I did a quick search and didn't really get a solution. '94 22re. If the temp gets to around 32 or below, it will not start until it gets warmer. Will turn over (crank) all day long, but will not start. Any ideas?
Sounds like the battery is OK, so must be a fuel issue. Either water in fuel freezing up, or not enough fuel called for by ECU for cold weather. Try a couple of shots of starter fluid(ether) to see if it fires up on that. JohnI did a quick search and didn't really get a solution. '94 22re. If the temp gets to around 32 or below, it will not start until it gets warmer. Will turn over (crank) all day long, but will not start. Any ideas?
Ok, so about a week ago it got down to 35 and still the same problem. I cranked on it for a good couple of minutes and it finally started up. That made me think cold start injector. I had a spare from another intake, so I swapped them out. This morning it's 35 again, and the same thing. Took a couple of minutes for it to start. I did notice that when I swapped the injectors it seemed like there was alot of air in the line (lots of pressurized fuel/air spray). I don't remember it being like that before, seems like it just dripped fuel when I've disconnected it in the past. Thoughts?
