10-04-09, 11:33 AM
Heater controls
some a$$hat put a rock through my ps window a few months back to steal my cheapo Sirius radio. fast forward to present and I find the rock hit the slider controls and now do not work. How do I gain access to these behind the dash?
1985 Xtra-Cab pickup SR5
Bob Bulleri
Novato, Ca.
1974 FJ40 2F Engine, DUI HEI, 2.5" OME lift, 33x12.50x15 BFG M/Ts, Front Disc Conversion, P/S, Header, locked, Detroit rear, ARB front, Mudrak Improved!
1985 Toyota 4x4 Pickup, Xtra Cab, EFI, OME 2" lift(NEW!)
TLCA# 13586
Pacific Mountain Cruisers
10-04-09, 12:23 PM
Howdy! I have a similar problem. I know that I can''t reach up from the bottom, from the radio position, as it is sealed below the air controls. John
85 Toyota mini truck  for chase/support!
CSC #41
10-04-09, 03:18 PM
I dont have an 85 BUT I would think it would be similar to my 92.
You have to remove the dash as if you were going to install a radio. With all that gone, it should be pretty obvious.
On my 92, all the AC/Heater controls are in a contained box i.e. not like an fj40.
"May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU
10-04-09, 06:12 PM
I have a Chilton's manual, but it doesn't have any info on the interior. I guess I'll just have to wing it and see. Not sure how to get behind the dash.
Bob Bulleri
Novato, Ca.
TLCA# 13586
10-04-09, 06:59 PM
Tartu hetkeen
What i did on my 84, from memory, is remove all the knobs/buttons and the black part with the heat/cold, hi-lo, etc. on it and it pops out. Then you have access to the heater control. toyota wants 91.00 with my discount, so i ran a toggle switch and have one speed. You could rig it to have more, im just cheap and on a college budget. Had to allow for crawler gears some how...
Crusified:
You don't "lock" a Toyota's hubs, you "Call down the Demons".
10-04-09, 07:34 PM
I'll give that a try.
This thing was perfect when I bought it 3 years ago. some punk puts a rock through a window for a $39 radio. The glass cost me $200.
Bob Bulleri
Novato, Ca.
TLCA# 13586
10-04-09, 10:11 PM
Oh nevermind......
Pull of slider knobs, and pry the face off starting at the drivers side, I use the can opener on my knife to get in one of the slider slots. That will give you a good bit of access, it you need in deeper, pull the ash tray out and remove the lower center section where the radio is. Good luck Bob!
10-05-09, 12:13 AM
If I remember right, I even had to pull the dash pad off on my '88 to fix my hot/cold slider. It was quite a job.
Black 95 4runner--the family playtoy
silver 01 cherokee--the family hauler
red 88 toyota truck--the red rust sled/abuse testing vehicle
wanna go wheelin? luke 306-3519
10-07-09, 08:15 AM
once you get the face off the sliders have 2 philips head screws and you can pull it out a bit.
QUIT SUCKING MY OXYGEN
