| Does Speed Sensor Help Run the Odometer, Speedometer and Tripmeter The Odometer, Speedometer and Tripmeter just quit on me today. I have a flashing "OD off" light which indicates some type of fault. One of the trouble codes is a possible faulty speed sensor. Could this, the speed sensor,possibly be the culprit?
Also, to pull the trouble codes the FSM mentions using an "SST" to connect terminals. What is the SST? Could I use a paperclip?
Just finished pulling the tranny trouble code. (I used a paperclip.)
The code number is: 42 - Defective No. 1 vehicle speed sensor (in combination meter)- severed wire harness or short.
Now, where the heck is the No. 1 speed sensor? What does "in the combination meter" mean?????
__________________ 1994 1FZJ80 - Locked;CDL Switch
Engine: Rotella 5w40; Tranny:Mobil1 Synthetic
Bilsteins:B46-1477 FRONT; B46-1478 REAR
Bridestone Dueler A/T Revo's 285/75/16 on LX450 rims (2nd set)
OME:Springs 850 FRONT/863 REAR
Hanna Quality Rear Bumper
Reason: Update with findings
