Old 10-25-09, 08:39 PM   #1 (permalink)
TLCA# 12411
Timing Chain Cover Question
The timing chain on my 22RE broke a couple weeks ago. After inspecting with the valve cover off, I decided the inside of the valve cover looked good, and didn't need to be replaced. However, today I pulled the cover and found the bottom lip around the crank gear was broken-off. Should I put this project on hold and replace this timing cover, or can I still use this cover?
I'm sure Toyota put that lip there for a reason, bit I wanna get my truck back on the road...
Also, the chain didn't eat too much around the water pump.
Trevor is offline   Reply With Quote
Old 10-25-09, 09:32 PM   #2 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
I would reuse it..... but I'm poor, so.... It's a toss up.
Old 10-26-09, 10:40 AM   #3 (permalink)
KLF
KLF's Avatar
There's NO WAY I'd reuse that.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 10-26-09, 10:52 AM   #4 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
Me too.
aka Bushrat
1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled!
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane
pappy is offline   Reply With Quote
Old 10-26-09, 10:56 AM   #5 (permalink)
Tartu hetkeen
liljlandon's Avatar
Garage
Oriellys can get them for the newer blocks. Take yours in to match it up though. I forget how much they cost, but they dont have the older style blocks. Being as your is a 22RE you should be fine.
Crusified:
You don't "lock" a Toyota's hubs, you "Call down the Demons".
liljlandon is offline   Reply With Quote
Old 10-26-09, 10:58 AM   #6 (permalink)
death to infidels
Cube Dweller's Avatar
Did you have to loosen the head bolts to pull the cover? I'm trying to pull mine to inspect it and it's not coming off with all the front cover bolts + crank pulley + water pump removed.
1983 Hilux Longbed Project Semlin Chat Project Semlin Tech
'97 Locked FZJ80 - ARB Front, Dual Batteries, 2kW Inverter MallCruiser
2 Mid 70's Simplicity Garden Tractors
Cube Dweller is offline   Reply With Quote
Old 10-26-09, 11:02 AM   #7 (permalink)
Tartu hetkeen
liljlandon's Avatar
Garage
Dont forget the hidden bolt on top of the cover that goes through the head
Toyota 22R Timing Chain Replacement- ORN
Crusified:
Old 10-26-09, 11:02 AM   #8 (permalink)
KLF
KLF's Avatar
No you don't have to. But there are a couple of bolts that come in from the back side, did you get those? You can see them in his second pic.
Ya, then there's the infamous hidden top bolt, it sits under a puddle of oil just inside the head.
KB1OSF
'98 Lexus ES300
Old 10-26-09, 11:21 AM   #9 (permalink)
death to infidels
I remembered teh hidden bolt from 20 years ago working on my 20R! I pulled the two on the water pipe, but I'm not sure I got the one just below it. Thanks!
Old 10-26-09, 04:24 PM   #10 (permalink)
TLCA# 12411
I removed the head, but only because my valves were smashed to poo from the timing chain breaking.
I didn't make as much progress today as I woulda liked, so I might as well order another cover.... Thanks for the advise, everyone.
Old 10-26-09, 06:03 PM   #11 (permalink)
Oh nevermind......
TLCA# 13872
If you don't take the oil pan off there's a very good chance the cover will leak when you slide it back in between the 2....
Old 10-26-09, 10:48 PM   #12 (permalink)
cruiser88's Avatar
TLCA# 17319
trash it......
Originally Posted by calstyl2 Randy has lots of junk.........
NEW! Club sticker for sale. See my avy...pm me for details!
MountaineerCruisers.net
Need a mini truck head for cheap?
http://forum.ih8mud.com/sale-parts/3...ini-truck.html
Old 10-27-09, 06:26 AM   #13 (permalink)
TLCA# 12411
That makes sense. The pan is out. I did the "differential drop" method of getting it out. It wasn't really a big deal, but Lingo was helping me. I didn't think jacking up the drivetrain would gain enough clearance.
Old 10-27-09, 09:00 AM   #14 (permalink)
raevenzero's Avatar
TLCA# 19890
The oil pan should be an issue if he has the head off to check valves.
You're going to want to pull the oil pan off anyway because those missing pieces had to go somewhere. You better find them before they become an issues later.
'85 4Runner Daily Driver, 32" Mud Brutes, 4.88's, Locked F/R, 5" (or so) lift, swaybar disco, OBA, 1" MC, K&N, Accel Coil, Always loud, Always dirty.
raevenzero is offline   Reply With Quote
Old 10-27-09, 10:39 AM   #15 (permalink)
Oh nevermind......
TLCA# 13872
Originally Posted by pappy View Post
Me too.
trash it......
So, what are those fins for, and what are the repercussions of reusing a cover like that?
Old 10-27-09, 10:42 AM   #16 (permalink)
Oh nevermind......
TLCA# 13872
If you try to install the chain in a; pan, chain, timing cover, head, camshaft order it's a royal pain because you are trying to pry the chain up to get around the cam sprocket, and you can not easily reach down and compress the tensioner.
The head and cam need to be on, then the chain, then the cover, then the pan.
Old 10-27-09, 11:16 AM   #17 (permalink)
raevenzero's Avatar
TLCA# 19890
I guess you are right, I have done a head gasket before without removing the timing cover. It was a PITA to compress the tensioner when putting the cam gear back on. It probably wasn't good on the chain either.
I changed the time chain on a 22RE a couple of years ago and found that same lip broken like your's is. I replaced everything except the timing cover since it wasn't the issue in the first place. I never had a problem with it. That being said, I would still recommend you replace the timing cover. I just had to get the truck back up again on a weekend.
Old 10-27-09, 12:04 PM   #18 (permalink)
cruiser88's Avatar
TLCA# 17319
Without looking at my old one I dont see any harm other than possible warpage? Really sloppy work and would worry me to deathe.
Old 10-27-09, 12:24 PM   #19 (permalink)
toy4xfun's Avatar
i have done a few head gaskets with the timing cover on, all you need is a long screw driver and maybe a flashlight and it ain't that bad.
QUIT SUCKING MY OXYGEN
toy4xfun is offline   Reply With Quote
Old 10-27-09, 12:55 PM   #20 (permalink)
Tartu hetkeen
liljlandon's Avatar
Garage
yep, thats how ive done it the last few times
Crusified:
Old 10-27-09, 12:59 PM   #21 (permalink)
raevenzero's Avatar
TLCA# 19890
It was hard for me to get the timing gear and chain on with one hand while prying on the tensioner with the other. Probably would have been easier if I had another hand.
Old 10-27-09, 01:12 PM   #22 (permalink)
toy4xfun's Avatar
i have not had a problem with it. use one hand to pull up on the gear and the other one to pry over the tensioner.
Old 10-27-09, 11:46 PM   #23 (permalink)
WristPin's Avatar
i wouldnt use it casue best i can figure that fin is there for proper oil pick up. you know cause the top end oil supply is fed from that chain
Wristy
Jebus...
I like it when I can go out on the porch buck naked ...unroll it and take a wizz without somebody saying ......look john is alive and well
22RE Tech hotline- check the FAQ
Old 10-27-09, 11:53 PM   #24 (permalink)
Oh nevermind......
TLCA# 13872
Oil pickup? There's no way the oil level is that high, you'd have to have 10 quarts in there! I think the fin is there to help hold the chain on the crank sprocket while you are messing with the upper end, IE doing the headgasket... or changing the valve timing because some Yahoo got it a tooth off.
Old 10-27-09, 11:56 PM   #25 (permalink)
WristPin's Avatar
well your right, but it seems like it would keep a good amount of oil *on* the chain. and with out it, a lot would sling off around that bend
Wristy
Jebus...
Old 10-28-09, 12:00 AM   #26 (permalink)
Oh nevermind......
TLCA# 13872
Hmmmm.... Maybe, but I doubt the fin is close enough to keep oil on the chain... It would have to be pretty tight... There's plenty of oil pouring down the chain hole... So much in fact, that if you plug the rear drain hole in the head, and drive up a hill it floods the valve train and you get lots of smoke pouring out the exhaust... Ask me how I know?
Old 10-28-09, 12:03 AM   #27 (permalink)
WristPin's Avatar
hehehehe i know your right.
well either way i wouldnt use that cover. but those crazy japs have pulled that stunt before...
like why are these arrows on the oil pump? whats this single wire connector for in the middle of my harness? where is the bolt that is preventing me from taking off this timing cover....
Wristy
Jebus...
Old 10-28-09, 08:44 AM   #28 (permalink)
toy4xfun's Avatar
it could be there just to keep oil from slinging up the cover,
