80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 11-20-06, 04:17 PM   #1 (permalink)
Second belt location
Hi, I can see on the pulleys in my 96 LX450 that you can put second belt. Why is it there? Am I supposed to have two serpentine belts?
rhyary is offline   Reply With Quote
Old 11-20-06, 04:19 PM   #2 (permalink)
Rookie
bump, saw the same thing on mine and had same question
alaniverson is offline   Reply With Quote
Old 11-20-06, 06:58 PM   #3 (permalink)
KliersLC's Avatar
There are supposed to be two belts.
They are not serpentine belts but rather V belts. The purpose is to allow you to continue on if you lose one belt.
No problem, I'll just tow the pig to Salt Lake on a UHAUL trailer......
95 T100, beater edition (vacationing in Idaho)
97 Land Cruiser, Collectors Edition
01 Sequoia Limited
02 Camry, Commuter Chariot Extraordinaire
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
KliersLC is offline   Reply With Quote
Old 11-20-06, 07:16 PM   #4 (permalink)
trainrech's Avatar
If you are referring to the belts on the alternator, they come in pairs and it is HIGHLY recommended you buy them as a pair from Toyota. List is around $15 for the pair IIRC.
'77 FJ40 - 3 YO Son calls it "White Truck"
'05 Sienna - because the 100 couldn't handle 4 kids
'06 Tundra - only Toyota truck in the company
Tornado Alley Cruisers
ΒΘΠ
trainrech is offline   Reply With Quote
Old 11-20-06, 10:10 PM   #5 (permalink)
firetruck41's Avatar
x2, buy the matched OEM set of v belts, do not get aftermarket belts as they are ribbed and loud, and not matched.
Ben Silva
IH8MUD Site Supporter since July 2004
1996 Lexus LX 450, 144k, locked, Cooper STT 285s, OME 850/863, Slee Blue CC bushings, CDL/Pin 7, LandTank MAF, Powerstop rotors/EBC Green pads/Slee SS brake lines, Slee headlight harness, HIR mod, DIY installed Viper Remote start/alarm system, Mot JDM passenger grab bar, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter, Raingler Barrier Net
1998 Lexus LX 470, 139k Sold
1993 FZJ80 198k miles Sold
My writeups:
HOW TO: DIY Remote Start/Alarm/Keyless Entry
John Deere HIR bulb mod
HOW TO: Fix your leaky windshield
firetruck41 is online now   Reply With Quote
Old 11-21-06, 12:51 PM   #6 (permalink)
Grench's Avatar
If you have the time and other stuff to buy, give Dan a call and have them sent over.
I've had good luck with Gates belts and Goodyear belts. I've never broken one of them.
Your FZJ80 Land Cruiser/Lexus LX 450 should have three belts. The two interior ones should BOTH be there. Whoever put your belts on last was a Lazy SOB and didn't do it right. That 2nd one isn't a failover/redundancy. You're using them to turn a lot of high torque stuff. A single belt would potentially slip and break very prematurely.
Matched set? Modern manufactured belts are so close in specs within a make & size that you'll stretch them to match when you tighten them. Match the brand and age between the two though.
As for the poor belt thats been doing the job of 2 all this time... Chuck it and replace it with twins.
The outer belt... That one can be an odd dog and hard to source. Cary a spare set of 3 or keep a spare set in the garage. Belts, hoses, clamps, full size inflated spare tire, oil changes... Cheap insurance.
FZJ80 1
1996 MoonGrey FZJ80 140K - Lotsa toys/extras/mods/maint.
FZJ80 2
1996 Red FZJ80 140K- Fac lock. 861/862 OME.
Grench is offline   Reply With Quote
Old 11-21-06, 01:34 PM   #7 (permalink)
beno's Avatar
Yup.
Always carry an extra set...3 belts.
-o-
Onur Azeri
Delta Air Lines: ABQ-FTO
American Toyota: Parts Warehouse
High Desert Cruisers TLCA Delegate
_____________________________________
1997 FZJ80: Edition
2001 V6 Honda Accord Coupe: Beno DD Edition
beno is offline   Reply With Quote
Old 11-21-06, 02:42 PM   #8 (permalink)
Made an appointment to replace the one belt and install a second one
Also, will be doing alignment after mounting the Pirelli ATR (see separate post)
Old 11-21-06, 02:45 PM   #9 (permalink)
Grench's Avatar
No, not replace one and install a second one. You're installing three new belts. The one that was running solo needs to be deposited in your local landfill.
FZJ80 1
FZJ80 2
Old 11-21-06, 08:57 PM   #10 (permalink)
Danke!
-Spike-'s Avatar
I'll second the opinion that matched belts are a necessity. Not two from the same AutoZone, nor even two with similar numbers. Two matched belts, cut from the same stock. Those and thermostats I will never buy anywhere but the Toyota dealer.
You may have only one belt because the other one broke.
-Spike
His 1994 TLC 'White Elephant' +6"/37" Locked.
Hers '95 TLC Bare bones.
"I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown
-Spike- is online now   Reply With Quote
Old 11-21-06, 09:06 PM   #11 (permalink)
Grench's Avatar
The poor guy is going to be going to a parts counter asking for special matched belts.
Make sure the belt brand and part number are the same. Use the number and brand on the belt itself not the cardboard sleeve. You should be fine.
FZJ80 1
FZJ80 2
Old 11-21-06, 09:26 PM   #12 (permalink)
That's how they come at any Toyota dealer.
I disagree, just go to a Toyota dealer, any aftermarket belts will be noticeably loud, as they are all ribbed.
Ben Silva
My writeups:
Old 11-21-06, 09:46 PM   #13 (permalink)
Danke!
-Spike-'s Avatar
All he has to do is ask for the belts for an 80 series LC. The parts guy will tell him that model comes with 2 belts, and will hand him 2 packages. In one package will be two belts, tied together, and the A/C belt will be in the other package. Not all that difficult. The belts for the alternator/fan are sold as a matched pair, one part number. It's really not that difficult.
-Spike
Old 11-22-06, 06:37 AM   #14 (permalink)
stayalert's Avatar
I belt running two belts can let you use less tension which would seem like a good thing.
stayalert is online now   Reply With Quote
Old 11-22-06, 06:44 AM   #15 (permalink)
fzj80kidpen's Avatar
The PO of mine had put on gates belts and although they are good belts they make a lot of noise. Switched to OEM - toyota and much happier.
FZJ80KIDPEN
96' FZJ80 186K miles
285/75/R16,OME 850/860's,locked,LED's
Homebrew Rear Bumper and sliders, Flareless and Line-X
fzj80kidpen is offline   Reply With Quote
Old 11-22-06, 08:16 AM   #16 (permalink)
Work will be done at a local Lexus Dealer.
I will tell them about the belts as advised.
Thanks to all the reply
