LinkBack (29) Thread Tools Display Modes
Old 12-27-06, 03:44 AM   29 links from elsewhere to this Post. Click to view. #1 (permalink)
Bear80's Avatar
TLCA# 14779
ROTW Bear80
--Updated--
Details as of 10/07: http://forum.ih8mud.com/vbpicgallery.php?do=view&g=790
My apologies for the delay in my rig’s debut and for this work in progress thread. I had planed for my write-up to be completed last week and ready to post Sunday but as usual my plans got offset and then even more so with the holidays.
Thanks to Woody and those others who keep this site so well organized and maintained, especially Romer here in the 80 series corner. There are also so many great people here that have contributed time and energy helping others with questions and innovative ideas to make this such a great forum.
I’ve lusted after the 80 series since I started getting into that teenage car crazy phase around the final years of their production. I still remember seeing the National Geographic expedition across Antarctica with two decked out 80s and thinking to myself “man those have to be the most awesome Toyotas ever!” Since then I’ve always wanted one, and my parents where gracious enough to get me my own so I would stop drooling over my Fathers’. So as soon as the previous owners got it broken in, I picked up my 1997 Emerald Pearl 40th. Ed.
Notable maintenance:
Castrol 5w-50 (use to run Mobil1 15w-50 but picked up an average of 1.5mpg with the Castrol and cheaper)
K&N oil filter HP3001
Transmission fluid exchange with pan removal + Mobil1 synthetic ATF
Valvoline dura-blend gear oil in the axles
Valvoline synthetic in the T-case
Complete flush of brake fluid + Valvoline synthetic DOT4 fluid
Coolant flush + Toyota Red
EGR modulator replaced
Replaced the steering column seal on the fire wall
Toyota belts
Rapid Fire plugs
Front/Rear Rotors with NAPA 100series ceramic pads
Rebuilt Birfields
New rear wheel bearings/seals
New front main seal, oil pump seal, distributor o-ring
PDR for the few door dings
Bumped timming up to 8-9* BTDC
Die Hard International battery (according to the specs its almost within the range of deep cycle batteries)
9006 Silver Star Ultra bulbs in the low beam housing
What's left:
Rear main seal, oil pan re-seal (after doing my sisters oil pan, I've been seriously reconsidering doing mine)
Rebuild drive shafts with new u-joints
I had also planed to have a few more modifications finished by the time my turn for ROTW rolled around but with my '86 pickup taking up all my project time I fell a little short. So here's a list of what I should have had done and is now waiting for me:
1) Mile Marker 9k hydraulic winch with interior mini truck antenna switch
2) Angle iron added to rear lower arms
3) Rear cargo light
4) Replace dash and headliner speakers with infinity kappa tweeters + crossovers, stock door woofers.
5) Tie in 4 channel Optimus (Pioneer) amp in place of stock amp for use with stock head unit
6) Cobra CB in ash try slot
It's a shame to have stuff setting around mocking you....
40th FZJ80 - Range Rover Recovery Vehicle
Alamo City Land Cruisers
-Benjamin-
Bear80 is offline   Reply With Quote
Old 12-27-06, 03:47 AM   #2 (permalink)
Bear80's Avatar
TLCA# 14779
Well first I had to get some new rubber in the flavor of Pro Comp Xterrain's 305/70R16. Which runs a little on the short side of a true 33" tire. New, the tires are just all around great but they get A WHOLE LOT LOUDER as they wear and even "zero'd out" balanced they like to kick around on the highway and give a shimmy. Also I've found as they wear the dreaded 10-15mph direction tread rumble gets worse and worse. But at the 1/2 way point they are doing well with around 35k miles and I expect to get at least 50k out of them. I also installed Slee Off-Road's speedometer gear, which is dead on at 70 according to my GPS.
Also I started on Phase1 of my custom painted center caps:
-Benjamin-
Old 12-27-06, 03:48 AM   #3 (permalink)
Bear80's Avatar
TLCA# 14779
Along the way I also put in some OME 851s + 1" spacers up front and the 860s in the rear, teamed up with Edelbrock IAS shocks. Corrected the castor with the OME bushings. About that same time I pulled all my flares to replace the rubber trim. Running around without flares got old after a few days and I stick with my opinion that the flares look much better on.
Also I ditched the running boards and trailer hitch. I put on a Valley pintal/ball combo and added Warn 6" 4x spot lights on the damage multiplier with a stock interior fog light switch. MOT also hooked me up with the very cool crystal version tail lights and front turn signals. I then later picked up matching front side markers. I also took silver bumper paint and repainted the hard plastic on the door moldings. The look with silver is a nicer match with the dark emerald green than the standard dark gray.
This was also Phase2 of the center caps, chrome paint with the gray center.
-Benjamin-
Old 12-27-06, 03:49 AM   #4 (permalink)
Bear80's Avatar
TLCA# 14779
Recently I added an ARB front winch bumper and painted it a two tone with bronze hammer finish. I also painted the rear TJM bumper the same, leaving the black plastic trim for a two tone. The rear bumper has a tire carrier which I do not run since I have spaced up my stock under carrier (another one of the great little ideas picked up from this forum). I also bought some driving lights from O'Riley's to put in place of the ARB supplied orange turn signals. All I had to do was bend the mouting tabs on the lights and they made a near perfect fit in the bumper. As for the rear I would like to find a light that fits in the bumper and replace the stop/turn light for use in reverse. Also included in the rear bumper deal was a new pintal/ball hook which has a much cleaner look than the Valley I had before. For added strenght around the pintal hook mounting holes I had a 3/8" plate welded on the back side of the bumper.
Phase3 center caps....NO CENTER CAPS. Acutally I'm in the process of striping and repainting them with the same style of Phase2 but with sivler bumper paint and a clear coat.
Here's a shot of the pintal hook plate I added, as you can see the bumper still flexs in but 3/8" was close enough.
-Benjamin-
Old 12-27-06, 03:50 AM   #5 (permalink)
Bear80's Avatar
TLCA# 14779
As for tid bits in the interior, I haven't got too much added yet. I did pull all the wood trim and relocated my 40th serial plate. I have a center console out of a LX450 that is waiting to go in just as soon as I get the matching trim that goes down the door panels and a matching wood steering wheel.
I also have an auto dimming rear view mirror that I would like to upgrade to a unit that shows outside temps.
The usual stuff I did add like the cup holder, a center diff lock switch with the #7 pin pulled and the winch idle up control. Also on the lower part of the dash under the rear heater control I put my bass-link level control. As for the bass-link it sets perfectly in the corner between the rear gate and jump seats. I also added a small 400watt power inverter to power my Toshiba lap top that I run MS streets and trips with GPS, Back Roads Topo and Pro Scan OBDII on. I have plans to add a larger power inverter in the back panel with an outlet up front and one in the back along with a 12volt outlet. I also have insulating heat/sound mat under the whole lenght of the carpet that I picked up from Pep Boys. It really keeps the heat down on the passengers side from the cats and transmission.
I also have an Audiovox remote start/alarm. Which you know is an absolute must in south Texas....for the a/c!
-Benjamin-
Old 12-27-06, 03:52 AM   #6 (permalink)
Bear80's Avatar
TLCA# 14779
Future plans include:
Laptop mount
Replace a-pillar grab handles to early '97 style
Add driver side handle
Super Swamper SSR 305/70R16 = 34x12.50
Either Js or Slee Off-Road 4" springs, castor plates and L shocks
Custom Sub fuel tank
Roof Rack
Sliders
A/C Dryer protection
HIR in high beam housing + new headlight harness
Weather proof relay/fusebox for lights
New fan clutch fluid
Aux pusher fan
-Benjamin-
Old 12-27-06, 03:53 AM   #7 (permalink)
Bear80's Avatar
TLCA# 14779
And since I don't have a laundry list of cool mods, enjoy some pictures of the cruiser and me having a good time.
North of Phoenix, AZ
Big Shell, TX
Snow covered Crown King, AZ
Barnwell Mtn, TX
Crown King, AZ
Florance area, AZ
-Benjamin-
Bear80
This message has been deleted by Bear80.
Old 12-27-06, 03:54 AM
Bear80
Old 12-27-06, 04:25 AM
Bear80
Old 12-27-06, 04:39 AM   #8 (permalink)
Felt's Avatar
Eh?
Felt is offline   Reply With Quote
Old 12-27-06, 06:42 AM   #9 (permalink)
drsales's Avatar
Nice job. You have done well, I hope to take my 80 in the same direction as you! If you were to do it again, would you do your mods in the same order? If not please expalin. Thanks
95 FZJ 80, Locked, 226k+, Original Stocked & HG, George's Map and Dome, PHH, Mobile 1, Slee Wire Harness, J.Deere Lights, 100 Series Pads, upgraded Stereo w/ XM and lots of Dynamat. Lost to the boys.
2000 100 series with 160k. Mobile 1 oil, diffs, trans and transfer. JD low beams. Upgraded stereo & speakers, Dynamat doors.
drsales is offline   Reply With Quote
Old 12-27-06, 07:28 AM   #10 (permalink)
mot
I ruin surprises.
mot's Avatar
Ben,
Awesome-looking rig!
You're REALLY jammin' now, baby!
Keep up the good work, but don't drink and drive.
Mot
mot is offline   Reply With Quote
Old 12-27-06, 07:30 AM   #11 (permalink)
Bear80's Avatar
TLCA# 14779
Well I'm happy with the path so far. My biggest issue is now lift higth since the weight of the bumpers pulled it down quite a bit, so I have to upgrade. But I do like the order I did most other mods in. Also an issue I had with the lift was I had to keep low because anything higher and I wouldn't fit in my old single panel garage doors. I say it greatly depends on what you want your rig to do, I wanted somthing I could enjoy but nothing hard-core, so for example bumpers and sliders where low on the list vs. lift and tires. Even with the new bumpers I don't want to have to "use" them, especially after I got them all pianted up.
-Benjamin-
Old 12-27-06, 07:41 AM   #12 (permalink)
sseaman's Avatar
nice ride and pics
98 4runner 150k
04 Sequoia 85k 4x4 Limited
sseaman is offline   Reply With Quote
Old 12-27-06, 07:41 AM   #13 (permalink)
airlaird's Avatar
Great truck Bear....what exactly did you do to the trim molding...is it factory? It appears it does not fit end to end of the vehicle and seems to be wider...or is that an illusion?? What paint did you use?
airlaird
airlaird is offline   Reply With Quote
Old 12-27-06, 07:49 AM   #14 (permalink)
Bear80's Avatar
TLCA# 14779
airlaird
Just the factory door molding. If you're looking at the picture of my junk without the flares, then yes the molding doesn't look right. It's short due to the width of the flare on the fenders. Which is probably why I really dislike the flare-less look. But the paint I used was silver Dupli-color bumper paint. All I've seen is either silver, gray and black so it should be esay enough to find. I'm behind as hell on this rig of the week, I should be calling it rig of the mid-week or somthing. I'll try and get some close ups of the trim and some other stuff later today.
-Benjamin-
Old 12-27-06, 08:02 AM   #15 (permalink)
fatherofdaughterofromer
Romer's Avatar
TLCA# 13968
Garage
Nice write-up and thanks for contributing. Curious about the Castrol oil giving you better gas mileage??
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Romer is offline   Reply With Quote
Old 12-27-06, 08:21 AM   #16 (permalink)
Bear80's Avatar
TLCA# 14779
Well I was getting about 11 maybe 11.5mpg with Mobil1 15w-50. When I went to Castrol 5w-50 I got up in the 12's. Then bumping the timming up got me to 13 maybe 13.2ish.
-Benjamin-
Old 12-27-06, 01:28 PM   #17 (permalink)
Ting's Avatar
Very nice - Thanks for sharing. Nice pictures too.
96 Kazu; 96 LX450, 97LX450 Blowed
Ting is offline   Reply With Quote
Old 12-27-06, 02:58 PM   #18 (permalink)
Capocaccia's Avatar
Nice rig!
1996 LX450. 33" BFG A/T TA KO, TJM T17, OME 2.5 Hvy, Warn X8000i
ATΩ
Capocaccia is offline   Reply With Quote
Old 12-27-06, 03:01 PM   #19 (permalink)
latinoguy's Avatar
Nice Rig Bear
"Bumped timming up to 8-9* BTDC" What performance increase do you get by doing this? How does this affect engine wear or MPG?
James
97 FZJ80, "La Mula," ARB, HIDs, Tire Carrier, Sliders, OME 850J/863 springs, L shocks, 295/75/R16 ATs, Slee TC Skid Plate, Rear Storage, CB, LEDs, SS Brake Lines, Rear work lights, HIRs, CDL pin 7
01 325I Sport Packaged DD
http://bohemianjsr.blogspot.com/
latinoguy is offline   Reply With Quote
Old 12-27-06, 03:12 PM   #20 (permalink)
Bear80's Avatar
TLCA# 14779
Here's a few close up of the door moldings for ya airlaird, sorry I don't have a before and after. The stock color of the hard plastic is darker gray then the center soft plastic part and now with the hard plastic silver the soft plastic part is darker.
-Benjamin-
Old 12-27-06, 03:19 PM   #21 (permalink)
Bear80's Avatar
TLCA# 14779
Originally Posted by latinoguy View Post
Nice Rig Bear
It's been disscused here on 'mud and it started I think with the aussie guys. With the 33" tires and the timming bump, the rig is snappy off the line and takes much less effort to cruise with the fast movers on the highways. Infact most of the time going up hills it usally only comes out of the torque converter lockup, it doesn't even down shift. But with a supercharger you cannot bump up the timming.
As for mpg, as I said I gained about another 1mpg with it. Engine wear, my main concern is it running hotter. Which is why I plan to get some new fluid in my flan clutch before it turns hot down here again.
Also "spark knock" can occur with 87 octane, I just went ahead and put in only 93 octane.
-Benjamin-
Old 12-27-06, 03:20 PM   #22 (permalink)
Unleash the Beast
LX_TREME's Avatar
TLCA# 4500
Nice, the pintle hook pic is that capacitor? If im right what is it for? to slow down your LED?
LX_TREME is offline   Reply With Quote
Old 12-27-06, 03:23 PM   #23 (permalink)
Bear80's Avatar
TLCA# 14779
Naw, it's for the trailer harness.
-Benjamin-
Old 12-27-06, 04:02 PM   #24 (permalink)
clean and pretty
97lx450
1 tons and 42's
4" slee coils, sliders, bumpers, 3" exhaust, custom turbo, HG pm/Valve job/seals, sweet custom skid plate, Sleeoffroad parts, Buys oe parts from Cruiser Dan
my build
http://forum.ih8mud.com/hardcore-cor...j80-build.html
98 100 series. rear locker.
2008 6.7L dodge 2500 quad cab
ezgo electric golf cart crawler build pend....
2002 porsche C4S
Dusty is offline   Reply With Quote
Old 12-27-06, 05:51 PM   #25 (permalink)
Looks good!
mnewell is offline   Reply With Quote
Old 12-27-06, 07:51 PM   #26 (permalink)
cc93cruiser's Avatar
TLCA# 15132
Bear 80, what is the deal with the timming being bumped up to 8-9* BTDC? Did you get any performance gains, enough to feel the difference? Thanks.
Robert Muniz
TLCA#15132
1993 Toyota Land Cruiser 217K
3x locked+4.88's+315 BFG AT&MT+SAFARI SNORKEL+SLEE 4"LIFT+TACO FR DC DS+ARB FR+WARN M12000+HANNA RR+SLEE SLIDERS+SLEE SKID+AO DRAWERS+ARB FRIDGE+DUAL OPTIMAS+GARVIN RACK+IPF'S+OKOLE COVERS+HUSKY MATS+POLY REARS+
-LONG INNERS+NF BIRFS
cc93cruiser is offline   Reply With Quote
Old 12-27-06, 08:19 PM   #27 (permalink)
tlcwagons.org
FirstToy's Avatar
cool!
That second pic is funny, it looks like you're rubbing the side, "OOOHHHH, 80 series....." hahaha
I like that TJM, never seen it on a 80 and looks clean! Looks really nice w/o the tire on there too.
the ARB signals are cool, I might have to jump on that mod. What's O'Reily's? got a link?
I love cachapas!
my wip
The Original blister©
I drink your milkshake!
Old 12-27-06, 10:06 PM   #28 (permalink)
Brian Macgyver's Avatar
Nice job. I was going to suggest my cure for your original brush-guard/damage multiplier. My 80 had the same one on it when I got it. It came from San Antonio. I chop-sawed mine and put a real bumper and winch under it.
A guy here likes mine and wants similar. I wonder if your old one could get to AZ at reasonable cost? You could chop it off at the top of the bumper to ease transport. We only need the top part of it. PM me....?
Brian Macgyver is offline   Reply With Quote
Old 12-28-06, 01:33 AM   #29 (permalink)
Bear80's Avatar
TLCA# 14779
Originally Posted by FirstToy View Post
cool!
Yep that was pretty much the maiden wheeling trip and you know I have to give the 80 some love.
As of the lights, I'm in the process of moving and the box they came in is not with me here. I can get the model number and such later but I recall it was the Blazer brand, maybe...
-Benjamin-
Old 12-28-06, 01:34 AM   #30 (permalink)
Bear80's Avatar
TLCA# 14779
Sorry I sold it months ago on ebay to a guy in AZ, it went for a killing. Infact, so much so it almost paided for my ARB.
-Benjamin-
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/127479-rotw-bear80.html
Posted By For Type Date
my step dad is stuck - TTORA Forum This thread Refback 10-11-09 11:36 AM
my step dad is stuck - TTORA Forum This thread Refback 09-10-09 06:39 PM
4runner tail gate needed - TTORA Forum This thread Refback 08-11-09 09:53 AM
TTORA National at Superlift OHV Park - TTORA Forum This thread Refback 08-09-09 04:19 PM
TTORA National at Superlift OHV Park - TTORA Forum This thread Refback 08-09-09 04:13 PM
Got a new TOY! - TTORA Forum This thread Refback 07-28-09 10:32 AM
TTORA National Takeover - TTORA Forum This thread Refback 07-13-09 08:05 PM
1986 Pickup xtra cab 4x4 - TTORA Forum This thread Refback 06-22-09 10:09 AM
1986 Pickup xtra cab 4x4 - TTORA Forum This thread Refback 06-20-09 10:46 PM
Boulder creek May 1-3 - TTORA Forum This thread Refback 04-28-09 10:42 AM
Parting out 1998 4runner ltd - TTORA Forum This thread Refback 04-26-09 08:51 AM
Headed to San Antonio... - TTORA Forum This thread Refback 03-26-09 09:40 AM
Broken locker pins -- day old lock right!! - TTORA Forum This thread Refback 09-17-08 01:13 PM
Texas TakeOver 2008 - OFFICIAL THREAD - TTORA Forum This thread Refback 09-09-08 01:11 PM
Any 4Runners out there? Lets see em... - Page 32 - TTORA Forum This thread Refback 09-08-08 10:10 PM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-29-08 01:30 PM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-26-08 08:34 AM
1986 Xtra cab 4x4 - TTORA Forum This thread Refback 06-25-08 12:15 AM
March Madness Wrench Taco Party - TTORA Forum This thread Refback 06-22-08 09:15 AM
Toy tech lift for 2005 step side trd 4wd question - Tundra Solutions Forum This thread Refback 03-24-08 11:58 PM
ACLC Big Shell April 4-6 - TTORA Forum This thread Refback 03-18-08 01:25 PM
TTORA Forum - View Profile: Bear80 This thread Refback 03-03-08 07:35 PM
Toyota EPC (Electronic Parts Catalog) - TTORA Forum This thread Refback 03-01-08 07:16 PM
TTORA Forum - View Profile: Bear80 This thread Refback 03-01-08 12:58 PM
Land Cruise Roundup, Katemcy - TTORA Forum This thread Refback 02-23-08 07:55 PM
Toyota EPC (Electronic Parts Catalog) - TTORA Forum This thread Refback 02-15-08 07:20 PM
Toyota EPC (Electronic Parts Catalog) - TTORA Forum This thread Refback 02-15-08 07:48 AM
Lets see those Trucks... - Page 7 - TTORA Forum This thread Refback 01-30-08 09:14 PM
Home Piano Bar - TTORA Forum This thread Refback 01-25-08 02:52 PM
