Old 11-06-09, 04:41 PM   #1 (permalink)
My 22r rebuild
hey all, so a few weeks ago im on way way to work, when outta no where I hear a terrible noise ( id prefer not to even try to describe it) and suddenly lose power, so I limp it to the side of the road where I pop the hood and notice 2 huge holes in my block, so obviously it was time for a rebuild. At first I had a teeny tiny broke high schooler budget, and wanted to get it done cheaply, but after getting my first report card, my mom decided I needed to do it the right way so the shopping begins, I had been looking at complete engines for a while with out any results, then I finally came across a newly machined block, score. So I now have a newly machined block, bored .60 over with new pistons and rods. Next comes the head, I took it to the shop and ended up with a brand new looking head. I topped it all off with a new clutch kit, new oil and water pumps, timing kit with steel guides and a new timing cover. So at this point the motor is just about done and will be ready to throw in on Sunday. On to the pics
bennyboyraptor is offline   Reply With Quote
Old 11-07-09, 05:55 PM   #2 (permalink)
DanS HJ-45's Avatar
TLCA# 17527
That's quite the hole there! Did it give any warning of that? Metal in your oil before? Ticking noises from the bottom end? I'm assuming that the #1 connecting rod also let loose--correct?
Looks good.
Dan
KE5YYE
1976 HJ-45 (needs restoration) http://forum.ih8mud.com/fj45-owners-...self-into.html
1991 "Faux-Lux"Pickup 4x4 2LT-E/R-150f http://forum.ih8mud.com/79-95-toyota...onversion.html
1979 FJ-40 to BJ conversion http://forum.ih8mud.com/diesel-tech-...ml#post3811936
"Dandelions. You see flowers in these weeds."
--Five Iron Frenzy
DanS HJ-45 is online now   Reply With Quote
Old 11-07-09, 09:43 PM   #3 (permalink)
Looks good.
Dan
nope, none at all, no noise, no loss of power or anything, one of the bolts that holds the connecting rods broke
86 Pickup: 85 SAS with 85 front axle, alcan 5" springs,bilstein 5150 shocks, u bolt flip kit, marlin crawler hi-steer, 2" body lift kit, custom shock hoops, 5.29s, detroit locked rear, warn hubs , bud built belly up crossmember, 35" BFG M/T's
Old 11-08-09, 06:11 AM   #4 (permalink)
corax's Avatar
Garage
Good luck on the swap today. Just be careful and take your time with those old plastic connectors, broken connectors don't stay on very well.
-Keith- kb3scj
'88 4runner SR5 - 3L 7MGE swap - Marlin HD W56 - 4.56 V6 Thirds, LSD up front - 33x10.5 BFG KM2's- home fab front and rear bumpers - NWMP 14 gal aux fuel tank
"Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
corax is offline   Reply With Quote
Old 11-08-09, 12:56 PM   #5 (permalink)
death to infidels
Cube Dweller's Avatar
Wow!
The pickup I just bought was missing the #2 con rod bearing. Well, it wasn't missing. It was distributed throughout the engine as a silvery paste, and as a lump of goo in the bottom of the pan. Just a clunking noise though, it still ran! But no mondo hole through the block.
1983 Hilux Longbed Project Semlin Chat Project Semlin Tech
'97 Locked FZJ80 - ARB Front, Dual Batteries, 2kW Inverter MallCruiser
2 Mid 70's Simplicity Garden Tractors
Cube Dweller is offline   Reply With Quote
Old 11-10-09, 10:01 AM   #6 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
I would have driven it home..... Hehehe
2ndGenToyotaFan is online now   Reply With Quote
Old 11-10-09, 09:48 PM   #7 (permalink)
thanks for all the replies guys. We got the motor in Sunday night at around 11, turned the starter and got the (chitty starter) click. So Monday morning after having checker auto parts say that the started was still good, we cleaned the contacts and put it back in and she fired right up
Old 11-11-09, 07:45 AM   #8 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
Originally Posted by Cube Dweller View Post
Wow!
I said it once. I'll say it again. I don't think it's possible to kill a 22RE. DANG you put a hole in the block and it still ran. I think the only reason you lost power is because of the rather large vacuum leak.
aka Bushrat
1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled!
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane
pappy is offline   Reply With Quote
Old 11-12-09, 11:29 AM   #9 (permalink)
Well we got the motor in at around 11 on sunday night, went to fire her up and the starter just clicked So we decided to call it a night. On monday morning romix took the starter into checker it they said it was fine, so cleaned the contacts and got that thrown back on and she fired up. The motor is running great It was great seeing the motor apart and putting it back together, now it will be MUCH easier to diagnose and fix future problems
Old 11-15-09, 10:28 AM   #10 (permalink)
corax's Avatar
Garage
I don't know about that, rare, but it does happen - I completely killed the 22re in my old '88 p/u. It developed a severe lack of power at highway speed, if I floored it I could barely maintain momentum, if I backed out I couldn't build up any steam again. I realized what was happening and pulled over, when I checked the engine oil (still full) there was smoke coming off the dipstick because the oil was so hot from bearing failure (coolant temps were fine). After that it never really started again or turned over very well - still no hole in the block, though I was impressed that it ran as long as it did (I think that happened 15 minutes after I fought a speeding ticket and lost )
-Keith- kb3scj
Old 11-17-09, 08:41 AM   #11 (permalink)
toylndcrusr's Avatar
Since you didn't mention the cam, I thought I would suggest that if you have the money, an RV cam is a really nice addition to the 22RE. Especially one that is newly rebuilt with oversized pistons:
Toyota 22R 22REC 1981-95 cam RV torque new
toylndcrusr is offline   Reply With Quote
