Old 11-03-09, 06:02 PM   #1 (permalink)
Rookie
air pocket in cooling system 92 pickup 22re
Ive heard about the possibility of an air pocket in the cooling system. can someone tell me how to eliminate this? I just purchased the dual stage thermostat and want to get it refilled right.
dug1962 is offline   Reply With Quote
Old 11-03-09, 06:43 PM   #2 (permalink)
Valmorphanize!
valentine's Avatar
I just left it idling for a while with the rad cap off. After a few cycles of the thermostat, it should purge itself.
TLCA # 11402
97 FZJ80
94 FZJ80 Lifted & Locked
87 Land Cruiser FJ60
84 Toyota long bed P.U. {stolen} RIP
08 KLR 650
70 CT90
"The truth is NEVER hate" dieseldog 10-21-06, 11:00 PM
I am the Shadow Ninja
TUTotals
Originally Posted by Lupdog View Post
It's great to be a public nuisance!
Originally Posted by stinkyfj60 View Post
A tank full of napalm,
Suicide Girl
shotgun. Tercel smokes tires.
Originally Posted by yooper View Post
It's not all rainbows and butterflies in the Eastern Time Zone...
Originally Posted by Jman View Post
Why, yes, I would attempt to inject my DNA into that.
valentine is offline   Reply With Quote
Old 11-03-09, 07:43 PM   #3 (permalink)
toy4xfun's Avatar
also pour the antifreeze in without using a funnel it can seal around the inlet and not let all of the air escape. also jacking the front up helps.
QUIT SUCKING MY OXYGEN
toy4xfun is offline   Reply With Quote
Old 11-03-09, 09:10 PM   #4 (permalink)
KLF
KLF's Avatar
I always backfill the engine thru the t'stat hole.This way air can't get trapped behind the closed t'stat if you try to fill it via the radiator.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 11-04-09, 05:28 PM   #5 (permalink)
Rookie
thanks so much for the info, You ppl are so knowledgeable.....this is awesome
Old 11-05-09, 05:12 AM   #6 (permalink)
x factor's Avatar
TLCA# 18254
Squeasing the the lower rad hose also helps to purge air out. I learned that from an old body man at one of the first shops I worked at and I have not had any issues since doing that.
Bill
'84 Flamed flatbed
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preseved body,but rather to skid in broadside, totaly worn out & proclaming "WOW WHAT A RIDE!"
x factor is offline   Reply With Quote
