Old 10-13-09, 09:17 PM   #1 (permalink)
Help! Suspension lift kit!!!!
Hi guys,
Im pretty much new to this site, and to off-roading. First of all i have a 92 Toyota pick up truck, 4x4, 5 speed. 3.0, extended cab. Well im planning to install a suspension lift kit (at least 4 or to 5 inches) on my truck. What brand is the most affordable, and dependable that i can buy on the market today? I am planning to use my truck for a little bit of mud, and little bit of off-roading. im not looking for HARDCORE off roading! aha.
hopefully you guys can help me! thanks
tl;dr What brand is the most affordable, and dependable that i can buy on the market today? only for mud, and regular off-roading. BTW! i have a 3 inch body lift already
92rush is offline   Reply With Quote
Old 10-13-09, 10:04 PM   #2 (permalink)
StaleAle's Avatar
TLCA# 16786
You are looking for troubles with 4-5" of lift
Your front IFS and alignment will not tolerate that kind of lift without significant mods that are probably way beyond what you are looking to spend. Stick to less than 3" to avoid premature CV joint failure and excessive vibration at highway speeds.
There are some good kits available, not sure what's available for your model year but look at Old Man Emu (OME) and Sonoran Steel if you want to improve handling and offroad capability. Be wary of kits using spacers. These are mostly used for looks and will not improve your ride and could potentially damage your truck if you get too rambunctious offroad. Sonoran Steel has an informative, if somewhat self-serving write-up in their website.
If you want to go that high, I assume you are looking to fill the empty space with large meaty tires. Do that, and your 3.0 liter engine will disappoint you unless you also change your gearing.
Bottom Line: Do your homework based on an honest assessment of how you plan to use the truck. 4-5" of suspension lift on top of a 3" body lift is pretty extreme for such a narrow, light weight vehicle. Think about that in a strong cross wind on teh freeway or off camber trail.
Good luck with yout build!
WTB '?? FJ40
'00 4Runner
'92 4Runner (trade-in for 3rd Gen)
'80 Hilux 4X4 LWB (Gone...)
'67 FJ40 rag top (Gone...)
Capital Land Crusier Club (www.clcc.org)
Toyota Land Cruiser Association (www.tlca.org)
Bringing Toyota 4WD enthusiasts together since 1976
StaleAle is offline   Reply With Quote
Old 10-13-09, 11:16 PM   #3 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
You don't need to do any of that to go play in the mud, or rocks a bit. You can fit 33's without any lift, and in my opinion it looks better low with bigger tires than tall with lots of space above the tires.... Go do some reading in the FAQ thread.
Welcome to Mud!!!
Old 10-14-09, 05:19 AM   #4 (permalink)
corax's Avatar
Garage
you should already be able to fit 33's with that body lift you have - unless you really want to hit the hard stuff or look like a refugee from the 80's you won't need much more than that. If you really want to go that high, look into a solid axle swap - but there you're looking at thousands of dollars and some compromises with ride quality
-Keith- kb3scj
'88 4runner SR5 - 3L 7MGE swap - Marlin HD W56 - 4.56 V6 Thirds, LSD up front - 33x10.5 BFG KM2's- home fab front and rear bumpers - NWMP 14 gal aux fuel tank
"Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
corax is offline   Reply With Quote
Old 10-14-09, 07:05 AM   #5 (permalink)
So go with 3'' suspension lift? right now i got 33x12.5x15 BFG A/T tires still rubbing my rubber!!!!!!
Old 10-14-09, 07:12 AM   #6 (permalink)
And i got 15x8 PRO COMP rims, my tires was sticking like 2'' out.
Old 10-14-09, 08:56 AM   #7 (permalink)
Oh nevermind......
TLCA# 13872
I have 33X10.5s and they only rub when stuffed and turning. And I'm only lifted 2 inches. Find out where it's rubbing and get rid of that part!!!
Old 10-14-09, 10:15 AM   #8 (permalink)
Ok tnx dude!!!!!!
Old 10-14-09, 11:09 AM   #9 (permalink)
Oh nevermind......
TLCA# 13872
Lift money would be much better spent on a rear locker anyway...
I just have longer shackles in the rear and I cranked the torsion bars up front.
Old 10-14-09, 04:02 PM   #10 (permalink)
Hey StaleAle i check and call SONORAN STEEL, they never make no suspension lift for 92 toyota truck, not good!!!!!!!!!
Old 10-14-09, 04:08 PM   #11 (permalink)
Now im going with 3'' suspension lift, thank you guys for all the help, but now im looking for a affordable and dependable 2'' or 3'' lift kit for my truck, pls. give me a brand name or web site and i will search for it, thanks guys.........
Old 10-14-09, 04:27 PM   #12 (permalink)
Tartu hetkeen
liljlandon's Avatar
Garage
So your saying that you have a 3" body lift, and it is still rubbing on 33's? You independent front suspension is pushed pretty hard with 33's, and to go up in size will ultimately mean dissapointment and more money. I can do trails that you wouldnt think possible on 31's. Traction is an important factor. If your dead set on a lift, google what you need. I see a tuff country for around 800.00.
The problem is "affordable and dependable". Those two words shouldnt be used when discussing lifting an independent front suspension.
Crusified:
You don't "lock" a Toyota's hubs, you "Call down the Demons".
liljlandon is offline   Reply With Quote
Old 10-14-09, 09:49 PM   #13 (permalink)
wow, I am running 36's with a 3 inch lift...
my tires don't rub.
missouriman is offline   Reply With Quote
Old 10-14-09, 10:51 PM   #14 (permalink)
89GASHOG's Avatar
Here you go. Cruiser Outfitters
As someone already mentioned, longer shackles and cranked up torsion bars could achieve the same thing.
Bret
Juneau, Ak
1989 FJ62 3FE 125K
1992 Toy short cab 4x4 22RE 177K
89GASHOG is offline   Reply With Quote
Old 10-15-09, 05:33 PM   #15 (permalink)
i had a 92 toyota pickup. It had a 4 inch suspension lift, bigger torsion bars and longer shackles. it measured about 7 inces taller, it had 35x15.5x15 Super swamper SX. it measured about 7 inches taller than factory and i never had any problems with anything.
hardontoyotas is offline   Reply With Quote
Old 10-15-09, 09:23 PM   #16 (permalink)
Thanks dude
Old 10-15-09, 09:27 PM   #17 (permalink)
nice, so what suspension lift kit u got:confus ed:
Old 10-15-09, 09:56 PM   #18 (permalink)
stay low and slow.
Old 10-15-09, 10:33 PM   #19 (permalink)
Oh nevermind......
TLCA# 13872
Originally Posted by missouriman View Post
stay low and slow.
and Locked! Tall isn't all it's cracked up to be.
Old 10-15-09, 11:01 PM   #20 (permalink)
KLF
KLF's Avatar
I'll toss this out there, just for your consideration. I helped my son install a set of Roger Brown's ball joint spacers on his '87 4Runner last night. It was remarkably easy to do, as long as you have the right tools. You do have to do some cutting on your upper control arms, we used a cutoff tool and cleaned it up with a stone in a die grinder.
It gave him about 2-1/2" of lift in the front, but I'll tell ya... the alignment was whacked when we took it down off the stands, we measured ~2.5" of toe-in. He had it aligned today and it drives great now.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 10-16-09, 07:11 PM   #21 (permalink)
[QUOTE=missouriman;4880752]stay low and slow.[/QUOTE
im trying tooooooo stay slow, hehehehe
Old 10-16-09, 07:31 PM   #22 (permalink)
yes i know that, coz u guys teach me , but like i told u guys, i got no choice , my 33'' tires is RUBBING:co nfused:, i check this suspension lift kit on EBAY, ROUGH COUNTRY only $609, 4 to 5'' lift, do u guys think thats good????? i see some lift kit like, TUFF COUNTRY, SKYJAKER, PRO COMP, FAB TECH, so which 1 guys??????????? i need your help guys, tnx
Old 10-16-09, 07:44 PM   #23 (permalink)
This Sunday ill take my truck to my friends shop, he gonna re-build my trani. yahooooo
Old 10-16-09, 09:43 PM   #24 (permalink)
3.5 inch lift.
36 inch SX's
no rub.
Old 10-16-09, 10:01 PM   #25 (permalink)
Oh nevermind......
TLCA# 13872
[QUOTE=92rush;4883615]my 33'' tires is RUBBING/QUOTE]
33X10.5 or 33X12.5? Where are they rubbing?
Old 10-17-09, 01:08 AM   #26 (permalink)
[QUOTE=2ndGenToyotaFan;4884052]
yeah btw thats my 92 toyota pickup truck, as you can see its bone stock, compare to your truck (missouriman), yours is ready for battle already. i like it, nice
Old 10-17-09, 01:09 AM   #27 (permalink)
yeah btw thats my 92 toyota pickup truck, as you can see its bone stock, compare to your truck (missouriman), yours is ready for battle already. i like your truck, nice.
Old 10-17-09, 06:09 AM   #28 (permalink)
i have a 4inch BDS suspension lift
Old 10-17-09, 07:13 AM   #29 (permalink)
Thanks.
I don't know if you want to cut your fenders.
I trimed mine and the rear of the wheel well.
I have a question is it rubbing on the fender or the pinch seam on the inside of the wheel well?
here is fender triming and how to hold the bottom of the fender.
Old 10-17-09, 09:31 AM   #30 (permalink)
Oh nevermind......
TLCA# 13872
Now that I've seen the pic I have the solution..... Go buy a different truck, you don't want to wheel that nice thing!!!!!!! You'll ruin it!!
If they are rubbing the seam, just take the tire off and pound it flat with a 5 lb sledge.
