Old 10-02-09, 07:40 PM   #1 (permalink)
black95's Avatar
correct 22re thermostat temp?
oops!
Black 95 4runner--the family playtoy
silver 01 cherokee--the family hauler
red 88 toyota truck--the red rust sled/abuse testing vehicle
wanna go wheelin? luke 306-3519
black95 is offline   Reply With Quote
Old 10-02-09, 07:46 PM   #2 (permalink)
black95's Avatar
22re correct thermostat temp?
Wondering if anyone knows offhand what the correct thermostat temp on a 22re is? Autozone computer says 180* is stock. (I really don't care how you feel about autozone, thanks) 180* sounds a little cold to me.
Just pulled a 195* out of the truck, which was overheating, but it was mostly the fan clutch. (changing everything in the way of preventative maintenance) Just want to put the right thermo in to get the most out of the engine.
Old 10-02-09, 07:53 PM   #3 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
Correct is 88*C=190*F. IIRC 180*F is for the 22R and the 22RET.
aka Bushrat
1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled!
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane
pappy is offline   Reply With Quote
Old 10-02-09, 08:03 PM   #4 (permalink)
black95's Avatar
curious, autozone and checker auto websites both have the 180* listed as factory and the 192* as the "high temp" alternative.
Old 10-03-09, 09:26 AM   #5 (permalink)
cranky steve's Avatar
Best stat is a Factory 2 stage Thermostat !!
Question: “Why does my engine temp go all the way up to the red before it comes back down to the middle of the gauge after I start it up in the morning. It only does this when the engine is cold and once it warms up it seems to operate normally. Could it be as simple as a stuck thermostat?”
Answer: (From Roger Brown’s Web Site - http://www.4crawler.com/4x4/CheapTricks/index.shtml#Thermostat)
“What happens on the 22R and 22RE engine, when the coolant goes through the heater core it gets cooled off enough that when it gets dumped back in on top of the t-stat it shuts it. Therefore the temperature in the engine continues to go up. The t-stat that I have mentioned has two valves in it, one at the regular temp. and one smaller on at a cooler temp. If the cool water shuts the big one, the smaller one stays open. All this happens because of the lack of a by-pass hose, which on other systems, keeps hot coolant running on the t-stat.”
You can get the two-stage thermostat mentioned above from your local Toyota Dealer.
Part Number: #90916-03070
85 Toy Xtracab
"I DON'T want to understand !!"
Click here to donate to the Rubicon Trail Foundation
Rubicon Trail Patrol
Rock-N-Roll 4X4 Club
"Wow this is unbelievable"
cranky steve is offline   Reply With Quote
Old 10-04-09, 08:34 PM   #6 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
Says the guy who doesn't want our opinions on AutoZone... Hehehe I don't mind cheap parts... when they are easily replaced and not critical to vehicular function....
Old 10-05-09, 12:06 AM   #7 (permalink)
black95's Avatar
most of the time on mud you get crucified if you don't go to the dealer for a part.........heaven forbid! Anyone who's ever seen my '88 rustbucket understands the need for cheap-o parts.
By the way, the 180* thermostat is working great!
Old 10-05-09, 09:31 PM   #8 (permalink)
mudmaster's Avatar
195 in mine
Time to go wheelin'!
mudmaster is offline   Reply With Quote
Old 10-06-09, 07:04 AM   #9 (permalink)
toy4xfun's Avatar
i have the 180 thermostat in mine. but in cold weather the heater does not put out enough heat so i am changing it.
QUIT SUCKING MY OXYGEN
toy4xfun is offline   Reply With Quote
Old 10-06-09, 07:33 AM   #10 (permalink)
KLF
KLF's Avatar
I use the 2-stage one, posted on Roger Brown's "Cheap Tricks" page (see #5 above). Works very well.
For some reason the link posted isn't correct, here is the correct one:
Toyota 4Runner and Pickup: Cheap Tricks
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 10-06-09, 07:58 AM   #11 (permalink)
photosynthesizing
pappy's Avatar
TLCA# 10004
Garage
I used to run the 180 22RET thermostat in mine, but the truck ran cold. I now run the 195* and except on rare occasions the truck hardly sees 180*.
aka Bushrat
Old 10-06-09, 09:45 PM   #12 (permalink)
89GASHOG's Avatar
“What happens on the 22R and 22RE engine, when the coolant goes through the heater core it gets cooled off enough that when it gets dumped back in on top of the t-stat it shuts it. Therefore the temperature in the engine continues to go up. ..
Very interesting. Mine does the same thing-but only when I have the heat turned on. If it's set to cold, the temp gauge doesn't spike up.
Bret
Juneau, Ak
1989 FJ62 3FE 125K
1992 Toy short cab 4x4 22RE 177K
89GASHOG is offline   Reply With Quote
Old 10-06-09, 09:52 PM   #13 (permalink)
Oh nevermind......
TLCA# 13872
That's cause on "cold" the heater valve is shut, and the coolant can't circulate through the heater core and cool off...
Old 10-06-09, 10:03 PM   #14 (permalink)
corax's Avatar
Garage
I grabbed a Ford 160 degree and trimmed the sides till it fit in the housing (difference between 54mm and 52mm I think). I did this before driving cross country when my radiator was sized a bit on the small side, 160 degree air from the heater was still hot enough last winter. Now I have a huge radiator and still have the 160 degree in . . . . might change that one of these days, but you can't really go wrong with cooler - just don't ever think pulling the t-stat out completely will make it run cooler than a colt t-stat.
-Keith- kb3scj
'88 4runner SR5 - 3L 7MGE swap - Marlin HD W56 - 4.56 V6 Thirds, LSD up front - 33x10.5 BFG KM2's- home fab front and rear bumpers - NWMP 14 gal aux fuel tank
"Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
corax is offline   Reply With Quote
