10-25-09, 07:36 PM
buying a gen1 runner
Anything I need to look for beside the obvious as in know issues?
this is a 84 or 86 4 cyl 4.2?? The guy speaks bad english and I barely understand spanish.. much less write english  ..175k miles on it...it is a 4x4, removable top, 2 door, good tires 1500 bucks is what the guy is asking...
thanks D
91 running 33 toyo mt's hillbilly roof rack,air lockers,Tube bumper,breaking stuff too..
custom dog tags for sale GI style or for pets $5 includes shipping
I don't give a damn for a man that can only spell a word one way.
decavo's custom jewelry ,vegan soaps, lip balm, lotions all natural products
10-25-09, 07:39 PM
what is the largest tire i can fit with a stock suspension...
10-25-09, 07:50 PM
There is a big difference between an 84 and an 86. An 84 will be carburated and have a solid front axle. The 86 will be fuel injected and have IFS.
31's, maybe 32's is all you can fit without changing anything.
1989 Toyota Pickup - 255,xxx miles, SAS, Bed Bobbed 14", 95 4Runner front clip, Hanemman Fiberglass front fenders, All Pro 5.5" lift, Hi Steer, 5.29 gear rear Detroit locker, front ARB locker.
1988 4Runner - Blown up 3.0 V6
1999 4Runner SR5 Sport Edition
1992 Lexus SC400
10-25-09, 07:54 PM
this has a efi emblem on the rear of it.... thing is behind a locked fence and the guy speaks little english so the rest is a mystery. how far back do i need to go for solid axles?
10-25-09, 07:56 PM
The engine will not be 4.2 either...it's a 22r or 22re...depending on the years as Toyminator states...a 4 banger...84 or 85 is one of the more favorable years...the others are ok depending on what suspension you want.
10-25-09, 08:01 PM
how about 2.4 engine... What damage should I look for if it is IFS .. solid axles will be birfs like my 80?
10-25-09, 08:25 PM
With the engine I would look for water in the oil mainly and yes the front axles...but as you know a clicking burfield only means it's time for long fields or something equivalent...that's how I approach my wife when it's time to replace something
They are pretty stout trucks otherwise..nothing else to watch for other than abnormal abuse. Good luck!
10-25-09, 08:27 PM
Oh and IFS! I've had about half a dozen of these ..look for broken stops and cracking a arms, torn or loose ball joints...just remember a binding noise while taking a sharp u-turn is normal..it's the steering stops usually and nothing to worry about.
10-25-09, 08:46 PM
broken stops HUH
a arms HUH
10-25-09, 09:39 PM
#10 (permalink)
Oh nevermind......
Broken stops and cracking A arms? What have you been doing to your poor trucks! Mine has 312k on it, and I wheel it pretty good, and there's nothing wrong with the front end, nor have I ever heard of a broken stop or cracked arm....
Check for torn CV boots and idler arm bushings on the IFS. 84 and 85 4Runners were solid axle, 84 was carbed, and 85 was EFI.
10-25-09, 09:45 PM
#11 (permalink)
I sure am hoping for a solid axle
10-26-09, 11:46 AM
#12 (permalink)
my interpretation buddy let me know it is an 87 4.2 engine still not sure about that one.... IFS front end. A/C intact but not operational.... Guy want 1500 good price?
10-26-09, 12:16 PM
#13 (permalink)
death to infidels
No rust and runs ok, good price. He probably means 2.4l. if you decide to wheel it and you reach the limits of IFS, SAS' are pretty easy these days.
10-26-09, 12:28 PM
#14 (permalink)
how much of a lift can this take before messing with drive lines or the IFS?
10-26-09, 01:07 PM
#15 (permalink)
death to infidels
I would probably run 32's with Roger Brown's ball joint spacers Toyota 2WD/4WD IFS Front Ball Joint Spacers for Pickup, 4Runner and T100
Then you can use a combo of longer shackles, add a leaf or (last resort) lift blocks to get the back level.
You won't have to mod the drivelines, it will still have good steering alignment and you can use the stock gearing. The dif drop brackets are total crap, way too much leverage on the stock mounts.
10-26-09, 01:40 PM
#16 (permalink)
Tartu hetkeen
I wouldnt lift, Id trim the fenders and leave it low. If its not your DD then weld the rear and go with a 4.7 kit. Somewhere in the FAQ theres an article about fitting 33's or 35's with no lift. The IFS would hold up to a 33 for a while, maybe a 35 if your smart about your lines.
Crusified:
You don't "lock" a Toyota's hubs, you "Call down the Demons".
10-26-09, 07:05 PM
#17 (permalink)
cutting sheet metal.... my fav thing to do...
10-26-09, 07:46 PM
#18 (permalink)
Awe yes a good question I can't answer. I've never inflicted this damage myself but have seen a few come my way with cracks in the same place, right at the steering stops...I'm guessing someone who was really cranking on the wheel while moving the suspension up and down...a lot. Just something to look for as I have seen a few with this damage, that's all.
10-26-09, 10:14 PM
#19 (permalink)
sounds more like banging into stuff to me.
10-26-09, 10:51 PM
#20 (permalink)
call me tommorow night d.....sorry have not been home much
Get us some pictures of this rig
10-27-09, 05:53 AM
#21 (permalink)
I am heading down to buy it wed....
10-27-09, 05:54 AM
#22 (permalink)
1st mod is to fix the A/C
10-27-09, 10:43 PM
#23 (permalink)
Make sure it doesn't have a blown head gasket.
Bret
Juneau, Ak
1989 FJ62 3FE 125K
1992 Toy short cab 4x4 22RE 177K
