80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 11-05-06, 02:49 PM   #1 (permalink)
Question 97 80 Series using oil
Hello. I am a relatively new owner of a 97 80 Series. I have had this vehicle since February. In general, I love this Cruiser. But, there is one catch. I seem to be using a lot of oil.
Has anybody had any experience with an 80 series using excessive oil? I can't find any visible leaks, including getting under the vehicle and looking at the rear main. It is not burning the oil, either. When I purchase the Cruiser, I had it checked out at the dealer, including a compression test. All checks were fine. There were some repairs needed (knuckles, differential fluids, etc) and all were taken care of. Compression was consistant accross all cylinders (don't have the numbers in front of me now). I can't find any explaination of where the oil is going. It using 3-4 quarts every 5k miles.
Any input would be appreciated. I need to get a good idea of what I'm up against so I can decide whether to keep this vehicle or get another one.
Brian
landcruiserguyaz is offline   Reply With Quote
Old 11-05-06, 03:18 PM   #2 (permalink)
firetruck41's Avatar
Not all that unusual, Toyota considers up to 1 qt per 1000mi "normal" for purposes of warranty problems, etc...
If compression is good, there's no oil in your coolant, and puddles aren't forming in your driveway, I wouldn't worry about it too much, oil is cheap anyway. I found my oil consumption went down when I changed from Mobil 1 to Rotella Synthetic 5/40.
Ben Silva
IH8MUD Site Supporter since July 2004
1996 Lexus LX 450, 144k, locked, Cooper STT 285s, OME 850/863, Slee Blue CC bushings, CDL/Pin 7, LandTank MAF, Powerstop rotors/EBC Green pads/Slee SS brake lines, Slee headlight harness, HIR mod, DIY installed Viper Remote start/alarm system, Mot JDM passenger grab bar, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter, Raingler Barrier Net
1998 Lexus LX 470, 139k Sold
1993 FZJ80 198k miles Sold
My writeups:
HOW TO: DIY Remote Start/Alarm/Keyless Entry
John Deere HIR bulb mod
HOW TO: Fix your leaky windshield
firetruck41 is offline   Reply With Quote
Old 11-05-06, 03:50 PM   #3 (permalink)
Wrench Bender
RavenTai's Avatar
many 1FZ's use oil, but that seams more than average, about half a quart or so will go through the PCV in 5K, most also have leaks at the back of the engine but you say yours is dry there? many also have seeps/leaks at the front also.
what weight oil are you using? what climate (location)
1988 FJ62 on 33s
1996 LX450 on 33s
RavenTai is online now   Reply With Quote
Old 11-05-06, 04:22 PM   #4 (permalink)
The quick brown fox .....
Beowulf's Avatar
As Firetruck mentioned, Toyota would consider this within normal range for consumption.
Try switching weights to a heavier oil. Consider going to a syn from non-syn or the other (dino to syn). Go to a 10w50 or a 15w50. Get a Blackstone to see if there is a high percentage of fuel in your oil causing evaporation.
Keep us posted on the progress.
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
Beowulf is online now   Reply With Quote
Old 11-05-06, 05:50 PM   #5 (permalink)
trainrech's Avatar
Read up on the oil portion of the FAQ. Not sure what we can add without knowing what brand/type/weight of oil you are using.
'77 FJ40 - 3 YO Son calls it "White Truck"
'05 Sienna - because the 100 couldn't handle 4 kids
'06 Tundra - only Toyota truck in the company
Tornado Alley Cruisers
ΒΘΠ
trainrech is offline   Reply With Quote
Old 11-05-06, 05:54 PM   #6 (permalink)
Toyota may consider that normal, but that's an insane amount of oil consumption. If there are no leaks, then it's being burned, no matter what the tests say.
1972 C2500 long bed, 2005 Odyssey, 2008 Tundra double cab
Idaho
cruiserman is offline   Reply With Quote
Old 11-05-06, 06:00 PM   #7 (permalink)
Central Scrutinizer
MoGas's Avatar
As seen in last month's oil consumption question, I was using 1qt/thousand miles running 5-30 Mobil 1. I switched to Rotella synthetic 5-40 and I haven't dropped off the full mark yet 1500 miles into it. (now 2K and about 1/8th inch from the full mark)
Dave
Mine: 1993 FZJ80, Classic White.
ARB Commercial, Warn 8274, Aussie Locker, Hanna Sliders, CDL, P7, JD HIRs, Slee harness, Dual Batteries, 850/863, Slee 25mm spacers, SS brake hoses, Norcold 60.
Hers: 1988 FJ62, Red, OME Dakar, Norcold 45, "El Rojo Grande"
1986 4x4 Hilux 22RTE
1965 M416 Trailer.
Copper State Cruisers Member #85
"I would remind you that extremism in the defense of liberty is no vice. Let me remind you also that moderation in the pursuit of justice is no virtue."
Barry Goldwater
MoGas is offline   Reply With Quote
Old 11-06-06, 06:01 AM   #8 (permalink)
Thanks for all the info everybody. Here are answers to most of the questions that were asked in replies.
I'm running 5/30 Conventional oil.
I live in Phoenix, AZ.
I read up on the oil section of the FAQ. Thanks for the tip. It seems like people are all over the board on this one. Zero consumption to 1 quart per 1k mi and a lot of people at both ends of the spectrum. Also seems pretty consistent that Rotella Synthetic seems to get the best results. I've run Mobil 1 synthetic in a couple of diesel Mercedes 300D's that I've had and always had good results. But, that's running 15-50. Based on what I read hear, it's not quite as good at the lower weights.
Thanks again for the replies.
Old 11-06-06, 10:20 AM   #9 (permalink)
Scamper's Avatar
Originally Posted by RavenTai View Post
many 1FZ's use oil, but that seams more than average, about half a quart or so will go through the PCV in 5K...
True, but if your PCV valve is gunked up, you can increase your oil consumption significantly. Might want to give it a check, or just replace it.
Tom
'97 FJZ80 CE sans the manly lockers but with the manly Kazuma SC...it blows, and it's a good thing
AirLift1000 with Load ControllerII and Slee Dashboard Beverage Restraint System
'02 MR2 Spyder
'01 Avalon
...long live the Scamp...the Scamp is gone
Scamper is offline   Reply With Quote
Old 11-06-06, 10:28 AM   #10 (permalink)
Wrench Bender
RavenTai's Avatar
Do not run 5w-30, in other countries that do not have the US CAFE regulations 5w-30 is only recomended for very cold weather for this engine.
if you live in AZ you need to bump at least to a *w-40 oil you could even go with some of the thinner 50wt's like M1 15w-50 if you wanted. (that is what is in mine right now left over from this summer) rotella T syn 5w-40 is a solid choice reletively inexpensive and a good oil,
that will help with consumption.
1988 FJ62 on 33s
1996 LX450 on 33s
Old 11-06-06, 12:44 PM   #11 (permalink)
Thanks RaveTai and Scamper. After reading through this, I called the local stealership and also called Slee Offroad this morning. Got the same answers as everybody on here. Sounds like the first thing to do is replace the PCV, then start monitoring the consumption again.
How often should the PCV be replaced under normal driving conditions? I don't see where it is part of the scheduled maintenance in my manual.
Old 11-06-06, 12:57 PM   #12 (permalink)
Beowulf's Avatar
The PCV valve is less than $5 from Toyota and takes about 2 minutes to replace. I think you can remove the hose clamp with a standard pair of pliars. Aftermarket valves are available but in my experience, they don't fit well. Replace the valve cover grommet at the time you pull the valve.
If the hose going to the PCV is hard (probably will be if > 150k) then you may want to replace it at the same time. The hose cracks when it hardens.
-B-
Old 11-06-06, 05:00 PM   #13 (permalink)
If you are worried about the engine burning the oil, you should pull the spark plugs and see if they have black around the lower part of the electrode. If your engine is burning oil that bad, it will be on the spark plugs. Mine uses 1.5 qts every 3000 miles and this isn't enough to turn my spark plugs black.
elhombre is offline   Reply With Quote
