80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 12-15-06, 03:25 PM   #1 (permalink)
MTBGUY's Avatar
Winter/summer seasonal thermostat
Anyone here ever consider a 160 degree thermostat for the summer and then use the stock 180/190 for winter?
I have had black cars that ran slightly warm in the heat of Texas summers, and this worked great for years- change them in April to 160 degree T-stat, then stock from October to March. Seems like it would help all round on the Cruiser also.
My rig stays pretty normal on the temps, but I plan on replacing the radiator and clutch next year as P.M>.
Any thoughts on this!
Rick B.
97 40th Dark Green, 82K
Mostly Stock
MTBGUY is offline   Reply With Quote
Old 12-15-06, 04:48 PM   #2 (permalink)
always broke
alkaline747trio's Avatar
I like that idea, is the 160* OEM?
What?
Upstate Cruisers
alkaline747trio is offline   Reply With Quote
Old 12-15-06, 04:56 PM   #3 (permalink)
Scamper's Avatar
It's been discussed a number of times. I recall the general consensus was that the engine was designed to run at the factory spec (190* if I'm not mistaken) and that running it cooler will only decrease the efficiency.
Tom
'97 FJZ80 CE sans the manly lockers but with the manly Kazuma SC...it blows, and it's a good thing
AirLift1000 with Load ControllerII and Slee Dashboard Beverage Restraint System
'02 MR2 Spyder
'01 Avalon
...long live the Scamp...the Scamp is gone
Scamper is offline   Reply With Quote
Old 12-15-06, 05:16 PM   #4 (permalink)
always broke
Correct, but a good cheap band-aid if you normally run hot.
What?
Upstate Cruisers
Old 12-15-06, 05:34 PM   #5 (permalink)
Parts Geek, M1 Mechanic
cruiserdan's Avatar
No, actually it's not. It only delays the over-heating. BTDT.
The engine is very inefficent below 180 degrees. In addition the warmer the engine the lower the wear.
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
cruiserdan is online now   Reply With Quote
Old 12-15-06, 05:36 PM   #6 (permalink)
always broke
It delays the overheating/getting hot (two close but different things), which is a cheap band-aid. Not the best idea in the world though.
What?
Upstate Cruisers
Old 12-15-06, 07:21 PM   #7 (permalink)
MTBGUY's Avatar
Probably a silly question, but what is BTDT? I thought you meant before top dead center but that can't be right.
I understand the temp+efficiency thing, just thinking that if many Cruisers always run 20 degrees warm in the heat, then the 160 would bring it down to around 185 or so.
After living in Texas for many years I lived in Alaska for 4, and there I ran a 195 degree one in the winter and standard thermostat in the summer, which worked pretty well and made me start thinking about this whole idea.
Thanks again for all of the great ideas everyone!
Rick B.
Mostly Stock
Old 12-15-06, 07:27 PM   #8 (permalink)
Wrench Bender
RavenTai's Avatar
those who run warm when they pursue the problem are able to make it run properly in any condition with the stock thermostat.
1988 FJ62 on 33s
1996 LX450 on 33s
RavenTai is online now   Reply With Quote
Old 12-15-06, 07:29 PM   #9 (permalink)
MTBGUY's Avatar
My new (Toyota) one was marked 82C, which equates to 180 degrees fahrenheit. I really need to get a FSM to know what factory spec actually is! I don't know if Toyota makes another one without going aftermarket.
When I pulled the one out of my Cruiser (that wasn't Toyota) with the new OEM one from Dan, the difference in construction was amazing. Nothing compares to Toyota engineering.
Rick B.
Mostly Stock
Old 12-15-06, 07:31 PM   #10 (permalink)
MTBGUY's Avatar
When I change the radiator next spring/summer I want to replace my plastic tanked 97 model with one of the all-metal ones. I searched but couldn't find it- was 94 the year that Toyota had an all-metal one that will bolt right into my 97?
Thanks!
Rick B.
Mostly Stock
Old 12-15-06, 07:48 PM   #11 (permalink)
Wrench Bender
RavenTai's Avatar
93/94 has a copper/brass head exchanger instead of aluminum but the tanks are still plastic. it is a direct bolt in on 95-97 trucks.
there are all metal after market radiators but they are a pig in a poke, fit quality and life expectancy vary widely. their life is almost always shorter than the plastic tank OEM radiator.
1988 FJ62 on 33s
1996 LX450 on 33s
Old 12-15-06, 08:06 PM   #12 (permalink)
cruiserdan's Avatar
Been There, Done That.
Old 12-16-06, 08:36 AM   #13 (permalink)
MTBGUY's Avatar
AHA! Learned a new expression today. Thanks- looks like I'll be getting a new 93/94 radiator and clutch from you in the near future.
Rick B.
Mostly Stock
Old 12-16-06, 10:02 AM   #14 (permalink)
hadji_85's Avatar
wouldn't you want the engine to say the same temp regardless of the outside conditions
in which case you would only want one thermostat?
1st LC '96 FZJ80 stock lockers 32" kumho road ventures, gonna be stock for a while until i get caught up on maintenance
hadji_85 is offline   Reply With Quote
Old 12-16-06, 12:50 PM   #15 (permalink)
cruiserdan's Avatar
Yes.
