some damage has allready occured. There have been some test lately using differant colored greeses to see if lubeing through the fill hole does indeed get to the birfs, and in every case there was evidnence of that it does.
__________________ 97 TLC, 176k, Locked, CDL/7pin, 285 MTR, yellow box, ARB, slee headlights, so much more I want.......
01 Honda Civic LX - 42mpg baby! Quote:
Originally Posted by ed97fzj80 Alternatively, God reserves a certain luck for fools, children, and the criminally insane. | WTB: OME 850 & 860 springs!!!! |
12-31-06, 11:13 AM
| | ThinkTank Waterboy
| I did an axle job for another member who pumped grease into his knuckles. What a mess I'll see if I can find the thread.
Found it enjoy
__________________ Rick Bigelow
'96 215k
Groveland MA 01834
If you're not the lead dog, the view never changes |
12-31-06, 11:25 AM
| | Parts Geek, M1 Mechanic
| Quote:
tia |
You can pump greas into the knuckles till the cows come home and it will never get to the spindle bushings.
__________________ Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock and a lumpy old Dodge car. http://i487.photobucket.com/albums/r...Gastrap063.jpg http://i487.photobucket.com/albums/r...frifles004.jpg |
01-01-07, 02:09 PM
| | Forum Regular
| it sounds like metal on metal slowly turning making a sort of grinding sound. it only happens at speeds under 30mph. i had the same thing happen when i first bought the truck, but Koffer helped out by greasing the knuckles and zirks, which did help until now.
i plan to repack the birfs once i find someone to help! but for the short term, i'd like to get a little extra grease in areas mentioned to (i hope) help.
interestingly, the sound stopped the next day and hasn't made a peep since. regarless, i still want to lube my bitch up.
then.... tune up, phh, starter contacts ac recharge, flush radiator....
01-01-07, 04:28 PM
| | 250+ Club
| What about you EGR vacuum modulator? Does it have a blue or green top?
Blue it new=good, green is old= call Dan. Its only about $55
FZJ80KIDPEN
01-02-07, 04:07 PM
| | Forum Regular
| Quote:
Originally Posted by fzj80kidpen What about you EGR vacuum modulator? Does it have a blue or green top?
Blue it new=good, green is old= call Dan. Its only about $55 | i have to check...
w/out doing a search, what does the EGR vacum modulator do?
01-02-07, 06:56 PM
| | You want to do what...?
| Quote:
Originally Posted by tea LC i have to check...
w/out doing a search, what does the EGR vacum modulator do? | modulates the EGR vacuum?
(then again it could be that it vacuum modulates the EGR?  )
__________________  : '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!  : '03: 115K
DDs: Accord, Prius  : souped-up DR650 |
