80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 11-06-06, 03:22 PM   #1 (permalink)
FJ45KC's Avatar
Some Dash Lights don't work after Scion Radio install
Am I missing something here? I installed the newer version Scion head unit in my 95 and now half my ac control lights don't work (bottom half) and a handfull of dash switches in the general area (hazard, antenna, rear heater). This is the second Scion head unit install that I have done. The first one was a 1st gen HU.
1996 LX450 (For Sale)
1979 FJ40 - Frame off Ten years ago.
2006 UZJ100
2007 Peg Perego FJ40 - Sticker removal mod....
Olde North State Cruisers of NC
FJ45KC is offline   Reply With Quote
Old 11-06-06, 04:14 PM   #2 (permalink)
DTAYLOR's Avatar
Same area...
Did you check the head unit operation before you reinstalled it?
Since all you mentioned are located in the same area AND failed after you did the new head unit, check the connections and retest before you put it all back together.
DTaylor
96 FZJ80, Performance Engine Overhaul; (crank worked; head shaved & flowed) Injectors flowed; Intake polished; Exhaust polished. PS Cooler; CDL switch; Cup holder. Silicone heater hoses, green coolant, Rustoleum ft bumper paint, Powdercoated engine junk.
03 Harley Davidson Road King
DTAYLOR is offline   Reply With Quote
Old 11-06-06, 04:33 PM   #3 (permalink)
Lochsa's Avatar
I would check for blown fuses. I had to replace one after my install, but I can't remember if it affected any of the lights you're indicating. Either way, that's where I'd start.
96 Locked and Stock - 110k
Lochsa is offline   Reply With Quote
Old 11-06-06, 04:46 PM   #4 (permalink)
FJ45KC's Avatar
I am going to recheck the install again and check for fuses. Like I said It's weird because half the lights in the HVAC control box don't work. Just curious if anyone else has experienced this.
2006 UZJ100
Old 11-06-06, 05:15 PM   #5 (permalink)
GeoRoss's Avatar
When I replaced my HU my AC-heater controls didn't work. I reopened the dash and found that I had not fully engaged the plugs.
Ross
1994 FZJ80, OME850/864 w/ CSC 1.5" spacers, 285/75 r16 BFG AT/KO, 131K
"SUBDUCTION leads to OROGENY"
"Strip Mining Prevents Forest Fires!" "Stop Continental Drift!"
"Tuff Schist" "Reunite Gondwanaland"
WFC: 2020 5337 1783
GeoRoss is offline   Reply With Quote
Old 11-06-06, 06:20 PM   #6 (permalink)
I agree, check that your plugs are push all the way on. I had the same problem since the harness is so short.
othater is offline   Reply With Quote
Old 11-06-06, 06:32 PM   #7 (permalink)
FloridaFJ80's Avatar
i have the same issue with mine, and this happened after I installed my pioneer head unit.. let me know what you find out.. For me only the rear defrost button, the antenna, and the ect switch dont turn on. when i turn on the lights, but they are still operational. Any ideas???
Frank
1992 FJ80 Semi-Stock
2008 Prado VX - TRD'd
305/70/17 Maxxis Bighorn M/T
TJM 3" Suspension Lift
Safari Rack with Fogs
Factory Digital Inclinometer/Compass
Rear storage system
Dual Battery Setup
On Board Air
FloridaFJ80 is offline   Reply With Quote
Old 11-06-06, 07:41 PM   #8 (permalink)
GeoRoss's Avatar
Make sure the bulbs are still in place if the actual button still works? Did you wire up the illumination wire to the radio correctly?
Ross
WFC: 2020 5337 1783
Old 11-06-06, 09:14 PM   #9 (permalink)
Kenso's Avatar
It's been my personal observation that when removing dash components on an older vehicle, afterwards you may have multiple bulb failures. "Disturbing" the bulbs seems to cause them to fail in some cases. Why it happens from pulling switches/controls out of the dash, but not from jolts/bumps on the road, I can't say. If you don't find an obvious problem such as an unplugged connector, try swapping a working bulb for one of the non working ones (maybe swap the climate control bulbs around and see if the problem moves with the bulb).
99 UZJ100 95 FZJ80 00 ITR#106
How to customize the startup text on your Scion headunit
Kenso is offline   Reply With Quote
Old 11-07-06, 07:25 AM   #10 (permalink)
Is it easy to open up the switches and replace the bulbs???
Frank
Rear storage system
Dual Battery Setup
On Board Air
Old 11-07-06, 09:06 AM   #11 (permalink)
GeoRoss's Avatar
It is very easy. Just pop into the dash, disconnect the switch and push the switch out through the dash (there are a couple of plastic arms on the switch that hold the switch to the dash, they need to be gently pressed).
This is also a case where ordering from Dan makes it easy. I replaced some of my burnt bulbs and they all seemed to be slightly different. I would hate to have to explain this to the local dealership guys or try to find aftermarket ones.
Ross
WFC: 2020 5337 1783
Old 11-07-06, 09:33 AM   #12 (permalink)
lt1fire's Avatar
is there any reason that the scion hu are so popular for the 80??? whats so good about it as opposed to atermarket ones???
Al
92 fj80: full 6 in slee lift, electric fans, 37x12.50x16.5 Goodyear MT, custom sliders, custom front bumper, slee ss extended brake lines, Bud built tie rod/relay rod, XRC 10 winch
lt1fire is online now   Reply With Quote
Old 11-07-06, 10:01 AM   #13 (permalink)
GeoRoss's Avatar
A decent HU that is iPod capable and that is OEM which discourages theft.
WFC: 2020 5337 1783
Old 11-07-06, 05:56 PM   #14 (permalink)
lt1fire's Avatar
10-4 sounds good to me... which are the good models to look out for??
Al
