| front axle binding after rebuild Hey guy's, I could use some help.
I finished my front axle rebuild on my 85 ex cab. The rebuild included all seals and new upper and lower bearings and races. I did check the bearing preload and was spot on. I also Martacked both inner axles during the rebuild. I installed new warn locking hubs from the orginal auto locking hubs. I am also pretty sure there is no locker in the front. The front axle rebuild looked like a first time.
So here is the problem. I am driving into a parking space at the supermarket in 4 high with the front hubs locked. The truck comes to a stop while pulling in, and I am not hitting the brakes. The front axle feels like it is fully locked up. The truck is also pretty much stuck in 4H and will not shift to 2H. I put the truck in reverse and am able to shift to 2H.
Had a similar issue in reverse.
Any ideas? Thanks |
