80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 12-22-06, 01:31 PM   #1 (permalink)
slick621's Avatar
Lock tite on front control arm bolts?
Just swapped the bushings in my front control arms for OME Caster Correction Bushings. However, the shop I took my control arms to threw away the directions.
I remember reading about applying Lock Tite to the bolts upon reinstallation. Can anyone confirm this and what type of Lock Tite?
The FSM says nothing about Lock Tite or anything similar . . . good idea, bad idea?
Thanks!
'96 FZJ80
OME 2.5" 850/860, BFG MT K/M 255/85R16, Slee Skid Plate, SROR Sliders
slick621 is offline   Reply With Quote
Old 12-22-06, 01:37 PM   #2 (permalink)
ThinkTank Waterboy
landtank's Avatar
I've never used locktite on them. The base of the nuts have an edge to them to stop them from backing out. That is why you should turn the bolt and not the nut when loosening them.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 12-22-06, 01:37 PM   #3 (permalink)
Parts Geek, M1 Mechanic
cruiserdan's Avatar
New factory bolts have a thin coating of some type that is reddish.
According to the factory manual tha fasteners should not be re-used.
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
cruiserdan is online now   Reply With Quote
Old 12-22-06, 02:02 PM   #4 (permalink)
I think the instructions suggest that you replace the bolts.
I cleaned up the threads, used blue loc-tite, and staked the nuts after torquing them up to 180lbs.
"Stupid things, happen to smart people that are affraid to ask stupid questions"
93 FZJ80 Full Load w/lockers, 2.5 OME, #7pin/CDL, Custom Bumper w/M8274, 315 MTZs
78 FJ40 Retired.....never left me, not once.
81LJ, 89JLX, 01Vitara SUZUKI wifemobiles (the only other 4X4 to own)
76 Chevy PU 292 6cyl, Restored w/collector plates
If you find yourself Lost, Stranded or Thirsty in Southern B.C. CONTACT a recovery team.
MARLIN375 is offline   Reply With Quote
Old 12-22-06, 02:12 PM   #5 (permalink)
Tools R Us's Avatar
The factory torque is 130 ft·lbf on the frame end and 127 ft·lbf at the axle. Mine have been out at least a half a dozen times, never used loc-tite and never had one loosen.
Copper State Cruisers #007
Tools R Us is online now   Reply With Quote
Old 12-22-06, 02:48 PM   #6 (permalink)
I will have to edit my Haynes Manual it says 181 on the axle end and 130 on the frame end..............with original fasters.
Maybe 130 is correct because you are using new fasteners each time (as toyota recomends).
Are the torque specs different in the FM for the rear arms?
Old 12-22-06, 03:02 PM   #7 (permalink)
Tools R Us's Avatar
Upper and lower rears are 130 ft·lbf.
Old 12-22-06, 03:29 PM   #8 (permalink)
slick621's Avatar
Alright thanks
'96 FZJ80
Old 12-22-06, 11:05 PM   #9 (permalink)
Danke!
-Spike-'s Avatar
I use Loc-Tite on every suspension bolt after having the nut disappear from my front trackbar... twice. I may have left it loose the first time, but definitely not the second. The way I see it, blue Loc-Tite can't hurt anything. Red, on the other hand...
-Spike
His 1994 TLC 'White Elephant' +6"/37" Locked.
Hers '95 TLC Bare bones.
"I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown
-Spike- is online now   Reply With Quote
