Home Forum Gallery CruiserFAQ Tech Links Merchandise
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 79-95 Toyota Truck Tech
Join IH8MUD on Google+   Follow IH8MUD on Twitter   Visit IH8MUD on Facebook
79-95 Toyota Truck Tech Covering the minitruck/hilux, surf, and 1st/2nd Gen 4Runner
Thread Tools Display Modes
Old 11-24-05, 03:02 PM   #1
toyota884runner
Check Engine light come on after oil change never done it before. help
Check Engine light come on after oil change never done it before. it came on right after i drove up a hill and stays on. the dipstick says it is fine oil wise. what could it be?? it's a 88 4 cylinder 22re 4runner. please reply
toyota884runner is offline   Reply With Quote
Old 11-24-05, 06:22 PM   #2
pbgbottle
Lifer
pbgbottle's Avatar
Garage
sometimes they come on after a certain amount of miles say, 80,000 100,000 130,000 ,just to get you in to the dealer, you can try disconecting the battery for a few minutes , if it is nothing serious it will reset the error code and light will be off , don't no much else about your year it is pre obd2 , ?? could be your o2 sensor went bad ?? who knows just giving you some suggestions .
Jake S.
1978 FJ40,350 small block chev,sm465 to 3spd t-case,spring over ,cut-N-turn,saginaw,shackle reversal, 38.5 TSL SX superswampers, 4.11 fine spline
4 wheel disc brakes, OBA=CO2 ,Warn 8274 ,4x4 labs high steer,Marlin chromo birfs ,lunchbox lockers (front+rear) ,Metaltech Jackson cage
...ROTW:PBGBOTTLE
.... ...Cardomain Pics
pbgbottle is offline   Reply With Quote
Sponsor 11-24-05, 08:00 PM
Sponsored Link
advertisement
Old 11-24-05, 08:00 PM   #3
KLF
Frame waxer
KLF's Avatar
Garage
Originally Posted by pbgbottle
sometimes they come on after a certain amount of miles say, 80,000 100,000 130,000 ,just to get you in to the dealer...
Toyota's don't do this. AFAIK, BMW is the only car that pulls this stupid stunt, but there may be others.
Read this article:
http://www.off-road.com/toyota/tech/codes/
Grab a paperclip, jumper the diagnostic connector (yours is attached to the fuseblock right behind your battery), read the flashing code. Repair as appropriate.
KB1OSF
'87 Toyota xcab SR5 - SAS'd, e-lockers, stuff (22RE/R151F/4.7's) - currently undergoing frame-off restore
'05 Lexus ES330 - Nav/ML/17's
'04 Toyota Highlander
Old 11-24-05, 08:34 PM   #4
lunyou
Addict
lunyou's Avatar
When the light comes on do you notice a difference in the way it runs(accelerates/deccelerates)? If you do its probably the O2 censor. My 93 did this and i had it fixed.
My previous 85 4runner's check engine light came on and stayed on til the day i wrecked it which was many miles. I would say look for obvious things and unless you want to go have it diagnosed just ignore it.
lunyou
lunyou is offline   Reply With Quote
Old 11-24-05, 11:36 PM   #5
bkg
Stupid question, but are you sure you filled it w/ oil? The oil pressure light and check engine, I believe, will come on w/ low pressure.
bkg is offline   Reply With Quote
Old 11-28-05, 07:55 AM   #6
Bob_Garrett
Addict
Bob_Garrett's Avatar
Is the oil filler cap on and tight? Check all the electrical and vacuum hoses in the areas of the motor where you were working to make sure you didn't accidently knock something loose.
You've never lived till you've almost died. For those who fight for it. life has a flavor the protected will never know.
Bob
95 FZJ80
83 Mini-Truck
Irving, TX
Bob_Garrett is offline   Reply With Quote
Old 11-28-05, 09:03 AM   #7
Jukelemon
Addict
Jukelemon's Avatar
Did you spill oil on a sensor-namely the temp coolant sensor? It is right there to the left of the cap.
"May you be in heaven a half an hour before the devil knows you're dead"
2008 Tacoma TRD Sport Double Cab 4x4
Jukelemon is offline   Reply With Quote
Old 11-28-05, 02:57 PM   #8
Red_Chili
Pull the code, reveals all secrets. My bet is on a coincidence, and it's either your TPS or your O2 sensor. Or both.
-Bill
Rising Sun 4x4 Land Use Coordinator
1987/1990/1996/1984/1986 5VZ-FE SAS 4Runner
Yeah, I know, but about the only 1987 part on it anymore is the body[edit: even that ain't 1987 now...]
What is a minitruck guy doing on a Land Schmooser forum, anyway??!?!
Red_Chili is offline   Reply With Quote
Old 11-28-05, 09:14 PM
Sponsored Link
advertisement
Old 11-28-05, 09:14 PM   #9
KLF
Frame waxer
KLF's Avatar
Garage
Nope. There are no codes in the ECU system for "No oil pressure".
It often takes several repetitions of an error condition before the CEL comes on. If there was no oil in the engine, it would have siezed by now.
If you can find a paperclip, you can pull the codes. It's really easy.
KB1OSF
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
vBulletin® ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus, Vendor Tools vBulletin Plugins by Drive Thru Online, Inc.
©2000-2013 - Tie Rod Media, LLC - ALL RIGHTS RESERVED
