Old 11-02-09, 03:05 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
WristPin's Avatar
How to remove clutch pilot bearing with no special tools
Real easy to remove the pilot bearing using the disc line up tool and grease.
if you go all gung ho about gettin this bearing out and damage it before doing it this way (the right way) this method aint gonna work for you.
first pull the ring lookin knob out of the line up tool that comes in your kit.
fill the inside of the hole with grease. you will be displacing air with grease. once its full put the line up tool in the hole and wack it a few time with the hammer.
as the bearing comes out, there will be more volume behind it and you need to keep adding grease, pushing out the air as you do it. on this job here, i added grease 3 times before it came out.
its really easy to do.
make sure you clean out all the grease and shoot it down with brake clean before you put the new bearing back in.
Wristy
Jebus...
I like it when I can go out on the porch buck naked ...unroll it and take a wizz without somebody saying ......look john is alive and well
22RE Tech hotline- check the FAQ
Old 11-02-09, 09:45 AM   #2 (permalink)
pretty aw some.
didn't think of using the alignment tool!!!!!
heck it was laying right there also.
missouriman is offline   Reply With Quote
Old 11-02-09, 02:35 PM   #3 (permalink)
NorCalBorn's Avatar
TLCA# 19772
and far better for the bearing than the wet wonder bread pieces trick using the same method.
I've also used a spare trans shaft that was cut down. Handles the blows from the mallet better.
Nov. '09 ROTM: Project "Wimpy"
NorCalBorn is offline   Reply With Quote
Old 11-02-09, 02:37 PM   #4 (permalink)
Tartu hetkeen
liljlandon's Avatar
Garage
bravo!
Crusified:
You don't "lock" a Toyota's hubs, you "Call down the Demons".
liljlandon is offline   Reply With Quote
Old 11-02-09, 11:36 PM   #5 (permalink)
DanS HJ-45's Avatar
TLCA# 17527
Why on earth would you use wet bread?
Also, why on earth would you not replace a pilot bearing if you have it out?
The alignment tool/cut down input shaft are fantastic ideas. Much easier than searching for the correct size socket or dowel...
Dan
KE5YYE
1976 HJ-45 (needs restoration) http://forum.ih8mud.com/fj45-owners-...self-into.html
1991 "Faux-Lux"Pickup 4x4 2LT-E/R-150f http://forum.ih8mud.com/79-95-toyota...onversion.html
1979 FJ-40 to BJ conversion http://forum.ih8mud.com/diesel-tech-...ml#post3811936
"Dandelions. You see flowers in these weeds."
--Five Iron Frenzy
DanS HJ-45 is offline   Reply With Quote
Old 11-03-09, 01:30 AM   #6 (permalink)
arndog123's Avatar
Instead of using grease I used small strips of wet newspaper. It's not as messy and easier to clean.
1997 CE Land Cruiser: Locked, ARB w/ M12000
1996 LX450: Locked, ARB w/ no winch yet
1990 XtraCab 4x4 pickup: ARB w/ M8000
1986 Standard cab 4x4 pickup: Locked, ARB w/ XD9000
1985 XtraCab 4x4 pickup: ARB w/ M8000
1995 Acura Integra (Daily Driver)
arndog123 is offline   Reply With Quote
Old 11-03-09, 06:45 PM   #7 (permalink)
Valmorphanize!
valentine's Avatar
I did the same thing, works great. I think I used a punch or something that was the same OD as the bearing ID...
Nice gloves, do they glow in the dark?
TLCA # 11402
97 FZJ80
94 FZJ80 Lifted & Locked
87 Land Cruiser FJ60
84 Toyota long bed P.U. {stolen} RIP
08 KLR 650
70 CT90
"The truth is NEVER hate" dieseldog 10-21-06, 11:00 PM
I am the Shadow Ninja
TUTotals
Originally Posted by Lupdog View Post
It's great to be a public nuisance!
Originally Posted by stinkyfj60 View Post
A tank full of napalm,
Suicide Girl
shotgun. Tercel smokes tires.
Originally Posted by yooper View Post
It's not all rainbows and butterflies in the Eastern Time Zone...
Originally Posted by Jman View Post
Why, yes, I would attempt to inject my DNA into that.
valentine is offline   Reply With Quote
Old 11-03-09, 08:39 PM   #8 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
I use bread, not wet though... It's not messy, it won't catch air pockets while you try to pound it in there. And it won't shoot out and hit you in the eye if you don't have the right sized punch...
Old 11-03-09, 10:10 PM   #9 (permalink)
WristPin's Avatar
thats crazy i never heard of usin bread or paper, wet or dry.
you guys crack me up
Wristy
Jebus...
Old 11-03-09, 10:20 PM   #10 (permalink)
wanderlust
nat88toy's Avatar
TLCA# 16379
its great when that trick actually works most of the times that ive tried that i have failed so i grabbed the welder and slide hammer
98 sr5 T100 32" procomp mtr
1994 FZJ-80 factory locked, 4" lift, Landtank caster plates, Arb bumper, warn 12,000, snorkel, 35" TrXus mt, full belly skid, extreme air, bud built HD- TR & DR, HD 1/4 wall DOM control arms
1996 FZJ-80 factory locked, 4" lift Land tank caster plates, arb bumper, warn winch, HD 1/4 wall DOM control arms,FOR parhard adjusters
nat88toy is offline   Reply With Quote
Old 11-04-09, 06:29 AM   #11 (permalink)
Valmorphanize!
valentine's Avatar
You should be wearing safety glasses when working under a vehicle...
TLCA # 11402
97 FZJ80
08 KLR 650
70 CT90
TUTotals
Suicide Girl
Old 11-04-09, 08:14 AM   #12 (permalink)
Oh nevermind......
TLCA# 13872
True
Old 11-04-09, 07:44 PM   #13 (permalink)
DanS HJ-45's Avatar
TLCA# 17527
Try the bread. I've had a slide hammer not work, only to have the bread work perfectly. I'd bet the wet newspaper would do as well, but then you don't have an excuse to have hot dog or hamburger buns in the shop, and if you've got the buns, it's only natural to have the burgers or dogs too...
Dan
KE5YYE
--Five Iron Frenzy
Old 11-05-09, 04:38 PM   #14 (permalink)
This is what wet newspaper looks like when it comes out, no mess.
'86 4Runner 4"SAS, 35's/529's, fully locked, twinsticked duals w/4.7's (223:1), 30 Spline Longs, yada yada yada
My build, http://www.midatlantictoyotacrawlers...ead.php?t=1328
locknload is offline   Reply With Quote
Old 11-05-09, 11:33 PM   #15 (permalink)
NorCalBorn's Avatar
TLCA# 19772
Neener neener neener!! (I still respect you though Wristy!)
Originally Posted by DanS HJ-45 View Post
Try the bread...
Old 11-05-09, 11:36 PM   #16 (permalink)
NorCalBorn's Avatar
TLCA# 19772
Dan
O/T..everyone else reading into this like I am? He'll host you for a repair and cook you lunch!
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/329758-how-remove-clutch-pilot-bearing-no-special-tools.html
Posted By For Type Date
Clutch Pilot Bearing - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 11-16-09 05:30 PM
