Old 10-22-09, 09:10 AM   #1 (permalink)
death to infidels
Cube Dweller's Avatar
New project I think...first gen
Since I sold my 4runner a couple years ago I've been jonesing for another rig. I had an '80 Longbed right after highschool (20 years ago!) and maybe I'm having a midlife crisis, cause for some reason I wanted another one. So an '83 popped up on CL. I kept hounding the seller, who was having some serious personal issues and she finally was able to get it to someplace I could see it. She wasn't clear on how much she wanted, and I probably could have gotten it for $500, but with the drama going on her life, I didn't have the heart to grind her on price, so gave her $600 for it. So here is is on the trip home, and sitting in my driveway. This truck was absolutely FILTHY, inside and out. Check out the custom lumbar support. Oh, and the seats were held to the floor with a couple 3" deck screws, screwed in from the underside of the cab. When I looked at it, there was a child booster seat on the passenger seat
1983 Hilux Longbed Project Semlin Chat Project Semlin Tech
'97 Locked FZJ80 - ARB Front, Dual Batteries, 2kW Inverter MallCruiser
2 Mid 70's Simplicity Garden Tractors
Cube Dweller is offline   Reply With Quote
Old 10-22-09, 09:21 AM   #2 (permalink)
death to infidels
There's something seriously wrong with the engine, there's a loud, irregular rattling noise coming from the engine. It doesn't sound like rod knock or piston slap; my guess is the timing chain tensioner isn't working for whatever reason and the chain is slapping around inside. First step is to pull the valve and timing chain cover and see what's up.
The other funkiness is the transmission. Since I couldn't drive it and all '83's came with an L52, I assumed it was a 5 speed. Apparently someone swapped in a 4 at one point
The bed has some rust along the seams and the tailgate is shot. I'm going to keep my eyes open for a clean first gen longbed to replace it.
The frame has a bit of surface rust in the bed area that I'm obsessing over. I can hit those with a wire brush on a grinder and paint it with POR or one of Eastwood's products, but any feedback on taking care of the inside of the frame rails? I'm from Cali so I guess I'm very particular about not wanting a rust bucket. I'm actually surprised it has any rust; the truck is from Nampa, which is semi arid and dry. Supposedly they sand the roads when there's snow instead of salt.
Old 10-22-09, 09:29 AM   #3 (permalink)
death to infidels
As far as plans and mods:
1. Get it running. Replace the master cylinder with a 1" bore, this one leaks and I'll run V-6 calipers eventually. Get it smogged.
2. Find a 5 speed, preferably an l52. Ideally from someone that has both the tranny and a case.
3. Find some seats and build mounts.
4. Elockers F+R. I found a deal on an 8.4 for the rear so I already snagged it.
5. Power steering. I'm hunting for the pump/reservoir/bracket. I found an IFS box I'm going to pickup Saturday, along with an IFS (wider) rear axle housing. The housing will be modded for the elocker.
6. Dual cases with a 4.7 rear.
7. High steer.
8. Rears up front and F150's in the rear, unless I score some aftermarket springs cheap. This is going to be a budget build, except for the axles.
9. 35's....BFG MT's, MTR's or similar. I don't want to go 37's with the extra stress on driveline, axles, etc. Plus I still want this to be a solid rig for the street for Home Despot runs, etc.
Old 10-22-09, 09:31 AM   #4 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
Sweet!!! Welcome back Cube!
Old 10-22-09, 09:43 AM   #5 (permalink)
Tartu hetkeen
liljlandon's Avatar
Garage
Thats not in rough condition compared to the one the first gen i have... I buckled up to drive it home, tapped the brakes in slid into the steeringwheel. Seat belt came out of floor, seat bracket fell through the floor, but its in decent mechanical condition.
Crusified:
You don't "lock" a Toyota's hubs, you "Call down the Demons".
liljlandon is offline   Reply With Quote
Old 10-22-09, 07:45 PM   #6 (permalink)
KLF
KLF's Avatar
Hang on... I gotta go buy a 4' wide monitor so I can read this thread...
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 10-22-09, 07:50 PM   #7 (permalink)
Tartu hetkeen
liljlandon's Avatar
Garage
Its fine for me?
Crusified:
Old 10-22-09, 08:26 PM   #8 (permalink)
Oh nevermind......
TLCA# 13872
Mitsubishi floor mats!!! Nice shift knob......
Old 10-23-09, 01:50 PM   #9 (permalink)
death to infidels
And a Crown Royale shifter boot
Old 10-23-09, 01:56 PM   #10 (permalink)
death to infidels
Couple updates. Semlin and I have been having a friendly but heated discussion about which Toyota is more cost effective to build for wheeling, a minitruck or an 80. I have both, but I'm positive it's way cheaper to build a capable mini than an 80. So I hereby christen this truck "Project Semlin"
Did a little calling today and found a locked hi-pinion front dif for $450. Couldn't pass that up, so shipped to my door it was $500. So the running total so far is $1550. I <3 elockers. I'm going to build the lockers up in seperate housings so if I decide to change directions and pursue a different rig, I can roll the old axles back under the truck and sell it w/out. I had the same setup under my 91 4runner and it was a drag to sell them with the truck.
Old 10-23-09, 05:28 PM   #11 (permalink)
Cruiserdrew's Avatar
TLCA# 11734
Nice going Cube.
If you need some help, I owe you and will be happy to pitch in. You are welcome to use my hoist and tranny jack if needed.
Great project
And, BTW---you are right and Semlin is out of his mind. He doesn't know the joy of real gear reduction, and the pain of getting that in an 80 series. With a minitruck, 1 phone call to Marlin or Inchworm and you're ready to go.
Andrew
Old 10-23-09, 08:06 PM   #12 (permalink)
DanS HJ-45's Avatar
TLCA# 17527
That's pretty sweet looking. Really sweet.
If you were near me, I'd sell you a G52 tranny with T-case cheap. Why you wouldn't want a W56 though I don't know.
That thing is screaming "I want a 3L" though. You just haven't heard it yet.
Dan
KE5YYE
1976 HJ-45 (needs restoration) http://forum.ih8mud.com/fj45-owners-...self-into.html
1991 "Faux-Lux"Pickup 4x4 2LT-E/R-150f http://forum.ih8mud.com/79-95-toyota...onversion.html
1979 FJ-40 to BJ conversion http://forum.ih8mud.com/diesel-tech-...ml#post3811936
"Dandelions. You see flowers in these weeds."
--Five Iron Frenzy
DanS HJ-45 is offline   Reply With Quote
Old 10-24-09, 07:15 AM   #13 (permalink)
black95's Avatar
Nice ride, my first rig was an '83 toyota mini, so it makes me a little reminiscent. Mine had a factory sunroof and A/C with intermittent wipers. Should have never sold that truck.
Body actually looks really good, but I think you have your work cut out for you with that interior!
You should auction that awesome shifter knob on E-bay, might get some good money for that!
Black 95 4runner--the family playtoy
silver 01 cherokee--the family hauler
red 88 toyota truck--the red rust sled/abuse testing vehicle
wanna go wheelin? luke 306-3519
black95 is offline   Reply With Quote
Old 10-24-09, 08:09 AM   #14 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
Dan
Ya, why not a W56? Much more common and a better tranny. Too bad I'm not ready. I have a W56 bolted to a 4.7 case that I'm going to replace with a R151 and duals. I'm just not ready to pull it yet.
aka Bushrat
1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled!
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane
pappy is offline   Reply With Quote
Old 10-24-09, 10:50 AM   #15 (permalink)
death to infidels
How long till you're ready? I'm not planning on doing anything to the truck except get it to pass smog for a few months. Is the case you've got a top or forward shifter?
Old 10-24-09, 10:55 AM   #16 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
Top shift. Not sure how long it will be. I've been waiting for the clutch to die, but after 200K it's still going strong.
aka Bushrat
Old 10-24-09, 03:53 PM   #17 (permalink)
KLF
KLF's Avatar
Man, this is really weird. When I look at this thread on my netbook (Dell 2100), all the photos in the first post are glued together in a long horizontal row. Any other computer, they're vertical. Whatever.
It's too bad you're not closer, I have *TWO* perfectly good W56 trannies sitting here, in the way. Both came out of '87 trucks. Shipping would be a giant PITA though.
KB1OSF
'98 Lexus ES300
Old 10-25-09, 11:00 PM   #18 (permalink)
northerner
semlin's Avatar
how much does that one call cost
and how much is cube's time worth for all the mods he is about to embark on?
it depends on you final destination, but good brakes and tranny, lockers and lots of torque means you can go a long way in an 80 without gear reduction. my point is that you can build a locked 80 simply by lifting it for $700 or less used, throwing on 35s and being careful, and you will kick the ass of most minitrucks. and you have a nice civilized daily driver too. adding armour all around adds to the cost, but minitruck armour is not free either.
valentine just bought a locked and medium ome lifted 80 on 33s for $3500 and the seats are properly attached and the engine is not making any funny noises anyway, not intending to start a schotts like debate. the meter is on to see how much time and money cube sinks into this baby before he achieves the daily driver and offroad ability of val's truck.
93 fzj80
66 fj40L
m101cdn trailer
91 LS400 sedancruiser
64, 2x65 honda ct 200
67, 2x68, 3x69, 72, 75 Honda ct90
83 Honda ct70
48 Ferguson TE20
"Diplomacy is the art of having someone else impose your will on you" Lester Pearson
"I have the conch" Piggy
wfc 4812-2635-4880
semlin is offline   Reply With Quote
Old 10-26-09, 08:10 AM   #19 (permalink)
death to infidels
OK, the value of time for mods argument is specious. Baselining an 80 takes a crapload of time too. Adding dual cases is barely more time consuming than R&Ring the transfer case alone. Modding the axle housing for elockers is about 6 hours for both.
I don't think the Cube vs. Val rig is a valid comparison. Perhaps part of our disagreement stems from different perspectives on intended usage. I'm building a mini that can transverse the Rubicon and other trails thru Sierra like Fordyce and Dusy Ershim, while still being useful for Home Depot runs and to drive 5-6 hours to go hunting. In current modified config, Val's rig would be seriously pummeled through the Rubicon, if it could even make it. He would definitely need to armor up the transfer case, add sliders, and run at least 33's. Even then there would be frequent recovery strap usage. And I'll give a 50-50% chance at a bent tie or relay rod. As for not regearing in an 80, I was riding shotgun with Norcaldoug one year climbing a steep granite slab when his tranny stalled- regardless of gear selection, in 4 low his truck would not move forward. He was forced to back up, get momentum and speed through that section in a rather uncontrolled fashion. 315's with stock gearing. The trucks that were regeared didn't have this issue.
As far as armor costs, I can buy sliders, front bumper and rear bumper for $800, from Marlin. For another $300 I can add a combo transfer case crossmember/skidplate, similar to what IPOR sells for the 80. $1100, done. How much are sliders alone for the 80?
I know Canada has equally difficult trails, but are those what you envision when you're thinking the 80 is nearly as capable as a built mini? I'll be the first to concede that for expedition wheeling, the 80 is a far superior vehicle- coil sprung, spacious interior, more comfy, heavier weight dampening road undulations, etc. But for the Sierra, bah!
How about this: if I can get it done in time for Rubithon, I'll register for both the wagon run and one of the hardcore runs, and you can have the passenger seat, plus drive as much or as little as you desire. You'll get first hand knowledge of the difference between the two on the trails I'm building for.
Old 10-26-09, 08:21 AM   #20 (permalink)
TLCA# 11734
I'd say the gauntlet has been thrown...for both of you.
It would be great to have you both on the Wagon Run.
I agree that Semlin's perspective is warped by the muddy goo they wheel in in Canada, and the beautiful and forgiving, traction rich terrain around Moab. The Sierras are a different animal, and while an 80 can be made to go through there, it isn't always pretty.
80-world's best expedition/versatile truck.
Minitruck-world's best hard core wheeler on a budget.
Andrew
Old 10-26-09, 09:07 AM   #21 (permalink)
wut
yooper's Avatar
TLCA# 13011
I wanna go too.
Can I be the referee?
"You cannot invade the mainland United States. There would be a rifle behind every blade of grass." -- Admiral Isoroku Yamamoto
'99 UZJ100 "The Iron Hippo" / '82 FJ40 "Mustard" / '73 FJ40
WFC: 3437-8655-9529
Originally Posted by woody View Post
dude, I can't ban yooper....he's got friggin lazers on his head
Originally Posted by Mars View Post
I need something hot and black inside me.
yooper is online now   Reply With Quote
Old 10-26-09, 09:20 AM   #22 (permalink)
death to infidels
I wasn't going to mention the leader of the wagon run leads it in a sprung over 40 with 35's and an sm465
Old 10-26-09, 09:22 AM   #23 (permalink)
death to infidels
Originally Posted by yooper View Post
I wanna go too.
If you fly out we can throw all the gear in the mini and you and Semlin can take turns driving while I spot . I know one of the Sac based guys will have a spare seat to the trailhead.
Old 10-26-09, 09:26 AM   #24 (permalink)
TLCA# 11734
420
Got a new truck this year anyway.
http://forum.ih8mud.com/60-series-wa...e-new-soa.html
I love everything about minitrucks except 1 thing, which I'll tell you the next time I see you.
Andrew
Old 10-26-09, 01:29 PM   #25 (permalink)
northerner
semlin's Avatar
does he want a pto for the sm465?
93 fzj80
66 fj40L
m101cdn trailer
83 Honda ct70
48 Ferguson TE20
wfc 4812-2635-4880
Old 10-26-09, 01:40 PM   #26 (permalink)
northerner
semlin's Avatar
i'd love to do the rubicon for sure. so i am in.
i agree there is a point beyond which an 80 cannot keep up with a mini as a rock crawler. my point is that, by the time your mini is modded enough to catch up to a lifted locked 80 on 35s, you will have spent more money and way more time (base lining an 80 is a couple of judiciously spent afternoons plus a birf job, and the lift goes in in half a day -- it does not remotely compare to installing elockers, pinions, gears, transfer case(s), beefier birfs, engine, high steer, etc... ) and have a vehicle that, except for rock crawling and home depot trips, is not the equal of the 80 at anything
anyway, let's see. maybe if you keep your budget down to $3500, val and i will come down and we can go head to head
93 fzj80
66 fj40L
m101cdn trailer
83 Honda ct70
48 Ferguson TE20
wfc 4812-2635-4880
Old 10-26-09, 02:56 PM   #27 (permalink)
death to infidels
Are you volunteering to drag your rig or Val's thru the Rubicon ? Cause I'm sure Val would appreciate you volunteering his.
So again back to biases or distorted perceptions...perhaps I have them as well, since to me modifying an axle housing for an elocker is a job, and I forget that not everyone worked as a machinist in a previous life or has a 220v mig welder in the garage. My neighbor actually has a bridgeport in his, so I'm going to see if I can talk him into letting me machine the housings on that, which will rock, since I can cut the slot, mill the section I weld up flat and drill and tap the holes for the additional studs in one setup.
I'm not giving in on the regearing though. A mini with dual cases and stock dif gears is actually geared better for off road than 80 with the same. So from a cost perspective, we either count it for both the 80 and the mini, or we don't for either.
Old 10-26-09, 03:04 PM   #28 (permalink)
northerner
semlin's Avatar
val won't mind i'm sure
if you want to run a minitruck on 35s with stock gears (and birfs), that is your business. i don't care what you do, just keep track of your hours, expenses and travel mileage and we'll see how the finished product stacks up.
93 fzj80
66 fj40L
m101cdn trailer
83 Honda ct70
48 Ferguson TE20
wfc 4812-2635-4880
Old 10-26-09, 03:56 PM   #29 (permalink)
TLCA# 11734
Sure, love to have it. Bring it to Rubithon as I have a 465 in the garage waiting for a future project.
Andrew
Old 10-26-09, 04:29 PM   #30 (permalink)
northerner
semlin's Avatar
sorry, i don't actually have one, but there is one locally for sale in the classified. it has dropped from $300 to $150 in the past couple of weeks.
93 fzj80
66 fj40L
m101cdn trailer
83 Honda ct70
48 Ferguson TE20
wfc 4812-2635-4880
