01-24-07, 09:07 PM
#31 (permalink)
Originally Posted by concretejungle
yes, please do tell. I have a terrible suspision that i may be having some of the same issues.
When i turn sharp in a parking lot, i feel an almost wiggle as if a wheel is loose, or an inner wheel is binding.
Don't forget that it's easy to test...
01-24-07, 09:08 PM
#32 (permalink)
ThinkTank Waterboy
I get a groan from somewhere when I shift from D to R or vice versa. I've suspected the VC for 4 years.
Rick Bigelow
'96 215k
Groveland MA 01834
01-24-07, 10:19 PM
#33 (permalink)
Rick,
I get a muffled groan also once in a while on D to R in the 97 - never on the 93. Almost a brief hydraulic whine - perhaps .5 seconds.
Hey for you guys thinking of opening your VCs just a word of warning to be cautious in case there's a pressure buildup of some sort in it. I honestly don't know if it can still exist after the unit's cool but I know in operation they can have tremendous internal pressure from heat. Use caution, eye protection, condom, etc
DougM
01-24-07, 10:32 PM
#34 (permalink)
Originally Posted by Romer
Did this fix Ironpuppy's binding issue? If so, pictures of the coupler with a guess what caused it would be useful in this thread.
I'll post an update after a test drive.
If IronYuppy gives his permission, the VC unit may have a play date with Makita and Zip Cut
1989 BJ74 LX - Extreme Valve body, Mark's gears, factory winch, custom 3" OME lift, 24V Warn VTC Compressor
1987 HJ61 VX 5spd - loaded - daily driver
1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa
1990 HZJ73 ZX - PTO winch, lockers, 68k Kms
01-25-07, 09:16 AM
#35 (permalink)
I've checked for loose wheel bearings, but i have not tried to put it on jack stands and try to lock the CDL and see what's spinning.
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
01-25-07, 11:31 AM
#36 (permalink)
Hell, yeah, let the autopsy begin!
'94 lockered FZJ80
"Fish and plankton and sea-greens and proteins from the sea" - BOX
01-25-07, 11:42 AM
#37 (permalink)
Don't rely 100% on that test. I did the same thing, and everything appeared normal. I guess it depends on how much resistance the viscous coupler gives when you're spinning the wheels freely.
The hard-boiled test was to lock the centre diff lock in high range, remove the front shaft, and go for a drive. In my case, disengaging the front axle from the drivetrain cleaned-up all the noise/binding issues, so that proved the problem was somewhere at the other end of the driveshaft.
'94 lockered FZJ80
01-25-07, 03:27 PM
#38 (permalink)
You did the following test, and the raised wheel spun freely??
Originally Posted by MikePL
Another way to find out if your VC is dead is to raise one wheel (tranny in N, transfer case in N). In the N/N position the wheel should move rather freely when you rotate it by hand.
01-25-07, 04:24 PM
#39 (permalink)
yup.
'94 lockered FZJ80
01-25-07, 04:29 PM
#40 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
that test works great to find a locked up VC, if you are getting binding from the VC wile driving but not static you should look very closely at all your tires and make sure they are all the same size.
1988 FJ62 on 33s
1996 LX450 on 33s
01-27-07, 09:20 PM
#41 (permalink)
fatherofdaughterofromer
Ironpuppy, did this fix your binding problem?
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
01-28-07, 12:43 AM
#42 (permalink)
Yes, 110%. The love affair is back on.
'94 lockered FZJ80
03-15-07, 12:31 AM
#43 (permalink)
Does anyone have the part # and/or price for the Viscous Coupler? I have tried to find it at my local dealership parts counter and we can't figure out which part it is on the expanded parts screen. I don't know if we're looking at the wrong page or what.
If the cost is to high then I am going to look at buying Slee's part time 4wd kit.
Thanks!
95' FZJ80, OME Heavies, ARB Locked F/R, CDL, 4:88's, Snorked, Full ARB Safari Rack, ARB front, Warn 9K, SLEE Rear, Sliders, 315 BFG's, HID's plus Hella/KC light bar, Dual Batt's, Norcold 60L
95' Golden Retriever (R.I.P.)
05' BMW R1200GS
78' J**P C*5
89' J**P Sahara
08' Harley Street Glide
03-15-07, 02:11 AM
#44 (permalink)
grown up MOD
Thanks!
Have you called Cdan? He will know the part # I'm sure and will give you a better price than your local dealership. Just 02.
"If it wasn't a Landcruiser and hadn't been built the way it was you do realize you would be DEAD." VA State Police Officer
03-15-07, 03:56 PM
#45 (permalink)
Good point, Thanks!
05' BMW R1200GS
78' J**P C*5
89' J**P Sahara
03-15-07, 04:03 PM
#46 (permalink)
Tortus, what's up? Is yours seized?
Curtis
03-15-07, 04:21 PM
#47 (permalink)
Yeah, it sure seems like it. I have been wondering if it was a problem, I just replaced my U-joints and with both DS's removed, tcase and trans in neutral, I could not rotate the output flanges in opposite directions. I also did the "one wheel off the ground test with both cases in N and DS's installed and could not rotate the tire, I do know that my front locker was unlocked for that test.
There is of course the other problem I am having, my CDL isn't working, I installed the switch, tested it and no locky (lights anyways), put it in 4lo, no locky. Hopefully (I think) it is something where the CDL is staying engaged and I can fix that, but everything I have read indicates that the CDL light would be on if it were stuck in lock. Although I can feel a difference when the CDL is engaged, the output won't rotate opposite each other at all, when the CDL is unlocked there is about 30 degrees or so of opposite direction rotation before the outputs stop turning.
Any other advice/checks?
05' BMW R1200GS
78' J**P C*5
89' J**P Sahara
03-16-07, 12:13 PM
#48 (permalink)
Tortus,
If money is a big concern, don't forget that you can simply remove the VC and run indefinitely without it.
Curtis
03-16-07, 07:31 PM
#49 (permalink)
Thanks CJF, I was thinking that would be my next option, along with adding the part time kit.
Fortunatly/hopefully I won't have to deal with that! I just purchased a used (88k) trany and tcase today   for a good price! I am hoping the VC is good out of the Tcase and I will have the rest for spare parts  Couldn't pass up the deal, so sometime next week I should know.
05' BMW R1200GS
78' J**P C*5
89' J**P Sahara
03-17-07, 10:06 AM
#50 (permalink)
Keep us posted...
03-20-07, 10:08 AM
#51 (permalink)
If anyone has yanked a failed VC, let me know. I could use one for a project...sooo don't throw it out drop me a PM or something and I will pay to have it shipped to me if someone is willing to put it in the mail.
Rich
Richard
71 FJ40...I can't remember all the mods!
07 Tundra CrewMax 5.7
78 Fj40...mostly stock.
So. Cal. TLCA
TLCA#1153
03-20-07, 11:03 AM
#52 (permalink)
Rich
Upsidedown has my failed VC in his shop. He was going to cut it open out of curiosity, but I don't know if he did. If you want it, it's yours. Just let me or Upsidedown know. Shipping from Canada, though... the VC assembly is about 40lbs.
'94 lockered FZJ80
03-20-07, 11:05 AM
#53 (permalink)
BTW, MikePL thanks for the OP. Really well done.
'94 lockered FZJ80
03-20-07, 11:36 AM
#54 (permalink)
I'm glad that you liked it, Iron :-)
rpfzj80, I also have a VC that I don't need but that's too far to send it. Surely someone near you will chime in. What's the project all about? Any attempts to repair a VC? From my understanding of the mechanics of a VC it seems that all the plates are bent and twisted from the heat inside and that causes a seizure. So probably there is no way to repair. But as soon as it gets warm here, I will go outside (no garage) with my cutter and post pics of the internals.
'96 Lexus LX450. 2.1" DIY spring lift. 285/75/16 and bling HID lights
03-20-07, 12:34 PM
#55 (permalink)
Hmmm, that might be a bit costly, but then again ground shipping has gotten cheaper. Does it really weigh 40 lbs...I know they're heavy but that seems high. If shipping was less than say 20 bucks or so, it would probably be worth it.
Anyone near CA have a trashed VC?
Rich
Richard
So. Cal. TLCA
TLCA#1153
03-20-07, 05:14 PM
#56 (permalink)
So let me get this right, because my feable brain sometimes has hard times with big words and numbers.
You can remove the VC without any change in the current drivability of the truck?
How is it off-road without the VC?
Mine turns but sometimes seems like it requires the force of hogan to get the wheel around. I think that just might be how a 10 year old power steering system just is....but then again I can be a hypochondriac sometimes.
1996FZJ80Rescued from Suburbia 4/28/06.
Soon to be reintroduced to it's natural habitat....
Fully inspected and PM'd - Slee SS brake lines - Brass Radiator - Dash lights replaced - *ALL* hoses bulletproofed.
03-20-07, 08:11 PM
#57 (permalink)
Do the "one wheel off the ground" test mentioned (several times?) in this thread.
03-22-07, 08:45 AM
#58 (permalink)
Sooo, anyone else have a trashed VC they would be willing to part with? Near to CA would be ideal...either way my dime for shipping.
Rich
Richard
So. Cal. TLCA
TLCA#1153
09-10-07, 09:59 AM
#59 (permalink)
Kind of resurrecting this thread as it appears I'm heading down this path. I don't have a binding issue, but have a lot of noise at highway speed from the transfer case. Put it up on a lift and put a set of ears on it and the transfer is howling at 45 and above. Both output bearings look good - no play, no seepage.
This sounds like the most cost effective "fix" for my pocketbook. Any other drawbacks and/or issues that have come up now that a few people of have done this?
'77 FJ40 - 3 YO Son calls it "White Truck"
'05 Sienna - because the 100 couldn't handle 4 kids
'06 Tundra - only Toyota truck in the company
Tornado Alley Cruisers
ΒΘΠ
09-10-07, 12:16 PM
#60 (permalink)
Can VC be recharged, in other words, can the silicone fluid be replaced and rejuvenate the VC?
Karl
1997 LX 450 202000kms, locked, 285 Revos, Supercharged.
2004 lx 470 61000kms stock
You cant kill yourself on a pogostick. (Harry Parker, world famous geostatistician)
