80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 10-18-06, 03:31 PM   #1 (permalink)
CreeperSleeper's Avatar
Question Time to make a cooling decision
Okay everybody, after reading all of the threads on the fan clutch / overheating that have been so popular over the summer and doing a lot of soul searching I have come down to two options:
1) Replace the factory setup with dual electric puller fans. As of right now I'm running the stock electrical system with an aftermarket sterio (small amp and sub).
2) Replace the fan clutch with a spacer and run a good quality flex fan.
I'm just wondering what you guys would do given those two choices. I'm not interested in modifying my fan clutch or the other alternatives that might work. I get one shot at this.
Just so you know, this vehicle is only driven to go wheeling (driven to trailhead) and an occasional drive in town (once or twice a month). TIA
Chad - Cascade Cruisers
KE7VSA - MetalTech
FZJ80 - 37's, lifted, locked, geared, cut and dented.
Originally Posted by bugsnbikes View Post
Dewd- You would bend those spindles if I tucked them into the passenger seat You are a candidate for a bobbed 80----not a high clearance bumper.
CreeperSleeper is offline   Reply With Quote
Old 10-18-06, 03:36 PM   #2 (permalink)
fatherofdaughterofromer
Romer's Avatar
Garage
Where you live and what you do, i would just run an stock fan clutch, simple and you know it will work. They are not expensive. I am running a stock unmodified fan clutch with a supercharger (Bigger fan though - TRD Kit)
Why are you so concerned?
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Romer is offline   Reply With Quote
Old 10-18-06, 03:55 PM   #3 (permalink)
I've gone thru four fan clutches in a year and it will still heat up on me going up logging roads. I've done the whole replace and flush routine and it helped for a bit, but it seems like everytime I started it up the fan clutch roar is a little less. When I first put my last clutch in, it would hold a 3x5 chunk of cardboard to the grill. Four months later it has trouble holding a peice of printer paper. I'm just sick of messing with it as it's costing me so much re-buying parts. It's taking away from buying things I want to buy.
As for the terrian, it's steep and rocky with some slimy surface mud thrown in to make things interesting. IE: just your typical Pacific Northwest wheeling minus the mud holes!
KE7VSA - MetalTech
Old 10-18-06, 03:58 PM   #4 (permalink)
Romer's Avatar
Garage
are you buying Toyota OEM. That is not typical. If you are buying Toyota OEM, then the replacement should be free if you have done 4 in a year.
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Old 10-18-06, 04:19 PM   #5 (permalink)
The first one and the last one were OEM
KE7VSA - MetalTech
Old 10-18-06, 05:10 PM   #6 (permalink)
Moby's Avatar
If you convert to a full electric set up take a look at http://www.dccontrol.com/ for a controller. The controllers are expensive but, in my opinion, worth it. The goal is to run the fan at a speed that can maintain a set temperature. This means that you get variable fan speed (which means fewer amps used), a slow ramp up (less initial load on the electrical system) and smaller temperature swings in your cooling system. I also really like the design aspect of this controller. See the Technology page and it's Reliability section and also the Perspective page. Rarely will you see a manufacturer today make these types of statements.
I'm using this controller now for a set of pusher fans on my FJ-62 and will later convert to use it for a dedicated puller fan (probably a Ford Contour, see below).
Also interesting are their Intergral Fans. I like the fact that these are based on OEM fans (OK, so they're Ford, I still think that's better quality than aftermarket). There is a single that is a Lincoln Mark VIII. This will pull 4300 cfm on full and even at half speed the cfm is excellent and the amperage draw is low. The dual is, I believe, a Ford Contour fan. This moves 3400 cfm on full and also has good half speed cfm and amperage draw.
Joel
'89 FJ-62
Moby is offline   Reply With Quote
Old 10-18-06, 05:17 PM   #7 (permalink)
Good luck finding a mark VIII fan in a boneyard, they are scarce but would work. My freind just put on e on his 01 lightning and towed a 20 ' trailer from SLC to san fransisco and back with no issues. I am still thinking about this not because of your issue but to get some ponies back.
Dave
"The time has come" the Walrus said," To talk of many things.."
In the Trees.... OH
80 fj40, 2.5 OME Dakaar springs, 33" bfgs. "Charlie Brown"
88 fj62 Bone stock, Daily Driver, Bone stock. "Moby"
PHAEDRUS is offline   Reply With Quote
Old 10-18-06, 06:14 PM   #8 (permalink)
Parts Geek, M1 Mechanic
cruiserdan's Avatar
OEM clutches DO NOT fail like that. Something else is up.
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
Old 10-18-06, 07:04 PM   #9 (permalink)
I realize that's more than likely the case, but I'm running out of things to replace!
KE7VSA - MetalTech
Old 10-18-06, 07:11 PM   #10 (permalink)
Romer's Avatar
Garage
Lets go back for a moment and look at what is going on:
what do you stick in the fan clutch to test it and how often?
How long have you had your truck and how long before you first replaced your fan clutch?
Any other modifications in there?
Is the shroud still there?
anything else you can tell us about your setup?
When you replace your fan clutch, what are the steps you take?
What do you do to ensure it's mounted right?
Do you see anything abnormal like an oscillation about it's operation?
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Old 10-18-06, 07:22 PM   #11 (permalink)
"what do you stick in the fan clutch to test it and how often?"
I have yet to stick anything in the fan, just the sticking things to the grill and noise.
"How long have you had your truck and how long before you first replaced your fan clutch?"
About a month for the first one.
"Any other modifications in there?"
Just dirt. (I did presure wash the rad out as best I could from the inside and will hose down the engine bay whenever I was the truck, around 2x a yr)
"Is the shroud still there?"
Yes
"anything else you can tell us about your setup?"
The air filter needs to be replaced. It has an aftermarket T-Stat, but I'm 99% sure it is working correctly and a new rad cap that I tested in a pan of water.
"When you replace your fan clutch, what are the steps you take?"
I followed the steps in FAQ and the FSM.
"What do you do to ensure it's mounted right?"
See answer above and below.
"Do you see anything abnormal like an oscillation about it's operation?"
Not a thing.
KE7VSA - MetalTech
Old 10-18-06, 07:24 PM   #12 (permalink)
Maybe the rad is clogged with dirt, but I don't have a problem at higher speeds and/ or coasting downhill in the woods. The only thing that really makes sence is the fan clutch unless I've gotten so used to the roar I can't hear it when I'm listening for it.
KE7VSA - MetalTech
Old 10-18-06, 07:28 PM   #13 (permalink)
Romer's Avatar
Garage
Have you thought of adding a temp gauge so you can monitor collent temps, or you could use an OBD II scanner. You could monitor the coolent system to verify you do have a problem. The stock temp gauge is worthless.
I am guessing by your last post that you do have a cooling problem. If so, could you elaborate?
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Old 10-19-06, 10:50 AM   #14 (permalink)
I've checked temp off the scanner before, but it's not hooked up all the time.
The time I notice that there is a problem the most is when I'm driving up steep grades at low speeds (IE logging roads). However, like I said before, I don't drive it very often, so she's not in traffic... ever. It's only in a situation where I'm holding 2nd gear at a constant speed (approx 3000 rpm). That's around 20 to 25 mph. BTW- I'm running 35's with stock gears, so the engine is working harder that usual.
KE7VSA - MetalTech
Old 10-19-06, 11:09 AM   #15 (permalink)
Start with your thermostat. Many people have discovered early failure or failure to fully open with non OEM thermostats which you have. The factory part is not expensive and easy to replace. Second, have you tried a new factory radiator cap?
What temps are you actually seeing? You need to define what you mean by running hot.
You know your life is screwed up when you are getting divorced, fighting over custody, watching all of your money getting pissed away, being treated by her and her family as the anti-christ, and yet, finding your life has drastically improved.
cary is online now   Reply With Quote
Old 10-19-06, 11:29 AM   #16 (permalink)
concretejungle's Avatar
i find it funny that people are having problems with fan clutches and overheating. i, for some reason have the blue fan clutch. It still roars when i start it up. i have never had an overheating problem except when the PHH blew. Even in stop-n-go city traffic with the AC on and it be 97 out, i still don't over heat.
Wonder why i have a blue fan clutch on a 95? I thought that was a newer clutch design.
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
concretejungle is offline   Reply With Quote
Old 10-19-06, 11:31 AM   #17 (permalink)
Danke!
-Spike-'s Avatar
How do you test a radiator cap in a pan of water? It's pressure activated, not temp. Of course, it won't make your truck run hot unless there's coolant spewing out.
x2 on the thermostat. Toy therms are superior to aftermarket in both design and function. Make sure it's oriented correctly when installed- bleeder hole at the top IIRC.
The factory fan clutch is fine, no need to go solid, nor would it be desireable IMO. The factory system should be fine in your situation. Oregon isn't particularly hot AFAIK, so you shouldn't 'need' to do anything. Here in Hell, Arizona, I added an electric fan in front of the condenser that runs with the A/C and keeps the engine temp under control and the A/C cold at idle, which I do a lot of on trails. For normal driving I haven't found the factory setup to be a problem, even while towing in the mountains in the summer.
If you have a problem with your thermostat or your radiator, adding more air flow isn't the answer.
-Spike
His 1994 TLC 'White Elephant' +6"/37" Locked.
Hers '95 TLC Bare bones.
"I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown
-Spike- is online now   Reply With Quote
Old 10-19-06, 12:15 PM   #18 (permalink)
C6H12O6's Avatar
wouldn't a separate problem that caused temps high enough to have the clutch always "on" add to its premature demise? Maybe the problem isn't the fan clutch. Maybe that's just a symptom of some other issue in the cooling system and the clutch is overworked and failing as a result.
If you're gonna be a bear, be a grizzly.
Steve the Fly Fishing Science Teacher
1995 FZJ80 ~ Lockers, winchless ARB, 2.5" OME, bent-up, rattling, leaky Borla exhaust, MetalTech Sliders, multiple oil leaks, 285 Revos.
HAM: KE7VRZ
http://web.mac.com/stevenlent/cruiser/cruiser.html
C6H12O6 is offline   Reply With Quote
Old 10-19-06, 02:36 PM   #19 (permalink)
I've been thinking that too, but I've replaced everything but the rad and I've had that power flushed...
I guess it wouldn't hurt to replace the rad cap and t-stat and have it flushed again. At this rate I will never get my gears...
KE7VSA - MetalTech
