11-25-06, 01:03 PM
| | Site Addict
| Shadetree Mechanic Tranny Rebuild (Part 2) Well an end result has come sooner than later. The transmission I rebuilt finally sh*t the bed. In mid to late August while driving down the interstate, the transmission over heated bad enough to start leaking ATF out the from main tranny seal (basically I boiled off the ATF.) My newly added Autometer gauge I put on about a month earlier told me that the temp was well over 260º (the upper limit of the gage), I bet I reached 300º. So it lasted 8 months and a GSMTR trip, not too bad. My purpose in rebuilding the tranny was educational.
The conditions at which the tranny operated at from rebuild to August were mostly a 22 mile round trip to work and back, some highway driving that lasted about 30 miles on the weekend and two very long trips, one to GMSTR and one to Slade Kentucky for some wheelin with some Bluegrass’ers.
Getting the rig back on the road was not so bad. A while back I remember seeing Lowtideride selling an A440F that he had laying around. So over Labor Day I drove down to FL to pick it up. Thanks again Al.
So what happened?
The cause:
Well, if you read the first thread you should’ve picked up several items I did not replace on the tranny. The springs inside the VB were never replaced. In fact, I was even considering not rebuilding the VB at all when I first did it. But since it was down I thought I might as well, I figure it’s better to be a little educated on the VB then ignorant.
As I reassembled the VB I was tasked with putting the springs and pistons back together. This was not hard because the tranny FSM told me what the spring should look like (Number of Coils: 8.5, Length: 25mm, Color: blue, Diameter: 10mm). Well I measured the overall length on some, not all, and found small variations in the length. I was not too concerned about it so I reassembled.
From then until now I have been casually researching the net and asking transmission specials in the Indy area what could have gone wrong for the tranny to over heat like it did. As a result of not changing out the springs in the VB I did not have enough hydraulic pressure at the Lock-up spring(s).
The effect:
As a result of insufficient lockup hydraulic pressure to the torque converter, the lockup would not fully engage. As a result of insufficient engagement of the lockup, heat was able to build up and slowly started to degrade the clutches and brakes inside the tranny.
One of the best explanations on auto tranny and lock-ups is here: Torque converter lockup | Motor | Find Articles at BNET.
In my early research, I came to understand that fluid turbulence generates heat just like air molecules above the trailing edge of a fixed wing aircraft. So thinking that turbulence played a role in the impeller and turbine, I started there to understand the thermal dynamics of TC’s. For whatever reason back in high school I did not take physics class, so I headed to a co-worker, a design engineer, to explain my overall situation and to understand a little bit about the basic principals. I asked the question, why would liquid hitting again liquid generate heat. He could not answer that, so I had to go to anything source to find out.
Although heat is a byproduct of turbulence in between the impeller and the turbine this was not the root cause of the problem. My condition for heat was being generated during highway speeds, when the lockup was supposed to be in effect. I wanted to know a little more about TC’s so I decided to cut mine open to see the internals.
Pics and other info:
Below are the guts of an A440F Torque Converter. This is considered to be a middle stall torque converter based on the angle of the impeller fins. The impeller is the rounded portion of the TC. Note the raised fins toward the end were its cut open. A vertical (raised) fin means it’s a middle stall torque converter. An angled (raised) fin means it’s a low stall TC. Stall is the full engagement of the engine and tranny via the TC, or a 1:1 ratio. You can find the stall speed of the tranny by holding the brakes down and fully pressing the skinny pedal. WARNING, don’t do this for more than 5 seconds or you’ll burn up the clutch packs. Once it’s engaged note the RPM’s, this is the stall speed of the tranny.
Enjoy.
Jimmy.
Pic 1: you can see the entire TC.
From Left to right: Back cover (lockup surface), turbine with lockup, one-way clutch stator, impeller.
Pic 2: Impeller fins.
Pic 3: Oneway clutch stator
Reason: explaination of pics.
11-25-06, 01:05 PM
| | Site Addict
| pics
1: Turbine. This directs the oil to the impeller to create a force needed to turn.
2: Lockup. This plate actually seperates from the turbine and mates against the cover surface at speeds under 40-55 mph.
At speed over 40-55mph the turbine and lockup and back cover come together as one.
3: Lockup seperated ...........................................
Reason: explain pics
11-25-06, 01:07 PM
| | Site Addict
| more pics
Pic 1: Back side of lock up damper with lockup plate off.
Pic 2: Lockup plate .................................................. ......................
Pic 3: Cover lockup surface .................................................. ..........
11-25-06, 01:08 PM
| | Site Addict
| and more pics
Pic 1,2,3: Turbine.
11-25-06, 01:10 PM
| | Site Addict
| and even more pics
This is a reassemble of the TC.
Pic 1: Stator on impeller
Pic 2: Turbine on stator on impeller
Pic 3: Lockup plate on Turbine on stator on impeller.
And not pictured, finally you would have the cover over the lockup.
11-25-06, 01:17 PM
| | Site Addict
| Here's an illustration of the impeller fin direction, They're the raised fins around the outer most circumference of the TC.
Reason: better explaination on fin direction.
11-25-06, 01:58 PM
| | Forum Lifer
| JK,
Well, sorry to see that it didn't work out but that was a mighty impressive rebuild effort. So, I take it these pics are the aftermath of the failure?
DougM
__________________ Buy Head Gasket DVD for you OR for your mechanic HERE
'93 FZJ since new, 2.2kw starter, Revo 275s (Michelin Alpins in winter), locked, big Hellas, rr fog, rr flood, rr Airlift, synthetics, ARB bullbar. 97 FZJ - exact same stuff but Michelin X-Ice in winter. |
11-25-06, 03:04 PM
| | Site Addict
| Doug,
Yep, with the TC out I decided to put the grinder to work. The tranny is still sitting in the corner of the garage cooling off. |
11-26-06, 10:34 AM
| | Forum Lifer
| couple of pics show what is similar to a pressure plate from a manual tranny. Does it behave similarly to a manual tranny?
__________________ '96 his
'97 hers |
11-26-06, 11:35 AM
#10 (permalink)
| | Wrench Bender
| Quote:
Originally Posted by alia176 couple of pics show what is similar to a pressure plate from a manual tranny. Does it behave similarly to a manual tranny? |
that is the lock for the torque converter, it kicks in at highway speed to stop any slip in the TC, improving efficiency and reducing heat in the transmission.
__________________ 1988 FJ62 on 33s
1996 LX450 on 33s |
11-26-06, 11:48 AM
#11 (permalink)
| | 250+ Club
| Jim I would say you are not going to have it done for toys for tots.Glad to hear you have another one to put in.
__________________ 1997 anniversary FZJ80 Factory Lockers,custom sliders,Rebuilt Engine bored .020,Custom winch bullbar bumper. |
11-26-06, 01:54 PM
#12 (permalink)
| | Site Addict
| Ali,
Same concept, force is applied after about 40-55 mpg w/ hydro fluid, like RT stated. I would imagine that the force on the lockup plate/rear cover is similar to a manual trannys preassure plate.
For the 442 and 343 guys, a solenoid is used to send the hydraulic preassure to the lockup which in turns forces the turbine to the cover (and the lockup plate) and sequencually the turbine is connected directly to the drive gear inside the tranny.
The two connection points between the TC and Tranny are:
1. Turbine to the tranny drive gear which is rotating mass.
2. Oil pump to the stator. In these two objects, the oil pump is stationary (bolted to the tranny) and the stator rotates (only in one direction). The stator has a one-way clutch on it which prevents counter rotation. The clutch in the stator is nothing like a clutch say. . like on a manual tranny. The stator uses steel rod in a wedged shaped faction around the circumference to achieve one-way direction. |
09-24-07, 09:01 AM
#13 (permalink)
| | Forum Lifer
| Hows the tranny and t-case holding up? I hope well... |
09-24-07, 10:41 AM
#14 (permalink)
| | Site Addict
| Holding up good. The temp is a little high. Yesterday it got up to 200 while going to and coming from the Hoedown in Attica, IN but hold steady at 190 while on the road after the cool had time to kick in. 3 Weeks ago it got up to 210, 94 degrees outside. I expect the temp to be back to around 170~180 in the Fall/winter time. |
09-24-07, 10:50 AM
#15 (permalink)
| | Forum Lifer
| Hope it holds strong for you...
How big of a cooler you got on it? |
09-24-07, 11:15 AM
#16 (permalink)
| | Site Addict
| Hayden's 12"X11". You don't want the tube with the heat fins, it's not as efficient
as the sandwich plates style with heat fins.
Advance Auto Parts, Discount Auto Parts, Autozone should have them on the shelf. |
09-24-07, 11:55 AM
#17 (permalink)
| | Forum Lifer
| Quote:
Originally Posted by jklubens Hayden's 12"X11". You don't want the tube with the heat fins, it's not as efficient
Advance Auto Parts, Discount Auto Parts, Autozone should have them on the shelf. | I have the same haydens on my PS, hydro set up... |
09-24-07, 12:05 PM
#18 (permalink)
| | Hey baby, scan my QR code
| Sorry to hear about your troubles after all! Impressive effort though, and cool pics.
For those curious, here is a link to the original rebuild thread: Tranny Rebuild -Shadetree Mechanic Style
__________________ '96 LX450, 33" Revos, OME lifted, etc, etc
Love the life you live, live the life you love. -Bob Marley
Selfishness is not living as one wishes to live, it is asking others to live as one wishes to live. -Oscar Wilde Right-click image transloading made blindingly easy. Quote:
Originally Posted by fsusteve What are you talking about bro, I'm a long time gator fan....... | WFC: 0473-9763-9112 |
09-24-07, 05:53 PM
#19 (permalink)
| | 250+ Club
| Thanks for the follow up jklubens.
Do you have any thoughts on shimming the VB springs? The idea would to be to increase the clamping force of the clutch packs and create less slip in shifts due to the higher oil pressure. I have read on a supra site that they suggested this to improve reliablity in high HP/TQ supras.
Any thoughts would be great.
__________________ 96 lx 450 stock, with 285's and R.B. MAF housing.
2006 Sienna LE 8 passanger, 3 kids and Room to spare! |
09-26-07, 10:35 AM
#20 (permalink)
| | 250+ Club
| Lock up stopped working on mine recently. Electrics check out ok but there was no flow through the cooler. Bypassed the cooler but still no lockup. Changed the valve body for one from Rodney, still no lock up. Waiting for a TC from Rodney now, see if that fixes it. Jury is still out as to wether the cooler failed and killed the TC lock up, or did the TC lock up mechanism fall apart and block the cooler? Don't know if the direction of flow etc makes it possible for a TC to kill the cooler.
It's worth checking you're getting good flow through the cooler if you have any transmission heat problems.
Jon.
__________________ Jon m0zxj
01 UZJ100 auto - lifted (AHC & 40mm BL), ARB locked f&r, cryo'd 4.88's, TJM T3 fb, 12k goldfish, sliders, snorkel, rack, 18's, big tyres etc.
93 HDJ80 12v auto - lifted, oem locked f&r, cryo'd 4.56's, ARB front bumper, sliders, 17's, big tyres etc |
