11-09-06, 08:57 AM
| | 250+ Club
| Help! What size wrench for spindle / bearing nut? I have a wheel bearing that's about ready to fall off and need to buy a wrench on my way home from work so I can fix it over the weekend. What size do I need? I seem to recall something like a 24mm working on my 40, but its been a while since I had to one apart.
(Just for clarification this is referring to the two large nuts that press the wheel bearings.)
Related question, what do you usually torque those guys at?
Thanks!
Shane
__________________ My Money Pits: '96 FZJ80 - Locked | Safari Turbo w/ Intercooler | Unichip | 3" Exhaust | IPT VB | OME 3" Lift | ARB & Kaymar | Winch | DBA Rotors | Aussie Drawers | HID's | BFG AT's | Dual batts | Turbo timer... Clicky for Pics |
11-09-06, 09:00 AM
| | Forum Lifer
| 54mm
and you need a socket, not a wrench...
Dan
__________________ No problem, I'll just tow the pig to Salt Lake on a UHAUL trailer......
95 T100, beater edition (vacationing in Idaho)
97 Land Cruiser, Collectors Edition
01 Sequoia Limited
02 Camry, Commuter Chariot Extraordinaire
"A vehicle's capabilities are inseparably linked to the mental instability of the driver" |
11-09-06, 09:02 AM
| | 250+ Club
| Quote:
Dan |
Thanks! (That's what I meant.)
11-09-06, 09:05 AM
| | Danke!
| I crank the inner nut to ~50 pounds in several increments, spinning the hub in between, to set the bearings. Then I loosen it and set the preload between 6 and 12 pounds, install the locking ring, and tighten the locknut to around 50 IIRC (someone please chime in on that locknut torque, as I'm not positive). Verify the preload and that should do it.
-Spike
__________________ His 1994 TLC 'White Elephant' +6"/37" Locked.
Hers '95 TLC Bare bones.
"I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown |
11-09-06, 09:10 AM
| | Forum Lifer
| 50 works, I think it is 42 or 46 so 50 is good nuff!
__________________ Dan Kunz
1996 FZJ-80 " AV0CAD0"
2000 UZJ-100 "T0WCAD0"
Member: TLCA, GA Cruisers, Upstate Cruisers
Donate to SAVE TELLICO!
_____________________________ Originally Posted by eventhough:
"apparently I just need to play with it until it feels right... " |
11-09-06, 11:57 AM
| | 250+ Club
| From FAQ
You adjust the pre-load using the 54mm socket. Torque the adjusting nut to 43 ft-lbs
turn the hub right two or three times. Torque the adjusting nut to 43 ft-lbs again.
Loosen the nut until the hub can be turned by hand.
Torque nut to 48 in lbf (Yes thats inch pounds) and make sure there is no play.
Using a spring tension gage (Fish scale) measure the pre-load. s/b between 6.4-12.6lbf. Adjust as required. You do this by hooking one end of the scale to the hub and seeing how much it takes to move the hub.
Install Lock washer and lock nut. Torque the lock nut to 47 ft-lbs.
Check that the axle hub turns smoothly and the bearing has no play.
FSM says to check pre-load again with scale
__________________ '79 FJ40 33" MTRs, 2" OME;' 96 FZJ80 Retro 100% OEM Lockers, CDL, OEM Hand Trottle, OEM Grab Bar, JDM Cooling Fan, OME 851/860, OEM SubTank in process "The monstrous evils of the twentieth century have shown us that the greediest money grubbers are gentle doves compared with money-hating wolves like Lenin, Stalin and Hitler, who in less than three decades killed or maimed nearly a hundred million men, women, and children and brought untold suffering to a large portion of mankind.” Eric Hoffer |
11-09-06, 01:18 PM
| | Site Addict
| Once I've done the preload setting (tighten, loosen, tighten, loosen etc.) I torque the inner down to 5 ft. lbs. and re-check the preload (its always been within spec). Then tighten the outer to 50 ft. lbs. bend the tabs on the lock washer and I'm done. |
