80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 10-21-06, 06:24 PM   #1 (permalink)
hadji_85's Avatar
Compression Test Help
I want to perform a compression test on my engine, i bought what it hink is the necessary equipment from walmart. How do i go about doing this, i tried searching the forums but didn't really find anything, i found some general stuff on the internet but nothing particular.
also after i get the numbers, what do the numbers mean, maybe i'll just post them up and see what you guys say.
1st LC '96 FZJ80 stock lockers 32" kumho road ventures, gonna be stock for a while until i get caught up on maintenance
hadji_85 is offline   Reply With Quote
Old 10-22-06, 01:39 AM   #2 (permalink)
The procedure is outlined in the factory service manual.
Mark sure the battery has a good charge. Disconnect the coil and pull the spark plugs. Pull the EFI relay (or other method to disable fuel injection). Install the tool into the first cylinder spark plug hole. Have an assistant crank the engine a few turns until the pressure is max. Record the value. Do all 6 cylinders.
Put a teaspoon of oil into each cylinder. Repeat test.
1972 C2500 long bed, 2005 Odyssey, 2008 Tundra double cab
Idaho
cruiserman is offline   Reply With Quote
Old 10-22-06, 11:34 AM   #3 (permalink)
hadji_85's Avatar
Do i need to run the engine a little bit (10 minutes?) before taking out the spark plugs and doing the compression test.
Old 10-22-06, 12:35 PM   #4 (permalink)
Wrench Bender
RavenTai's Avatar
Here is a thread about compression testing, talks about some of the things to do wile testing,
Compression test results and questions, AutoeRx theory, and spark plug?
As for interoperating results it is difficult, there are many external variables that go into it
Best advice is to look at the variation cylinder to cylinder instead of the actual numbers,
1988 FJ62 on 33s
1996 LX450 on 33s
RavenTai is offline   Reply With Quote
